New ZHP cams on sale for $490 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-29-2010, 07:35 PM   #1
Iceman00
Banned User
My Ride: E90 6MT
11120429575 is the part number. Anyone want to buy me a set?
Old 04-29-2010, 11:38 PM   #2
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
So where's the sale?
/// MODS
/// Auto => 6-Spd Manual Conversion | Apex EC-7 | Koni/Ground Control Coilovers | Vorshlag Camber Plates | BMW Performance LCA | Mishimoto Intake Boots | GruppeM rep CAI | Shark Injector | 5000k Xenarc CBI 66240 HID | BMW European MTechII | BMW Performance Shifter | ACS Mirrors and Rear Spoiler ///
Old 04-30-2010, 12:35 AM   #3
carcus
My Ride: 2006 BMW M5
Pass on them.....expensive
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
Old 04-30-2010, 12:38 AM   #4
e36-2.0
My Ride: 330xi
buy YOU a set?
um no. EF that
'02 330xi
Konigsport/Ground Control/DPE/BMW Motorsport/Eurosport/Turner Motorsport/PowerFlex/RacingDynamics/Hotchkis/UUC/Beisan/Bimmerworld/Dinan/Conforti/RPI/GroupN/Technik/Dynavin
Alberta's BMW enthusiast forum.
-Projecttechnik.com
e36-2.0 is offline   Reply With Quote
Old 04-30-2010, 01:29 AM   #5
TitaniumCranium
/// Limitless
At $490 I'd do it, but not at $1200+
/// MODS
Old 04-30-2010, 03:19 AM   #6
Iceman00
Banned User
My Ride: E90 6MT
Tischerbmw has the "kit" on sale for $490 when you type in the part number. I seriously considering buying them.
Old 05-02-2010, 08:39 AM   #7
xixixi
Banned User
My Ride: 01 330x-xi
perhaps a dumb question but what else is required in swapping these cams over software, upgrade???
Old 05-02-2010, 10:56 AM   #8
TitaniumCranium
/// Limitless
The cam slightly changes the duration that the intake and exhaust valves are open, allowing more fuel/air into the motor. The effect becomes more apparent at higher RPM's. The ZHP software is different but you have to have a MS45 DME (after 3/03) to load the software. My car and cars prior to build date 3/03 have the MS43 DME. The ZHP software raises the rpm limit from 6,600 to 6,800. The increase in power will be due to the cam duration as the fuel/air ratio won't change. It's monitored by the O2 sensors. If your car is prior to 3/03 you'd need to Shark it to raise the rev limiter + you can go 155+ mph too.
To do the job you'd at least need to purchase a new camshaft cover gasket. When I do motor internals I also religously replace all nuts and bolts with new, just to be on the safe side. Since your going to be "in the motor" this would be an excellent time to visit Besian's site and do the Vanos seals (and a exceptional write-up on getting into the motor that far). While you're at it there is also a known issue with the ZHP camshaft rattling (marbles in your motor). Besian also has a cure for that so get it at the same time and stop it before it starts. It would also be a good idea to replace the camshaft position sensors since they would be extremely easy to get to and fairly cheap. And if you're at a point where it makes sense mileage wise, the tstat and water pump too.
/// MODS
Old 10-29-2010, 02:42 AM   #9
richyboycaldo
My Ride: Mx5 300zx 240z 330c
I just installed zhp cams on my 2001 330ci, should I buy a tune from AA or ESS? do I buy it for ms43 or ms45? I am kinda confused
richyboycaldo is offline   Reply With Quote
Old 10-29-2010, 06:25 AM   #10
Bimmerguy82
My Ride: 2004 ZHP 6 SPD
MS43 and I prefer AA.
BMWCCA member #407674
___________
-Joshua
ZHPMafia.com member
Ebay headers | 3.38 diff | 2.5" cat-less exhaust | K&N intake | AA stage 1 software | UUC stage 1 light flywheel and clutch | UUC Evo 3 ssk
Bimmerguy82 is offline   Reply With Quote
Old 10-29-2010, 07:22 AM   #11
ECSTuning
ECSTuning's Avatar
My Ride: BMW
We don't have them available at $490, but we do have the BMW M54 Performance Engine Kit! And as of the time of this post priced at $299 if anyone is interested!
Increase your horsepower, torque, and redline with this all inclusive kit from BMW.
* Increases engine performance to 235hp
* Boosts torque by 8 ft lb
* Raises redline to 6,800 rpm (from 6,500 in the regular 330i)
Note: For E46 330i (without option Performance Package) from 03/2003 on with electronic control unit MS 45
Best,
Joe
Old 10-29-2010, 09:10 AM   #12
Lemonsqr
My Ride: 2001 TiAg 330i
unless you DIY, I dont think it is worth it and DIY is a pain IMO....
Lemonsqr is offline   Reply With Quote
Old 10-29-2010, 09:12 AM   #13
rmank
My Ride: 2000 323Ci
Does anyone know if there is there any way these could be used on the 2.5L engines, M54 or M52tu? I've read the 3.0 cams have a 1mm higher lift and different duration than the M52tu cams, is this a benefit?
The reason I ask is that I'm doing a b30 manifold swap and headers on my 323ci, and was looking into a custom tune after modding is done. Would these cams add hp, torque, or improve the power band with the planned mods and a custom tune? Installation aside, $300 for 10hp is seems reasonable (Schrick cams are better I'm sure, but yes it is only a 323, I just like to learn and I enjoy the car).
rmank is offline   Reply With Quote
Old 10-29-2010, 09:27 AM   #14
Chris911SC
My Ride: '04 330xi 6sp Sport
Best,
Joe
What components does this kit include? And how does it differ from the ZHP cam?
Chris911SC is offline   Reply With Quote
Old 10-29-2010, 09:48 AM   #15
My Ride: Lexus
^Those are BananaBoy cams. Highly regarded in the Mustang community!
Old 10-29-2010, 10:05 AM   #16
shanneba
My Ride: 2003 330Ci
The 3.0 liter M54 also has different valve springs to allow for the increased lift.
http://www.bmwmotorsports.org/BMW_docs/m54x5.pdf
CAMSHAFT - The camshaft for the 3 liter M54 is modified with more lift (9.7 mm) and
new valve springs to accommodate the increased lift.
Join BMWCCA
Old 10-29-2010, 01:34 PM   #17
rmank
My Ride: 2000 323Ci
Good to know. 24 new valve springs adds to the cost a bit, if they fit at all. Definitely only worth it if DIY or cheap install. I'll have to keep gathering info.
Old 10-29-2010, 01:55 PM   #18
Iceman00
Banned User
My Ride: E90 6MT
You won't need valve springs.
Old 10-29-2010, 03:21 PM   #19
Mirko
My Ride: Your girlfriend :)
Great price with a high install cost otherwise I would be all over getting some zhp cams at that price. $300 is a steal! Sadly I am not Aggie or PEI so I doubt I could do the install
Mirko is offline   Reply With Quote
Old 01-07-2011, 12:46 PM   #20
SwapMag1c
My Ride: 2004 Z4 M54B30
Unhappy
Best,
Joe
hey, it's not 299 anymore!?
SwapMag1c is offline   Reply With Quote
