Thread Tools Search this Thread Rating: Thread Rating: 179 votes, 4.99 average. Display Modes
Old 05-01-2010, 09:34 PM   #1
tranceasia8
My Ride: 2003 325i , 03 R1
$5 Alternative for Lock beep
***Update for video clip and siren test!!***
Hey guys this is my first DIY so please dont burn me too bad lol.
Pics taken from my phone, ill get some better ones up soon.
I got the idea from the GodsSon lockbeep thread.
http://forum.e46fanatics.com/showthr...ight=lock+beep
This is just a more simplified process and is just for entertainment.
***UPDATE***
After speaking with a tech at the dealership. They confirm that this will only work with vehicles ARE programed to flash. It usually cost about $60 to have them do it.
Sorry for not putting that info out there sooner.
My vehicle is already programmed to flash the lights and the clown nose. If yours isnt programmed it can be done at the dealer.
List:
T-30 torx
Electronic buzzer- Radio Shack 90dB Piezo Pulse Model: 273-060
Time: 45 minutes easy DIY
Step one:
Remove the twist clips holding down the cover to the cabin air filter. Remove cover and filter.
Step two:
Remove (4) T-30 torx screws holding the filter tray and carefully separate the wire harness from the loom.
Step three:
Remove (2) torx screws holding the protective cover for the blend air box. There is one to the left side by the A/c charging port and the other by the DME.
Step four:
Locate pre-wired alarm siren plug. Usually taped to the left side.
Step five
Locate Black wire w/ Blue stripe far left, bottom hole.
Then locate Brown wire w/ Black stripe left upper hole.
Step six:
Pin the ground wire into the lower left hole.
Pin the positive wire into the upper left hole.
~~~ Test your key.
CAR SHOULD BEEP TWICE TO UNLOCK.
(NOTE) YOU MUST HOLD DOWN THE HOOD TRIGGER TO HEAR IT BEEP ONCE AND LOCK!
Step seven:
After deciding where you want to mount your buzzer mount it down with double-sided tape this is where I mounted mine.
** Switch for a bigger buzzer so that the sound is louder***
Step eight:
Put everything back together and enjoy.
if you got any questions please feel free to ask.
****Bonus!! Buzzer/ siren doubles as an alarm*******
work in progress.....
$5 Lock Beep DIY- http://forum.e46fanatics.com/showthread.php?t=761104
tranceasia8 is offline   Reply With Quote
Old 05-01-2010, 10:17 PM   #2
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Awesome DIY!!!!
Do you have a video clip of how the beep sound in terms of loudness?
delmarco is offline   Reply With Quote
Old 05-01-2010, 10:19 PM   #3
tranceasia8
Originally Posted by delmarco View Post
Awesome DIY!!!!
thanks, ill try to get a clip up tomorrow.
It can still be heard through the covers but just not as loud as the OEM alarm.
Old 05-01-2010, 10:26 PM   #4
eneka
My Ride: 2003 325i
nice. How does it sound? Does it sound like the one in the link you posted?
eneka is offline   Reply With Quote
Old 05-01-2010, 10:32 PM   #5
tranceasia8
yes it sounds just like that. Just easier to install lol
Old 05-02-2010, 02:26 AM   #6
Cazz
My Ride: 2005 BMW M3
Nice mod.
Put this in the "Free mods / cheap mods under $10 DIY" thread.
Cazz is offline   Reply With Quote
Old 05-02-2010, 02:33 AM   #7
miiikey31
My Ride: 00 BMW 323CI Coupe
thats cool imma try it on my car
miiikey31 is offline   Reply With Quote
Old 05-02-2010, 08:01 AM   #8
Mike@F1 AutohaŘs
Past Site Sponsor
My Ride: E46 330ci
Nice!
So what happens when the car goes off?
Mike@F1 AutohaŘs is offline   Reply With Quote
Old 05-02-2010, 08:52 AM   #9
Hartman
My Ride: 2000 323i
Wow I may give this a try
Hartman is offline   Reply With Quote
Old 05-02-2010, 12:57 PM   #10
Cazz
Here is a video I found of a radio shack buzzer on a different car.
Old 05-02-2010, 04:24 PM   #11
deadpass
My Ride: 01 330i
That sounds way better than I thought it would.
deadpass is offline   Reply With Quote
Old 05-02-2010, 07:38 PM   #12
tranceasia8
Originally Posted by Mike@F1 AutohaŘs View Post
Nice!
It will beep and stay on until your car is disarmed. Now if you opt to use a 2-tone or a pulsing siren it will go off just like any other alarm.
Both can be found at your local Radio Shack.
Thanks Cazz for posting the video clip. It sounds exactly like that
Old 05-02-2010, 08:32 PM   #13
shwagon
My Ride: 325it 5-speed
Best DIY of the year!!!! Huge thanks for looking in to this!!! In for vids btw...
Originally Posted by Reedo302 View Post
What an unending cavalcade of rampant virgin Mom's-basement-dwelling douchebaggery... Wow.
My Gun Builds: AR-15, GSG-522-SD, Saiga 308
shwagon is offline   Reply With Quote
Old 05-02-2010, 09:07 PM   #14
haurelio
My Ride: 2001 bmw 325i
whats the db level on the video?
Old 05-02-2010, 09:13 PM   #15
delmarco
Does this make the lights blink as well?
Old 05-02-2010, 09:23 PM   #16
Little Dragon
My Ride: E46s
No, you must program your lights to do so.
Hey OP, is the sound in sync with the flashing lights when it locks/unlocks?
My car is already programmed to flash and the clown nose flashes as well.
Little Dragon is offline   Reply With Quote
Old 05-02-2010, 09:29 PM   #17
bimmerman25
My Ride: 2003 330 ci
really cool diy ill prolly try it seeing as mine doesnt even make a noise lol
bimmerman25 is offline   Reply With Quote
Old 05-02-2010, 09:37 PM   #18
Cazz
Radio Shack says the buzzer in the video is 76 dB. I'm assuming that is before putting it inside of the engine compartment. They also have buzzers with higher dBs ( 80, 85, 90, 95 100, 108, etc.) and a 102 dB piezo siren (search on youtube for a video of this one on a Harley).
Old 05-02-2010, 09:46 PM   #19
tranceasia8
the beeps will be in sync with your lights if your vehicle is programed.
I ended up switching the smaller 50db buzzer in the pic out for a larger buzzer putting out 90db. Its pretty loud even when you mount it behind the covers.
Basically the mounting location will effect the sound, IMO anything over 70db should be loud enough to confirm that your vehicle is locked/ unlocked
Old 05-02-2010, 10:13 PM   #20
redice
My Ride: 06 M3 ZCP
very cool mod
redice is offline   Reply With Quote
