Old 04-28-2010, 05:42 PM   #1
B3ZKONTROLU
My Ride: 03 325i and 04 545i
Question DEPO HID Xenon headlight installation guide?
Hello fellas,
I have a 2003 325i sedan and recently decided to upgrade my OEM halogen headlight assembly to an HID Xenons with Halos and so on! I got the headlight assembly delivered today, however with no instructions in sight! Does anyone have any info on how to install these 'bad boys'?
Thanks!
B3ZKONTROLU is offline   Reply With Quote
Old 04-30-2010, 07:13 AM   #2
Bimmer Dude Xi
My Ride: 03 325XI 07 ZX-6R
Send a message via AIM to Bimmer Dude Xi
very easy, loosen the corner light with a phillips screwdriver then pull it out. pull out the lower headlight trim, then remove the four 8mm screws, two on top of the headlamp assmebly then the one 8mm screw behind it and the last is towards the grills. once you remove those four screws the headlamp should be able to be removed easily
good luck
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
|BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
Bimmer Dude Xi is offline   Reply With Quote
Old 04-30-2010, 12:26 PM   #3
Oz Striker
My Ride: '00 330Ci, '07 350Z
Just watch your heallamp washers, as you pull the lower trim out, washer fluid will prob start to leak out. You could always empty the reservoir first.
My YouTube Channel incl Muffler delete vids: http://www.youtube.com/user/OzStryke...view_as=public
My blog on E46 DIYs & Mods http://lifewithabmw.blogspot.com/
Oz Striker is offline   Reply With Quote
Old 04-30-2010, 12:30 PM   #4
snowcatxx87
My Ride: 04 330CI
I wouldn't empty the container, I'd remove it with the fluid in. Just make sure you have something to plug the lower pump holes.
snowcatxx87 is offline   Reply With Quote
