Thread Tools Search this Thread Rating: Thread Rating: 179 votes, 4.99 average. Display Modes
Old 05-03-2010, 01:24 PM   #21
bAby norAA
My Ride: 01 BMW 330i
i was just out doing this and it started to pour on me. so trying to do it quickly and i forgot to hold down the hood trigger so i thought mine wasnt working.
Gotta go back out when the rain subsides. great diy!
| VF Supercharged Stage 1.5| Southbend Stage 2 Clutch | ZHP Cams | Technik Headers |
bAby norAA is offline   Reply With Quote
Old 05-03-2010, 03:22 PM   #22
bAby norAA
I was wrong, it wasnt just my hood button. For some reason my car will not make the Radio Shack buzzer beep. I connected it the exact same way you did to no avail. Does the car need to be programmed to have the lights flash in order for this mod to work?
Old 05-03-2010, 08:57 PM   #23
The451Kid
My Ride: '01 325ci
I am curious too. My lights are not programmed to flash and I couldn't get it to work either.
The451Kid is offline   Reply With Quote
Old 05-03-2010, 09:00 PM   #24
leechieh
My Ride: 325i
Yes i believe that the factory alarm or parking light flash feature has to be enabled, this is what allows the signal to be sent to the siren.
leechieh is offline   Reply With Quote
Old 05-03-2010, 09:13 PM   #25
Hartman
My Ride: 2000 323i
I knew it was too good to be true.
Hartman is offline   Reply With Quote
Old 05-03-2010, 09:22 PM   #26
ianbiz
My Ride: E90
Send a message via AIM to ianbiz
i want to try this on my E90
Ian
ianbiz is offline   Reply With Quote
Old 05-03-2010, 09:34 PM   #27
tranceasia8
My Ride: 2003 325i , 03 R1
I really dont know if it is limited to vehicles that are programed. I can call BMW and try to track that down for you guys.
I had mine programed to flash the lights awhile back at the dealer for $60 and it took about 15 minutes for them to do it.
work in progress.....
$5 Lock Beep DIY- http://forum.e46fanatics.com/showthread.php?t=761104
tranceasia8 is offline   Reply With Quote
Old 05-03-2010, 10:06 PM   #28
l0stE46
My Ride: 2000 323i
Yo when I did it, the piezo buzzer stays on and doesn't stop. I tried switching the connections from one to the other connections. It also had a constant buzz. Does switching to a different buzzer work? Or do we have to get the activation from the dealership first?
++ Dinan CAI - ACS Type III Wheels - CCFL Angel Eyes - DICE - Clear Corners - Bilstein PSS9 Coilovers - Sports Package ++
l0stE46 is offline   Reply With Quote
Old 05-03-2010, 10:15 PM   #29
shwagon
My Ride: 325it 5-speed
did mine today, took all of 20min. I mounted my buzzer under the micro filter and my only complaint is that it could stand to be slightly louder, but ya cant beat $5
Originally Posted by Reedo302 View Post
What an unending cavalcade of rampant virgin Mom's-basement-dwelling douchebaggery... Wow.
My Gun Builds: AR-15, GSG-522-SD, Saiga 308
shwagon is offline   Reply With Quote
Old 05-03-2010, 11:08 PM   #30
tranceasia8
what kind p/n buzzer did you use?
Old 05-03-2010, 11:19 PM   #31
tranceasia8
Update...I was messing around with the buzzer today and decided to try 102dB Piezo Siren p/n 273-079
Check first post for quick video clip ^^^
Old 05-03-2010, 11:31 PM   #32
l0stE46
My Ride: 2000 323i
My buzzer is the 273-0060 model from radio shack.
3.0-28 VDC
Max current assumption of 5mA @ 12VDC
86dB min at 30cm/12VDC
resonant frequency: 3500 +_ 500Hz
It's an inch diameter with circles.
Looks like this:
http://www.radioshack.com/product/in...ductId=2062398
Old 05-03-2010, 11:35 PM   #33
l0stE46
My Ride: 2000 323i
Do you have the light flashing activated when you lock and unlock your car?
Old 05-03-2010, 11:37 PM   #34
tranceasia8
3.0-28 VDC
Looks like this:
That buzzer should work just fine as long as it doesnt need a driver circuit.
ill check w/ the dealer to see if vehicles need to be programed to be compatible.
Old 05-04-2010, 01:13 AM   #35
leechieh
My Ride: 325i
I did my install with a DEI 513T piezo, its about 120 db's and it is alot louder than the radioshak one, but it bumps the DIY up to about 12$
Old 05-04-2010, 01:34 AM   #36
smoke96
My Ride: 2004 325ci
could i possibly do this with a horn instead of a high-pitched beep? kinda like when a normal car is armed it would sound like the horn beeped.
[QUOTE=Back2Basics;11538236]So you're gonna have your food delivered to you while you sit at your computer screen on the 112th floor responding to questions about dildo's and sex lube's while strangers fill your bank account to acquire the tools needed for their sick, guilty pleasures?
That's pretty ****ing legit man.
smoke96 is offline   Reply With Quote
Old 05-04-2010, 02:31 PM   #37
shwagon
Yes, my car was programed to have the lights flash
I was thinking about this yesterday, in theory it should work but you would have to use a relay to control the ground circuit for the horn.
***NOTICE***
Also i noticed if I lock the doors and then open them from the inside or trigger the hood latch (simulating a break in), the buzzer would turn on and stay on until i hit the unlock button. This makes me think i can use a regular car alarm siren, this could actually work as a anti theft system!!!!
Old 05-04-2010, 07:48 PM   #38
nickpapa
My Ride: Z4
i like this idea. just wondering what would happen if it got wet?
nickpapa is offline   Reply With Quote
Old 05-04-2010, 09:11 PM   #39
haurelio
My Ride: 2001 bmw 325i
any success on those who's car is not programmed?
Old 05-04-2010, 10:47 PM   #40
tranceasia8
Thats pretty cool, I just stuck to what was at Radio Shack. To me $5-$15 is okay for messing around. OEM sirens can be found on Ebay around $90-100.
Yes bahnburnerit is correct on that. I can be used but if you dont have a relay then it will just stay on.
You final location of the buzzer should effect it. Most can operate from -5 to 120 degrees so i would think it would be fine if it stayed dry.
