Thread Tools Search this Thread Rating: Thread Rating: 179 votes, 4.99 average. Display Modes
Old 05-15-2010, 01:27 AM   #101
Cazz
My Ride: 2005 BMW M3
Originally Posted by Cowspoo View Post
Here's my side of the story.
When I lock my car, there's a light that blinks by the radio. The clown nose has never lit up. I plugged the red into the brown/black and the black into the black/blue. Nothing happened ( I held down the hood trigger).
Do your parking lights flash when you lock/unlock? If that option is enabled then usually the audible arm/disable is enabled.
The only combination for inputs that returns a sound are RED(from buzzer) into Input 1. Black into Input 2. That's a constant LOUD siren immidiately when connected
Your numbers and mine aren't the same, but those inputs sound like red to power (fused input) and black to ground (siren return), which just continuously drives the buzzer/siren.
Cazz is offline   Reply With Quote
Old 05-15-2010, 12:11 PM   #102
Cowspoo
My Ride: 328Ci
That's my connection. It looks like yours!
Parking lights? Meaning corners/tails/sidemarkers all blink when unlocking/locking? No
The only light is the red dot by the radio once locked.
spacebarissolazy
doesntfeelikebeingpressed
Cowspoo is offline   Reply With Quote
Old 05-15-2010, 11:47 PM   #103
yehm3
My Ride: 01 LSB M3
Just installed the 102dB piezo siren. Thanks for the DIY!!
yehm3 is offline   Reply With Quote
Old 05-16-2010, 04:23 AM   #104
Cowspoo
My Ride: 328Ci
Did your "parking lights" i'm assuming turn signals etc always blink when locking/unlocking your car?
spacebarissolazy
Old 05-16-2010, 01:00 PM   #105
sh00th00ps
My Ride: 2005 BMW 330i
does anybody else that bought the siren have the problem where it chirps but does not go off during a break in simulation?
sh00th00ps is offline   Reply With Quote
Old 05-18-2010, 12:20 PM   #106
Tate325xi
My Ride: 325xi 5MT
is this possible on an E90?
-Tate
Originally Posted by 217Bimmer View Post
sometimes i'm into it and my one hand gets tired, i try switching, but then it's like someone with lou gehrig's trying to peel a carrot.
Tate325xi is offline   Reply With Quote
Old 05-18-2010, 01:57 PM   #107
queezy1
My Ride: '04 BMW 325 SMG
You need to have the light blink upon arm programmed on. Just go to a local dealer...should be about $50
2004 325i SMG
Mods: BMW Performance Intake, Carbon Fiber Strut Bar, LED Angel Eyes, Xenesis Head/Fog Lights, Xexon Interiors, Clears all around, Matte Black Grille, M3 Trunk Lip Spoiler, Rear Tint, Black/White Roundels, Silver Trim/Knob, Silver Gauges/Rings, Aluminum Pedals, Alpine MP3 Changer, XM, GPS & Parrot Bluetooth all Hardwired, Alpine Speakers, Sub & Amps wired with Monster Connectors/Wires, Custom Sub Enclosure & Amp Rack
queezy1 is offline   Reply With Quote
Old 05-18-2010, 01:59 PM   #108
tom @ eas
european auto source
tom @ eas's Avatar
My Ride: e92 S/C M3
We can also code this in house.
tom @ eas is offline   Reply With Quote
Old 05-19-2010, 07:36 PM   #109
snitzl3
My Ride: e60 LCI
Send a message via AIM to snitzl3
EDIT:
Combination in OP doesn't produce the unlock/lock beep. In my trunk, it says i'm prewired for a security system too
Anyone have luck on a 2000 3series or know what i'm doing wrong?
just tried this, with the same results as you, except for me i only get a good sound when i have the red hooked into the top left and black hooked into bottom right which is a solid brown wire, once i hook those in its a constant chirp no matter doors locked or unlocked. One thing i did notice is when i plug in the wires like the diy says, and once i lock or unlock the door the buzzer chirps very very faintly, like its not getting enough power. So looks like i might need a relay of some sort....however im too lazy and put everything back together, will try it later if i feel like it
snitzl3 is offline   Reply With Quote
Old 05-20-2010, 12:00 PM   #110
Cowspoo
My Ride: 328Ci
Finally! Someone that shares my story.. Exact same with me. The other combination causes the faintest buzz. it seems like either the unlock or lock is twice as long as the other. maybe representing the two beeps. the buzz is similiar if i attach a battery to the buzzer. keep me updated!
spacebarissolazy
Old 05-20-2010, 03:27 PM   #111
mikeyh1015
My Ride: Bmw 04' 330ci coupe
Model?
Whats the Model # of the part? did you also get it at radio shack?
mikeyh1015 is offline   Reply With Quote
Old 05-23-2010, 01:24 AM   #112
snowcatxx87
My Ride: 04 330CI
There seems to be a lot of confusion regarding how the alarm
works.
Besides what the dealer tells you, it's not quite accurate.
When they program the indicators to flash when you lock and unlock, they activated half of your alarm.
They did not complete a retrofit, they turned on "DWA", which gives a fault code to your general module because it can't find the alarm components, but it makes the car flash during unlock and lock. It also sends a signal to the siren wire - the wire that you're using.
So - the reason why, when panic mode is used, no lights flash is because you don't have an "alarm"
Panic mode should have your highbeam flash and indicators with siren when you have a fully retro'd alarm
I myself like having a complete oem alarm, for safety and I mean you're drivin a BMW. Tilt/motion and with a small 10 dollar diy - shock sensor.
recap - you need to have DWA activated for this to work.
Hope this helps.
snowcatxx87 is offline   Reply With Quote
Old 05-27-2010, 06:17 PM   #113
NyBalla1014
My Ride: 2003 BMW 325i
Send a message via AIM to NyBalla1014
i just tried this and it beeps for everything other than locking the car. it beeps when i unlock the car and when i simulate a break in but it doesnt beep at all when i lock it.
does anyone have an idea of why this happens?
NyBalla1014 is offline   Reply With Quote
Old 05-27-2010, 08:30 PM   #114
Cazz
Usually that means something is open (door, hood, etc.). One of your pin sensors may be out.
Old 05-27-2010, 11:00 PM   #115
NyBalla1014
yep i figured it out..that was it lol thanks
Old 05-30-2010, 09:40 AM   #116
starscream.ro
My Ride: 320d 2000
Where exactly is the pre-wired alarm siren plug located? All E46 have it ? I can`t find mine... :|
starscream.ro is offline   Reply With Quote
Old 05-30-2010, 10:11 AM   #117
NyBalla1014
after you take the 2 cabin air filter pieces out, there should be a opening in the back of your engine bay. the plug should be taped up on the top left (passenger side) in there. i had to stick my arm pretty far in there to get it out.
if you still can't find it, stand back on the driver side of your car and look in there. u should be able to see it from there
Old 05-30-2010, 10:55 PM   #118
R1200RT
My Ride: 2004 330CIC
Did the DIY and it works great.
Thanks for compiling the procedure.
Nick
'04 330CIC, 3 pedals, M Sports\Aerodynamics Packages
'05 BMW R1200RT
'00 BMW R1100S
'04 BMW R1200C Montauk
'95 BMW R100R Classic
R1200RT is offline   Reply With Quote
Old 05-31-2010, 06:54 AM   #119
Adrian89
My Ride: BMW e46 325i Msport
i just have afew questions to ask atm my car does not blink apon locking or beep, i went to the dealership to see if they are about to program the car for visual confirmation of locking they can do it for $55.
My question is would i also need to get the alarm enabled even though i do not have a OEM alarm installed because i would like the siren to go off if i simulate a break-in? i just dont wanna go to the dealership twice to get my car programmed again.
My second question is how much current could be drawn from the connector under the cabin air filter? because i bought a 125db siren which draws 1.3amps just need to know if i should use a realy or not
thanks
Adrian89 is offline   Reply With Quote
Old 06-03-2010, 10:37 PM   #120
jsinclair_325ci
My Ride: 325ci
i wonder if the tilt and motion sensors will work if you activated an alarm with this cheap siren...i have the other two things, just need the siren
jsinclair_325ci is offline   Reply With Quote
