Sponsored by The Tire Rack
Old 04-28-2010, 03:54 PM   #1
newtuner
My Ride: '04 330CI, M package
Can a regular tire shop do a proper alignment on a BMW?
Like the title says I'm wondering if a regular tire shop has the proper set up to do an alignment on BMWs. Of course they have all said they do, but I wanted to know or do I have to take it in to a dealership?
newtuner is offline   Reply With Quote
Old 04-28-2010, 04:04 PM   #2
jcns
My Ride: California
short answer, yes.
long answer, yes but find a reputable shop. Ask other BMW owners in your area, where they go.
Want to feel like you got raped with a 10 foot pole, go to the dealership.
The difference between dealer and reputable shop, 10 foot pole.
jcns is offline   Reply With Quote
Old 04-28-2010, 04:18 PM   #3
Riverbmr3
My Ride: MB E350 & BMW 325i
went to firestone for an alignment, they refused and told me to go to the stealer!
Riverbmr3 is offline   Reply With Quote
Old 04-28-2010, 04:21 PM   #4
mvrk10256
My Ride: E30 325i
as long as they do 4 wheel alignment (most modern places) it will be ok.
Old 04-28-2010, 04:29 PM   #5
newtuner
ok, there is an indy shop near my work that I might take it to. I was just wondering as the tire shop might give me a deal on the alignment when I buy all new tires.
Old 04-28-2010, 07:47 PM   #6
BMWstudent
My Ride: hates potholes
The only time I've gotten an alignment that I wasn't happy with was Pepboys.
BMWstudent is offline   Reply With Quote
Old 04-28-2010, 11:44 PM   #7
VECTOR
My Ride: 2004 330CI auto vert
We have Tire Kingdom down here and they do a fine job. They give you a print out and if you are not satisfied you can bring it back (forget how long) and they will do it again WITHOUT CHARGE.
i GET THE MULTI YEAR PLAN because if you are going to keep the car for any length of time, it saves you money.
VECTOR is offline   Reply With Quote
Old 04-29-2010, 12:31 PM   #8
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Most independent alignment shops should be able to do the work. There is nothing different on a BMW vs. another manufacturer. Most alignment shops will have a database in which will include all OE specs for vehicles here in the U.S.
Before going to any random shop though, I do recommend asking for reviews and double checking their work.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 04-29-2010, 01:33 PM   #9
TallTravel
My Ride: E46/2
When I first purchased my E46--from the original owner--I got new tires and an " alignment " from a very well regarded indy tire and alignment center in Tampa, Florida I asked if they knew the details of my car, and they said " Oh, yes, we align them all the time ". This reinforced the opinions of my friend, who had a BMW 3 series and a 5 series, all aligned at this same place through their entire life. They seemed to know what they were doing on the face of it.
Well, they put the car on their fancy machine and could not get it aligned. They blamed it on some sort of unknown " damage " to the front passenger side. They had great difficulty adjusting the camber, and I drove away with it out of alignment. Bottom line: they had the " specs " in their hand because they looked it up in their database. But could they align it? No, because they did not know how to adjust the camber.
Walk into the dealership and they said simply " a lot of the indy places do not know how to adjust the camber on a BMW." On my car at least (2001 330ci sport package) the camber adjustment is apparently above the tire, in the wheel well, and some indy shops don't know this.
I gave the project to the dealer and they showed me the print out--perfect alignment.
Indy: fail
Dealer: Perfect
The real answer came to me a while later, when I found out the guy who is the best alignment tech at the indy place was gone that day.....without him, no one there knew how to align my car properly.
TallTravel is offline   Reply With Quote
Old 04-29-2010, 04:36 PM   #10
Kubica
My Ride: 2003 325xi
It's obvoiously all about the person doing it.
Make sure they ballast correctly- need 150lbs in each front seat, 150 in the rear center and 50 or so in the trunk.
Old 06-27-2010, 11:39 PM   #11
Jahan
My Ride: 2008 Corvette
Only if that's how the car is driven most of the time. On the cars that I take to the track, I have them aligned with me sitting in the drivers seat and 1/2 tank of fuel.
Jahan is offline   Reply With Quote
Old 06-28-2010, 03:05 AM   #12
Penguin Koolaid
Banned
My Ride: Inline Six
I have an indy shop I get some of my less intensive work done. They have a hunter road force balancing machine and state of the art laser alignment setup. It would be hard to guess by the appearance of the rest of the shop, and their typical clientele.
So it really depends on their setup. You never know.
Penguin Koolaid is offline   Reply With Quote
Old 06-28-2010, 09:13 PM   #13
WilliamLD
My Ride: 01' Bmw 330ci
Do you think these shops can adjust my rear camber arms as well? When I bought my suspension I also ordered the rear adjustable camber arms to dial it in more. The should be able to adjust this too right?
WilliamLD is offline   Reply With Quote
Old 07-07-2010, 09:19 PM   #14
mickey513
My Ride: e46
From experience: NO
I used 3 Firestone, 2 Wheelworks (local chain), and Sears
NONE OF THESE PLACES could align the car properly. Every time I would have a problem, they will come up with all sorts of B.S. saying the sheets show it's in spec and yada yada yada. I threw away 2 perfectly good front tires when one of these Firestone told me "it was the front tires". Funny how they drove fine for over 30k miles until I came here.
I found a repair shop that specializes in BMW and they got the alignment correct the first time.
mickey513 is offline   Reply With Quote
Old 07-07-2010, 10:10 PM   #15
Penguin Koolaid
Banned
My Ride: Inline Six
Originally Posted by mickey513 View Post
From experience: NO
Yea, I wouldn't go to a large chain that caters mostly to lower end domestics and imports. Some local indy shops that work on higher end cars and/or German vehicles would typically have the knowledge and equipment needed. Like I said, I go to a shop that has a top of the line laser alignment setup and they do a lot of work on BMW/Audi/Mercs.
Old 07-12-2010, 09:24 AM   #16
Leathers
My Ride: 2004 325xiT
How much has the dealer quoted? Is there a huge difference between dealer and indy for an alignment?
Leathers is offline   Reply With Quote
Old 07-31-2010, 12:46 PM   #17
stoble
My Ride: 2004 325i
I need new tires and an alignment. So I've been looking at the recommended installers on tirerack.com in hopes that I could get my tires mounted and then get an alignment from the same shop. I called the 2 local recommended installers listed on TireRack and both told me to go to the dealership or a European shop. One guy said it's alot more complicated to do properly for a BMW and that their equipment wouldn't be able to do a sufficient job.
How much does the dealership charge? How much have u guys paid at indie European shops?
Edit: Checked a local European shop and they quoted $119.99 for a 4 wheel alignment.
stoble is offline   Reply With Quote
Old 08-07-2010, 02:54 PM   #18
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
I'm not saying they can't but alot of them will refuse to........and if its lowered deff not......
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
