camber plates help with clearance, or do i need a roll? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 05-05-2010, 03:40 AM   #1
roastbeef
My Ride: 325ci
i just got a new setup running 235-35-19's on 8.5" rims. i'm also riding on h&r race springs.
the drop is perfect, and the car handles great, but when i take a hard, banked corner like a freeway offramp, i get a little rubbing at the top of the fender at the tire.
would camber plates tuck the edge of the tire better, or would a fender roll better take care of this issue?
roastbeef is offline   Reply With Quote
Old 05-06-2010, 12:08 AM   #2
roastbeef
My Ride: 325ci
nothing?
Old 05-06-2010, 01:47 AM   #3
mkodama
mkodama's Avatar
What's the wheel offset?
With the limited info, my guess you would need to roll the rear fenders. No point bothering with the front as stock E46 front fenders are "rolled" from the factory(from my experience).
Old 05-06-2010, 08:53 AM   #4
roastbeef
My Ride: 325ci
the rears tuck just fine, its the fronts that rub under heavy cornering.
unfortunately, i don't know the offset of these rims as i am the second owner, but they are 19x8.5's wrapped in 235-35's and they sit pretty flush.
the only place they seem to be rubbing is the top 6" of the fender lip. they never rub in level corners, only when taking a hard banked turn like a freeway offramp.
Old 05-06-2010, 12:34 PM   #5
azzy989
azzy989's Avatar
My Ride: 325i
Send a message via AIM to azzy989 Send a message via MSN to azzy989
what are your alignment specs right now in the front? yeah camber plates would be the only real way to tuck the top of the tire in more because you can't roll the front fenders. i wouldn't recommend going more than 2 degrees negative as you will start seeing some uneven wear in the tires.
-Azlan *I want to be like CD330*
azzy989 is offline   Reply With Quote
Old 05-06-2010, 03:30 PM   #6
mkodama
mkodama's Avatar
Well, if it is the fronts, then yeah, camber plates could help. But like azzy said, I'd suggest adding the minimum amount of negative camber you can to the stock alignment, assuming your stock alignment is correct. Add too much and you'll just be wearing out your tires a little quicker unless you change the toe-angle, but that's opening up a whole can of worms.
Old 05-06-2010, 05:40 PM   #7
roastbeef
My Ride: 325ci
looks like i'll be getting some plates. thanks guys.
Old 06-14-2010, 10:54 AM   #8
roastbeef
My Ride: 325ci
just fyi, if anyone is wondering...
i bought and installed camber plates from rogue engineering. the plates lift the front end about 1/8" (negligible) and gave me about -2.4* camber. this solved my slight rubbing issue i described in the original post. there is a noticeable improvement in cornering performance as well.
Old 06-15-2010, 01:26 AM   #9
mkodama
mkodama's Avatar
Do you have an alignment readout of your toe angle? Careful about that camber and change in ride height, as those small little differences could eat up your tires.
But good to know your problem is fixed.
Old 05-27-2011, 12:12 PM   #10
IrocThe325i
My Ride: is turning japanese
are your struts adjusted all the way out or all the way in or middle? pictures???
Sent from my DROIDX using Bimmer App
IrocThe325i is offline   Reply With Quote
