Old 04-30-2010, 03:19 PM   #1
B
OG Moderator Extraordinaire
B's Avatar
My Ride: 325iX-M3-525iT-M5
Send a message via AIM to B
Question Did you press CABs into your existing carriers? What's the P/N for just the bushing?
I can't find a P/N anywhere for just the rubber bushing but since I have a shop press I figured I would press new rubber into my existing carriers and call it a day.
For the record I checked:
realoem.com
ecstuning.com
fcpgroton.com
pelicanparts.com
autohausaz.com
I can find poly ones but not oem or equivalent rubber ones...
Thanks in advance!
B is offline   Reply With Quote
Old 04-30-2010, 03:20 PM   #2
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I've seen several threads of the carriers failing after being reused. I'd suggest just getting new assemblies.
Old 04-30-2010, 03:24 PM   #3
B
B's Avatar
hrmm maybe cause they are aluminum? we press bushings into the steel ones for e30s and e36 all day and all night
Old 04-30-2010, 03:26 PM   #4
aggieE46
Keep it clean
aggieE46's Avatar
Probably so. I guess they just get a little fatigued. I wouldn't chance it, though. Nice to save a buck, and normally I'd be all for it, but they're less than $100 shipped.
Old 04-30-2010, 04:25 PM   #5
nathancarter
My Ride: 02 330i
I don't think the rubber bushings are available separately from the carriers. The urethane bushings are available separately.
The threads about failed CAB lollipop housings make me pee my britches. Go find AdamBath's thread about the massive suspension and body damage that he sustained when his CAB lollipop broke, then go get new housings.
nathancarter is offline   Reply With Quote
Old 04-30-2010, 04:49 PM   #6
bustedse-r
My Ride: 2000 328i
Ordered many times from this place with no issues -
http://www.getcoolparts.com/item.wws?sku=BMW090095
bustedse-r is offline   Reply With Quote
Old 04-30-2010, 05:29 PM   #7
330I6SPD
My Ride: 2005 330I 6Spd.
Bavauto has the press in u'thane bushings, Part # : AD604, $ 38.95 ea.
330I6SPD is offline   Reply With Quote
