Old 09-01-2011, 12:15 AM   #221
TitanSilverE46
My Ride: 2001 318i & 325i
Originally Posted by Apple4life View Post
Maybe you car was not pre-wired for alarm?
Yes, that is probably the reason.
Cheers from down under.
TitanSilverE46 is offline   Reply With Quote
Old 09-03-2011, 09:11 AM   #222
Tw3ak3d
My Ride: 323it
I just did this mod, this morning. Super easy, super awesome! ( i opted for the DEI 514n Siren)
Tw3ak3d is offline   Reply With Quote
Old 09-03-2011, 09:40 AM   #223
darksideracer69
My Ride: 01 325ci
Video naaaooo!
Sent from my SGH-T959V using Bimmer
IMAG02051
Old 09-03-2011, 11:20 AM   #224
justin654
My Ride: 03 325xi
Originally Posted by darksideracer69 View Post
Video naaaooo!
Thisssssssss I need a louder siren. 102db doesnt cut it for me.
justin654 is offline   Reply With Quote
Old 09-03-2011, 11:36 AM   #225
gazfatha323i
E46 Spartan
My Ride: 04 CB/IR M3
Send a message via AIM to gazfatha323i
Just did this. It works, but on 86db its not that loud. I would mayber recommend the 102 if people can find it. I looked in the bins and 90db was the loudest i could find.
Carbon Black / IR ///M
gazfatha323i is offline   Reply With Quote
Old 09-03-2011, 11:42 AM   #226
darksideracer69
My Ride: 01 325ci
I was able to find the 110db but still not loud enough.
IMAG02051
Old 09-15-2011, 12:52 AM   #227
Stiggles
Stiggles's Avatar
My Ride: Was built Fri 13th
Are we able to hook up an actual siren to those wires without shorting anything out?
One like this is sitting in my basement unused:
Stiggles is offline   Reply With Quote
Old 09-25-2011, 03:26 PM   #228
Fuseryder
My Ride: 04 330i
Did this about 10 mins ago, here's some pics and I will post a vid of the sound later, very good DIY and cheap, costs about $6 hopefully you guys like this buzzer it is 102db
ID:	418487   Click image for larger version
ID:	418488   Click image for larger version
ID:	418489   Click image for larger version
Fuseryder is offline   Reply With Quote
Old 09-25-2011, 03:30 PM   #229
Fuseryder
My Ride: 04 330i
Vid as promised
Old 09-25-2011, 04:55 PM   #230
justin654
My Ride: 03 325xi
Originally Posted by Fuseryder View Post
Vid as promised
Sounds exactly like mine. Probably because it is the same one. Good video.
Old 09-25-2011, 05:23 PM   #231
darksideracer69
My Ride: 01 325ci
Should take video outside of the garage
IMAG02051
Old 09-27-2011, 02:19 PM   #232
jgold47
My Ride: 2004 X5 3.0
Did you wire this directly, or did you wire in a relay?
Also, anyone who has done this tried the intervalltone setting?
I
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 09-27-2011, 02:37 PM   #233
darksideracer69
My Ride: 01 325ci
I
What does that setting do?
IMAG02051
Old 09-27-2011, 02:49 PM   #234
jgold47
ok I am going to sumarize what I am looking for here, there are a lot of people subscribed, hopefully someone can help.
I have the OEM alarm, but the siren is wildly too quiet. I cant hear the chirps unless I am on top of my car. I would like to add an extra siren (a DEI one I have lying around), in addition to the OEM siren. I am making this over complicated a) because I can, and b) because I did something slighltly non-standard when I installed and activated my alarm.
In a normal alarm system, the siren is usually wired in a way that when it is 'triggered' either by alarm or by chirp, the connection is grounded, the circuit is made, and the alarm sounds. (negative trigger). the sound of the alarm is predicted soley on the wiring of the alarm. In this case, any 12v alarm siren can be used. horns, piezos, talkers, etc....Its a very simple basic circuit.
I am concerned that the feeds that everyone is tapping into are not a)drivable - meaning that they wont put out enough current to drive the siren and b) are not actually 12v +/- alarm triggers. I think they send a 'command' to the alarm module that it should trigger. the driver and the internal relays are part of the alarm module.
I think that because there is a setting burried in the car that allows you to switch to intervaltone (interval tone) for the alarm. it changes the siren to a european style tone. I have this enabled, its a riot.
I want to hook up the extra siren using a relay, and would use the two feeds everyone has used to drive the relay, but I dont understand how the signal coming from the car, going to the alarm module could be pure if the tone can be changed. since the GM5 controls the tone, I dont want to overdrive it and burn it out....
ive cross linked this post with the wiring diagram of the module.
http://forum.e46fanatics.com/showthr...=870745&page=2
Any thoughts? or are you all just as confused as me.
my about me link
Old 09-27-2011, 04:08 PM   #235
Tw3ak3d
My Ride: 323it
I
no, i did not use a relay. I wired it straight negative- positive.Im begining to think it's too loud. Im considering buying the chime that is used on lexus vehicles to tone it down a bit and keep it classy.
Old 10-01-2011, 07:20 PM   #236
muscam1
My Ride: BMW 2002 325i
Thanks to the OP for the DIY. I bought the 102db Piezo for under $6 and installed it in about 20 minutes.
It works perfectly!!!!
Note - my 325i already had the blinking clown nose and flashing parking lights activated.
Thanks again to everyone that contributed to this DIY thread - it made my decision to do it...and the job an easy one!
muscam1 is offline   Reply With Quote
Old 10-15-2011, 10:33 AM   #237
isaiahj95
My Ride: 2002 BMW 330i
I did it, but it doesn't work... i think i have to get it programmed which sucks!!!
isaiahj95 is offline   Reply With Quote
Old 10-15-2011, 10:37 AM   #238
SMUUUUUV
///Motorcepts ///Maintained
My Ride: '02 330 Vert #442
Thats the only way its going to work.
SMUUUUUV is offline   Reply With Quote
Old 11-17-2011, 07:00 PM   #239
calvinloc
My Ride: 330ci
Hi all, FYI : if you want to get your car programmed flash to work with this mod, I can do it for you guys. Just a lunch or donate is fine lol. I live in bay area, San Jose. So if you want just PM me.
calvinloc is offline   Reply With Quote
Old 01-03-2012, 11:56 AM   #240
Gengster
My Ride: 325 ci 2002
Smile
Originally Posted by tranceasia8 View Post
***Update for video clip and siren test!!***
Hey guys this is my first DIY so please dont burn me too bad lol.
Pics taken from my phone, ill get some better ones up soon.
I got the idea from the GodsSon lockbeep thread.
http://forum.e46fanatics.com/showthr...ight=lock+beep
This is just a more simplified process and is just for entertainment.
***UPDATE***
After speaking with a tech at the dealership. They confirm that this will only work with vehicles ARE programed to flash. It usually cost about $60 to have them do it.
Sorry for not putting that info out there sooner.
My vehicle is already programmed to flash the lights and the clown nose. If yours isnt programmed it can be done at the dealer.
List:
T-30 torx
Electronic buzzer- Radio Shack 90dB Piezo Pulse Model: 273-060
Time: 45 minutes easy DIY
Step one:
Remove the twist clips holding down the cover to the cabin air filter. Remove cover and filter.
Step two:
Remove (4) T-30 torx screws holding the filter tray and carefully separate the wire harness from the loom.
Step three:
Remove (2) torx screws holding the protective cover for the blend air box. There is one to the left side by the A/c charging port and the other by the DME.
Step four:
Locate pre-wired alarm siren plug. Usually taped to the left side.
Step five
Locate Black wire w/ Blue stripe far left, bottom hole.
Then locate Brown wire w/ Black stripe left upper hole.
Step six:
Pin the ground wire into the lower left hole.
Pin the positive wire into the upper left hole.
~~~ Test your key.
CAR SHOULD BEEP TWICE TO UNLOCK.
(NOTE) YOU MUST HOLD DOWN THE HOOD TRIGGER TO HEAR IT BEEP ONCE AND LOCK!
Step seven:
After deciding where you want to mount your buzzer mount it down with double-sided tape this is where I mounted mine.
** Switch for a bigger buzzer so that the sound is louder***
Step eight:
Put everything back together and enjoy.
if you got any questions please feel free to ask.
****Bonus!! Buzzer/ siren doubles as an alarm*******
That worked just great!!!
I just have one question what the other two wires are for??
Gengster is offline   Reply With Quote
