Old 04-30-2010, 10:28 AM   #1
jeffrey w
My Ride: 2001 325i
valve cover gasket
Hey guys..
Going to be changing out vcg here shortly. My q's are, my '01 325i has 98k miles on it. While I am into this project what else should I replace? Are there things that I should replace "no questions asked" and anything I need to look for when I'm into this for pre maintenance? Basically, just anything ELSE I should do. Thanks!
** Removed **
jeffrey w is offline   Reply With Quote
Old 04-30-2010, 10:43 AM   #2
BMWespresso
My Ride: 2005 325CI
Vanos is the only other you could, at 98K and 10 years if never done before, I would
BMWespresso is offline   Reply With Quote
Old 04-30-2010, 10:46 AM   #3
HighPod
My Ride: '00 white 323ci
i did mine yesterday. surprisingly easy to do with all the DIYs. did my spark plugs as well.
HighPod is offline   Reply With Quote
Old 04-30-2010, 12:52 PM   #4
325myAZ
My Ride: 2001 325i
Spark plugs are a great suggestion... otherwise, you're not really removing or accessing components that need repair.
VANOS could be an issue, but unless your hearing or experiencing a problem, you might just want to stick with the VCG.
325myAZ is offline   Reply With Quote
Old 04-30-2010, 07:56 PM   #5
York
My Ride: 01 330Ci
+1 for spark plugs.
330Ci
York is offline   Reply With Quote
Old 04-30-2010, 08:35 PM   #6
jeffrey w
My Ride: 2001 325i
thanks guys but I dont know what the hell is vanos..lol! I do everything myself when it comes to my bimmer but that term I never heard of
** Removed **
Old 04-30-2010, 09:46 PM   #7
blacksport325
My Ride: 98 M3, 318is, CBR600
While you have the cover off you can do the vanos seals from Beisan Systems. like others said, you are taking out the plugs so might as well swap those if you haven't in awhile. The Vanos seals seem to take a bit more time but its better to get it done while you have all the bolts out for the valve cover if you have the time and money.
blacksport325 is offline   Reply With Quote
Old 04-30-2010, 10:31 PM   #8
York
My Ride: 01 330Ci
Lots to read then!
http://forum.e46fanatics.com/showthread.php?t=700533
330Ci
Old 05-01-2010, 07:49 AM   #9
jeffrey w
My Ride: 2001 325i
thanks for the help on the Vanos. If I dont have that issue with the rattling noise, do I have to worry about replacing it? Or is it a part that wears out?
** Removed **
Old 05-01-2010, 09:06 AM   #10
blacksport325
It wears out over time, leading to sluggish performance usually in the low-end range, I think there's a few other symptoms too.
Old 05-01-2010, 09:18 AM   #11
York
My Ride: 01 330Ci
I just did my VGC a couple weeks ago (along with other maintenance items), but I didn't do the Vanos. I have the repair kit from Beisan Systems, but my car seems to run fine. I did read many posts that tell of a slow loss of perfermance over time and they didn't really notice until they did the Vanos repair. They said the car came alive, so I'll plan to do my Vanos in a few months since I have 100K miles.
330Ci
Old 05-01-2010, 10:24 PM   #12
Brilliant
My Ride: E46M3 Blk/Blk
AST 4100s, plates & s-RSMs | Eibach sways | OEM brace | CSL rack | CSL rotors & calipers w/ ST lines | Genuine CSLs w/ BBS caps
Euro headers & Euro cats | MILLTeK raspx | VAC pulleys | 3.91 M Gears | Z3 SSK
Infinity Kappa 5 amp, 50.9s, 60.9is | AC LC6i | CD53 retrofit w/ Aux | USASPEC ipod | OEM Sirius
OEM Euro folding mirrors | OEM LED retrofit & Euro LCM | V-CSL diffuser (fits like S) | misc cosmetics
Soon: CSL Intake
Brilliant is offline   Reply With Quote
replacing valve cover
