Motorsports & Track Forum by BimmerWorld
From Auto-X to Trackday to Racing and Professional Motorsports – this is the place to discuss making BMWs fast Sponsored by BimmerWorld |
#1 |
H&R rear sway bar help
Ok just a small question- didn't want to post in the general section.
I bought a used rear H&R non-m sway bar for the xi. Upon closer inspection, it looks like i got 20mm OEM BMW rear sway bar bushings, instead of the 21mm bushings that come with the H&R bar new. Can I use the 20mm bushings on a 21mm bar? Or is that a complete no-go? Is it safe to shave 1/2mm from the inside diameter of the bushings? If not, should I go with the 21.5mm M3 bushings? Thanks guys- I have no experience with sways and I was hoping to get them on tomorrow because I'll have a nice place to test the new setup on Sunday. Otherwise I guess I'll have to order new bushings from H&R. |
#2 |
Dumb question? Anyone care to speculate?
#3 |
I don't think going 21.5 on a 21 bar is a good idea. making the 20s fit the 21 should be fine however it all depends on what you're doing with the car. Track, I wouldn't risk it. Street not much that can go wrong.
'04 330i ZHP - OEM Clears - ///M Strut bar - CoolantSnitch
#4 |
Thanks. I'm either going to tape up the bar and use 21.5mm, or shave the 20mm bushings until I can get my hands on some 21mm bushings.
#5 |
The torsional forces on the bar a pretty strong, I bet that tape will fall apart in less than a year.
#6 |
Cool, I shaved them down a bit- seems to be working ok.
