Old 04-11-2008, 05:23 PM   #1
kyle808
My Ride: 00 328CI
Is this the wheel speed sensor in this pic?
Is it Number 5 in this picture? Been getting DSC, ABS, and Brake combo.
"I'm gonna die! Jesus, Allah, Buddha - I love you all!
-Homer Simpson
kyle808 is offline   Reply With Quote
Old 04-11-2008, 05:35 PM   #2
EurosportAMG
My Ride: bm mb
yes #5
EurosportAMG is offline   Reply With Quote
Old 04-11-2008, 08:10 PM   #3
grafiksguy
My Ride: 2010 328xi
That's it. Good luck getting it out of the wheel housing. I wrestled with mine with a big adjustable pliers and finally gave up after getting it part way out and tapped it back in. I was afraid I'd just chew it up. If you come up with a good way to remove it, I'd love to hear it.
grafiksguy is offline   Reply With Quote
Old 04-11-2008, 08:31 PM   #4
DiceyOne
My Ride: 1999 328i
Send a message via AIM to DiceyOne
what is that part number? what main group and sub group is that under? i am also getting those warnings intermittently. thanks
DiceyOne is offline   Reply With Quote
Old 04-12-2008, 02:33 AM   #5
EurosportAMG
My Ride: bm mb
front axle->front axle suspension->front spring/strut shock absorber
Old 04-12-2008, 03:06 AM   #6
justdjames
My Ride: 3
mine came out pretty easy..I too get all those lights sometimes, anyone know why it comes on....when I turn car off and start it again , lights are gone ...3 weeks pass...then it starts again
Image Hosted by ImageShack.us
[IMG]Image Hosted by ImageShack.us[/IMG]
justdjames is offline   Reply With Quote
Old 04-12-2008, 10:58 AM   #7
DiceyOne
My Ride: 1999 328i
I'm sort of in the same boat except that mine is the rear passenger sensor. my warning lights (break,abs,asc) come and go but they used to be less frequent. my peake tool doesn't show a code when the lights are off but i can't say that i have run a scan when those lights are on.
when those lights are on does that mean that the ASC (DSC) and ABS are inactive? i don't drive very hard but i haven't noticed my wheels spinning out of control or that my breaking is worse.
from what I've read all this does is count a magnet that goes by... not much to go wrong so i wonder what the specific failure is; especially when it seems that most cases it is intermittent.
Old 06-30-2008, 10:33 AM   #8
Glory22
My Ride: 323ci
How many of these sensors are there? I have the ABS+DSC+Brake combo as well. Would like to know how to determine front/rear which sensor is at fault.
Also, how much is this part?
Glory22 is offline   Reply With Quote
Old 06-30-2008, 02:15 PM   #9
gwburke
My Ride: 1999 BMW 328i
There are 4 sensors, one on each wheel. They are something like $140 each to replace. I can't get mine out to check/clean them, so I'm living with the occassional lights.
gwburke is offline   Reply With Quote
Old 06-30-2008, 02:37 PM   #10
gwburke
How do you know which specific sensor is faulty? Does the Peake tool tell you? Why would you be getting a "brake" light? That light should only come on when your brake pads are below the minimum and set off the brake wear sensor.
When the ABS/ASC lights are on you do not have either ABS or traction control. I've been dealing with this for some time now. ON...OFF...ON...OFF...360' on the highway...
Old 06-30-2008, 03:08 PM   #11
EVLEUROe46
My Ride: 2002 330ci
I have the same problem its really annoying.
I do notice that when the lights come on the car goes into some backup mode where you hardly have any power. Its harder to shift and the traction control is disabled. I got some wheel spin one night when it was raining and these lights came on. They come on so regularly that im getting pretty good at turning the car off and back on while im still rolling.
Im gonna get the codes scanned tommorow when the lights are actually on in my dash and see what codes come up. Hopefully it will say which sensor is defective if thats even the problem at all.
EVLEUROe46 is offline   Reply With Quote
Old 06-30-2008, 04:28 PM   #12
gwburke
Please let me know if it tells you which sensor (if that's the problem) is faulty. I only get the ABS/ASC lights, some people seem to get the "brake" light (not the "brake wear sensor" light I mentioned above) as well. I would love to fix this annoyance. I tried to take my sensors out to check/clean them, but it was futile. I think the only way they're coming out is in pieces, and if that's the case I only intend to take the faulty one out.
Old 03-11-2009, 01:09 AM   #13
YOnpds
My Ride: E46
I know its an old thread, but were you able to fix the problem?
YOnpds is offline   Reply With Quote
Old 03-11-2009, 01:46 PM   #14
kyle808
My Ride: 00 328CI
I just left it and live with the problems. It goes on and off randomly. It doesn't affect anything major and the car drives fine. I didn't want to spend the money on buying new sensors. They're too expensive.
-Homer Simpson
Old 03-11-2009, 01:53 PM   #15
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Have you had the codes read there are alot more components to the ABS than just the speed sensors
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 03-11-2009, 02:04 PM   #16
kyle808
My Ride: 00 328CI
Do you need to have the codes read while the lights are on? It goes on and off at random, especially after I shut off the engine.
-Homer Simpson
Old 03-11-2009, 02:11 PM   #17
jbeurotech
Regional Sponsor
No codes are stored in non volatile memory and will be in the computer when they read them
Seth Thorson
Old 03-11-2009, 02:21 PM   #18
vitiokas95
My Ride: '01 M5 and '05 325Ci
I got all these lights on couple days ago, plus this morning speedometer stopped working.
vitiokas95 is offline   Reply With Quote
Old 04-20-2010, 09:40 PM   #19
03E40sick
My Ride: 2003 bmw 325ci
Send a message via Yahoo to 03E40sick
if the speedometer stopped working then its a bigeer problem than you think ...you need to change your abs module...which is really pricey ...i have changed mine before but on a e39 model and it was $750 and it was refirbushed part...look it up on ebay...bc the dealer wont fix it they will only sell you a new you
bimmers is the way to go........
03E40sick is offline   Reply With Quote
Old 04-20-2010, 09:55 PM   #20
Aaron90
My Ride: 328i
well even though this thread is over a year old, i totally disagree with this advice. I swapped 330i rear trailing arms into my 328i and had to drive around without the right rear sensor for a few days and my speedometer didn't work. Speedometer not working certainly doesn't mean it has to be a failed abs module.
Aaron90 is offline   Reply With Quote
