Old 04-29-2010, 08:45 AM   #1
mojovase
My Ride: 2004 330Ci Conv
Replacing Air Mass Meter Tips
SES light went on. Took car to mechanic and was told I have a hole in the lower section of the air mass meter boot. Said I would need to have it replaced. I see that they are sold for $12 to $15.
Did a search and was unable to find any DIY tips. Anyone out there have directions or whatever to help me replace the lower section.
While I am considering having it done myself, I'm also wondering if I should replace the whole unit or not necessary? Any help you can provide would be appreciated.
Thanks!
mojovase is offline   Reply With Quote
Old 04-29-2010, 09:17 AM   #2
glxedwards
My Ride: 2006 A4 & 2001 325XI
Are you talking about the mass air flow sensor? All the pieces and parts are rather easy to replace and you should be able to do it yourself. Take a look at realOEM for the diagram of your MAF parts. http://www.realoem.com/bmw/showparts...05&hg=13&fg=15
This will literally be a flat head screw driver type job for you.
Good luck.
glxedwards is offline   Reply With Quote
Old 04-29-2010, 09:52 AM   #3
nughaud
My Ride: '01 330CI / '11 335i
Well you are either talking about part 3 or part 6.
Just like glxedwards said, you just need a screwdriver to change the parts.
As long as it's just a hole and not the MAF itself the cost will be minimal.
nughaud is offline   Reply With Quote
