Old 05-06-2010, 02:22 PM   #1
HellRaiser1
My Ride: 2004 M3
Too Soon to replace fuel filter?
I just replaced my fuel filter during my last tune-up on 8/09, about 15,000 miles ago.
However, there have been times where I've taken my car until the "low fuel" light pops up (i know, i shouldn't do that)....and I figure I'll be tinkering around there anyways...
Will it be a waste of money being that the filter will probably be clean?
Or should I do it as a precaution, better to do it than not to do it, can't hurt?
THANKS
HellRaiser1 is offline   Reply With Quote
Old 05-06-2010, 02:42 PM   #2
KhanArt
My Ride: 04 M3 JB/Cinn
I would also like to know when is it recommended to change your fuel filter...not the early stuff the stealership tells you but around how many miles you should really change your fuel filter.
2004 Jet Black/Cinnamon 6spd ///M3
Build///Journal
Tuning Tech Frank Smith /// Custom Performance Innovations /// Active Autowerke
IG: Khan_Art_
KhanArt is offline   Reply With Quote
Old 05-06-2010, 02:50 PM   #3
3Dirty
My Ride: 2008 Nissan Maxima
well.. I have 150k on mine, and haven't replaced it .. car runs like a champ though ...lol .. I have a new one sitting in a box though ..
I Influence How Others Drive Around Me..
3Dirty is offline   Reply With Quote
Old 05-06-2010, 03:27 PM   #4
Tangent_
My Ride: '01 330i, '11 Z435i
I really wish the myth that running to near empty makes your fuel pump suck up dirt you wouldn't otherwise would just die already... There's absolutely no real reason to not run the car to near empty. You won't suck up any more dirt or debris running it down because your fuel pickup is always at the bottom of the tank where any dirt would settle anyway. Any gas station outside the third world should be filtering the fuel they dispense so you don't get much dirt even in to your tank. And no, your fuel pump is not cooled by the gas it's submerged in, it's cooled by the fuel it pumps through itself. So unless the pump is sucking air, it won't run too hot.
My car's at 150,000 miles and I always run the gas down 'til near empty. It's pretty rare that I have a fill-up of less than 15 gallons. My fuel pump works as well as ever, and when I replaced the filter at about 140,000 miles preventatively, the gas that drained out of it was still nice and clean.
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 05-06-2010, 03:29 PM   #5
mvrk10256
My Ride: E30 325i
i swapped mine at 90K. i figure its just part of maintenance. so i would say every 60K orso is good.
Old 05-06-2010, 03:32 PM   #6
325adam
My Ride: 02 330i
I changed mine out at 65K and the fuel that came out of the filter wasn't dirty at all.
325adam is offline   Reply With Quote
Old 05-06-2010, 03:36 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Tangent, I changed my filter at 90k and it was BLACK.
Old 05-06-2010, 04:15 PM   #8
willsbma
My Ride: 99 323i
I opened the tank of a 89 ford bronco and it looked brand new. I think this whole fuel filter thing is a joke. Unless someone deliberately contaminates your tank you'll be fine. Here ya go: Does anyone have a pic of one they changed that was clogged? If there is one out there, I haven't seen it
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 05-06-2010, 04:24 PM   #9
VECTOR
My Ride: 2004 330CI auto vert
Lightbulb
I cannot speak for BMW's, but my last fuel filter on my Suburban was black and full of crap at 80k. I did have a tendency to run it till it got down near empty, but I'm not sure it had anything to do with it. So while I do not have a picture of the filter and the black gas that came out of it, rest assured it did at least happen to me.
VECTOR is offline   Reply With Quote
Old 05-06-2010, 06:16 PM   #10
325adam
My Ride: 02 330i
I think Solidjake posted his fuel filter and it was really dirty. That is the only one I have seen.
Old 05-06-2010, 06:30 PM   #11
Solidjake
Zero. Leaks.
Solidjake's Avatar
Old 05-06-2010, 06:33 PM   #12
Toad21
My Ride: 00' 328CI
Um, you are wrong sir. Running the FUEL PUMP on emtpy will destroy it, just as running any fluid pump with just air.
Don't beleive me? Try running until completely empty and then flooring it alot extra for a few minutes.
This does not effect the Fuel Filter however, so that is a myth. However it will destroy your fuel pump.
Toad21 is offline   Reply With Quote
Old 05-06-2010, 07:40 PM   #13
Tangent_
Time to change which gas stations you use. I had an even worse experience with a parts truck I used to drive years ago. The filter had to be changed every 10,000 miles or so and was filthy from the crap pumped out of the tanks of the Chevron i had to fill it at.
Umm, you might want to re-read my post. Allow me to highlight relevant portions for you:
Old 05-06-2010, 08:56 PM   #14
My325XI
My Ride: 03 325XI Sprt Prem
Recommended every Inspection II, approx every 60K. I'm sure it wont hurt but their not the cheapest things either to be replacing every 15K.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 05-07-2010, 12:53 AM   #15
TallTravel
My Ride: E46/2
My 01 330ci has 165,000 on the fuel filter, which is the original.
I am going to replace it soon, just because I figure it can't last forever, but it has thus far shown no real signs of failing.
TallTravel is offline   Reply With Quote
