Thread Tools Search this Thread Rating: Thread Rating: 179 votes, 4.99 average. Display Modes
Old 04-20-2011, 02:27 PM   #181
gibby13
My Ride: 2001 BMW 325i
Anyone have a clue?????
I tried this DIY..... I recently had my lights activated and they DO flash with lock and unlock. Though i get no sound at all from my buzzer.
Suggestions?
(I think it may be a bad buzzer....anyone know the proper way to test a buzzer for correct operation)
gibby13 is offline   Reply With Quote
Old 04-20-2011, 03:13 PM   #182
love the 325ci
My Ride: black 2005 325ci
Works great, thanks for starting the thread
love the 325ci is offline   Reply With Quote
Old 04-27-2011, 01:33 PM   #183
sdbimmer
My Ride: 2004 325Ci
test with your battery
you can test out your siren by connecting the black wire (negative) to the body of the car and touch the red wire (positive) on your siren to the red Positive battery terminal. This will power on the siren and it will sound off. If you have a defective siren, then you will hear nothing.
If you want to test the connector to see if it is sending the power to the siren, you can hook up a volt meter to the two connection mentioned by the OP.
NOTE: if you want to test it, MAKE SURE THAT YOUR HOOD PIN IS PRESSED DOWN in your engine bay. Sometimes with the hook up/Pin up, the siren won't activate.
With your volt meter, you should be getting 6-12 volts spikes when you press lock on your keyfob and 2 spikes when you unlock.
Suggestions?
sdbimmer is offline   Reply With Quote
Old 04-30-2011, 02:04 PM   #184
xenon325i
My Ride: AWE46,AWE92xDrive
Does anyone know if there is a pre-wired siren harness inside the E9x hoods? I have a buzzer and was going to hook it up in my E46 but I can't find any body to activate light flash in my area. I also have an E92 that already has light flash and would like it to beep.
xenon325i is offline   Reply With Quote
Old 05-08-2011, 01:48 PM   #185
TORERO
My Ride: 2000 323i
My stealership wants $134 dollars to program my lights to flash... Does anyone know of a cheaper place here in San Diego?
TORERO is offline   Reply With Quote
Old 05-09-2011, 02:59 AM   #186
AznPhelo
My Ride: A Vespa
Euro Auto Spot can do it, it's about $50 to code. Give them a call
Euro Auto Spot
8680 Miralani Dr. ste 124
San Diego, CA, 92126
858-635-9063
9-6
located right off of MCAS Miramar.
BBS / GRUPPE M / STATUS GRUPPE / STACHé
AznPhelo is offline   Reply With Quote
Old 05-09-2011, 02:24 PM   #187
kasun
My Ride: 2001 E46 330ci
Im going to try this within the next 2 days. I just got my car programed to flash. it cost me $98
kasun is offline   Reply With Quote
Old 05-09-2011, 11:25 PM   #188
TORERO
My Ride: 2000 323i
Euro Auto Spot
858-635-9063
9-6
I'll give them a call. Thank you
Old 05-19-2011, 11:06 AM   #189
mletchworth
My Ride: 2003 325i, 2007 x3
Heading to radioshack in T minus 1 hour....
mletchworth is offline   Reply With Quote
Old 05-31-2011, 02:20 PM   #190
TheSaint
My Ride: '01 325i / '09 XRS
Awesome! That was super easy and super cheap.
Thanks so much for sharing
TheSaint is offline   Reply With Quote
Old 06-09-2011, 09:38 AM   #191
My1stBimmer17
My Ride: SlvrGry/Imola '05 M3
I did this DIY last night and it was super easy! Only reason it took me longer than 30 min is because I'm so meticulous about wire routing and mounting.
Definitely make sure you buy the loudest siren there (102db). Even that one is a little soft, especially compared to other OEM 'beepers.'
You also need to make sure the hood pin is getting depressed ALL THE WAY, otherwise the 'lock' beep will not sound. I rewired the siren twice thinking it was my own fault. I'd push the pin down and test it - no issues. I'd close the hood and test it - no beep! For some reason my hood isn't pushing the pin down enough, so I'm adding some time of rubber stopper to the hood where it makes contact to ensure that it fully depresses the pin.
Overall an awesome DIY for < $10!!!
My1stBimmer17 is offline   Reply With Quote
Old 06-09-2011, 08:53 PM   #192
Anferney
My Ride: 2003 330i ZHP
Where exactly is the alarm plug? I can't tell from the pics. Taped to the left side of where? A spines out pic showing the location would be great.
Sent from my PC36100 using Bimmer App
Anferney is offline   Reply With Quote
Old 06-18-2011, 02:15 AM   #193
reyes186
My Ride: e46
what about if i cut off the connector ?
reyes186 is offline   Reply With Quote
Old 06-18-2011, 06:41 PM   #194
mletchworth
That's what I did. Wanted a more secure connection, plus I'm never going to put an actual alarm in there.
Old 06-18-2011, 09:53 PM   #195
reyes186
My Ride: e46
That's what i wanted but now my car dnt want to unluck and luck the car with the control after i did that !! Do any one knows what could be wrong here pls help !!
Sent from my Vortex using Bimmer App
Old 06-25-2011, 05:14 AM   #196
King Kashi
My Ride: 06 BMW 330Ci M54 Eur
Originally Posted by Cazz View Post
Here is a video I found of a radio shack buzzer on a different car.
do u have the packaging of the buzzer ??? i want to do this to my car, haha n i also WORK @ RADIOSHACK ! thats the sound i been looking for
King Kashi is offline   Reply With Quote
Old 06-25-2011, 11:37 AM   #197
sweetcheeks1988
My Ride: 320 d
Tried this can't find cable at all must be going blind only see one cable and if that's the one gonna be a bitch to get to as being from Ireland everything on opposite side and not as easy to reach
sweetcheeks1988 is offline   Reply With Quote
Old 06-25-2011, 03:33 PM   #198
Cazz
My Ride: 2005 BMW M3
I video says 273-059. However, mounted inside the engine bay it is probably too soft.
Originally Posted by sweetcheeks1988 View Post
Tried this can't find cable at all must be going blind only see one cable and if that's the one gonna be a ***** to get to as being from Ireland everything on opposite side and not as easy to reach
It probably is on the other side on a RHD drive vehicle.
I found this pic of the siren mounting location and since it is on the other side, the cable should be as well:
Cazz is offline   Reply With Quote
Old 06-27-2011, 03:54 PM   #199
SaN NizZLe
My Ride: 2000 328Ci
SaN NizZLe is offline   Reply With Quote
Old 07-13-2011, 01:32 PM   #200
darksideracer69
My Ride: 01 325ci
Just wanted to stop by and say thanks to the person that did this, i finally got mine installed and i love it. I ended up using radio shacks 108db, which sound good.
On another note, i was thinking. Has anyone successfully wired up angel eyes like this? So that they blink with the signal lights when the car is unlocked and locked.
IMAG02051
