Old 05-03-2010, 07:22 PM   #1
Diazz
My Ride: Bmw 325Ci -01
Right side window does not move up/down - Coupé
Hello Guys.
I think im in the wrong place but i couldnt find any better.
I have a 325Ci, and the right side window, does not move up and down like it should when i open/close the door, sometimes it works, sometimes it get stuck on the outside when i close the door, sometimes it stays up when opening the door. Is there anyone here that has encountered this problem and has a solution i'd be mighty happy!
Thanks!
Diazz is offline   Reply With Quote
Old 05-03-2010, 08:05 PM   #2
York
My Ride: 01 330Ci
Last time this happened to me, from the driver's seat (not sure it matters) I rolled the window all the way down and then rolled it back up. After the window reached the top I continued to hold the switch for an extra 10-15 seconds. That did the trick for me. Now, when I open the door, the window goes down a quarter inch or so and when I close the door, it goes up to seal it tight.
Check post #17:
http://forum.e46fanatics.com/showthr...=#post11140108
330Ci
York is offline   Reply With Quote
Old 05-04-2010, 12:38 AM   #3
Diazz
Wow thanks for the tip. Fast and exactly what i needed, creds to you sir! Thank you again
Old 05-04-2010, 12:09 PM   #4
York
My Ride: 01 330Ci
Let us know if it works!
330Ci
Old 05-05-2010, 09:48 AM   #5
Diazz
Worked like a charm, maybe a "DIY" about this should be in the sticky?
