Old 04-29-2010, 04:11 PM   #1
coxm1
My Ride: 2001 325i
Power Loss at Higher RPM's
Well, a month or so back my SES light came on while driving over a pass on a road trip. After scanning the car, the code that pulled was “P0171 – Bank 1 too lean”. So I replaced both pre-cat 02 sensors and reset the SES light. However, a week later the SES light came back on, with the same code.
Now, even when I reset the SES light, I seem to have lost horsepower at higher RPM’s. You can feel a noticeable decrease in acceleration at 4,500RPM.
My next guess is fuel filter, however if the filter was getting plugged then I would think that it would say both banks are running lean. Same goes for a vacuum leak. Does anybody have any ideas as to what would cause this code and/or check engine code?
coxm1 is offline   Reply With Quote
Old 04-29-2010, 04:18 PM   #2
Mike666
My Ride: 2000 323i
You might want to check your MAF sensor. Just a thought.
Mike666 is offline   Reply With Quote
Old 04-29-2010, 04:21 PM   #3
coxm1
My Ride: 2001 325i
I did pull the MAF Sensor out and sprayed it with a specifically designed cleaner but it didn't help.
Old 04-29-2010, 04:33 PM   #4
Andy2108
My Ride: SpecE46 & E46 M3
vanos seals <--- search
De gustibus non est disputandum.
p0171, power loss
