Old 05-06-2010, 09:56 AM   #1
spmx43
My Ride: 2002 325i
Replaced R-springs, ect. thanks fanatics
Yesterday: Any advice on changing out r-springs on my 2002 325i ? (broken)
Going to borrow a spring compression tool from a friend.
Read on suspention forum that them might slip out ? Hummm
*** Many thanks guys, finished the job in 2 hours ***
Replace 2 broken r-springs, frozen-stuck caliper and pads.
bleed side w/new caliper, Done.
1 spring (left) broke on the top and bottom.
Also thanks to my neighbor for the help w/the springs.
spmx43 is offline   Reply With Quote
Old 05-06-2010, 12:30 PM   #2
Lestat_
My Ride: E46 318ci M-Sport
it's a 10 min. job, no need for compressor. Take the shock bolt out and use a prybar to push down on the spring carrier.
Lestat_ is offline   Reply With Quote
Old 05-06-2010, 01:47 PM   #3
uninc4709
My Ride: 2002 BMW 325i 5spd
true words, did mine when i bought my car, just take off wheel and disconnect lower shock mount and the arm drops and you can just put your body weight on it and pull out the spring! good luck
^^ more than likely a useless post
uninc4709 is offline   Reply With Quote
Old 05-06-2010, 01:51 PM   #4
smoke96
My Ride: 2004 325ci
both above statements are correct. then use another jack to jack the spring into place so you can reconnect the shock.
[QUOTE=Back2Basics;11538236]So you're gonna have your food delivered to you while you sit at your computer screen on the 112th floor responding to questions about dildo's and sex lube's while strangers fill your bank account to acquire the tools needed for their sick, guilty pleasures?
That's pretty ****ing legit man.
smoke96 is offline   Reply With Quote
Old 05-06-2010, 02:59 PM   #5
FKxit
My Ride: 2003 325xit
Trying to do the same thing today. Is there a torque spec on the strut bolts? Thanks!
FKxit is offline   Reply With Quote
Old 05-06-2010, 08:32 PM   #6
spmx43
My Ride: 2002 325i
Spring
Thanks for the info,
Doing rear caliper swap and brakes also.
Got used springs and re-built calipers
Fun weekend 4 me.
Old 05-07-2010, 11:56 AM   #7
spmx43
My Ride: 2002 325i
I don't know the torque, they are on very tight. Had to use a pry-bar and socket. Just wrench them down good.
good luck, oh, have a friend there to get the spring in. No way to do it alone.
