Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 09-03-2013, 12:03 PM   #22181
Zell
Zell's Avatar
My Ride: so turbo wow
Originally Posted by Mango View Post
whats it in the shop for
One of my caliper bracket bolts is stripped to all getout from some serious seizing, so I can't do my front brakes. Even extractor sockets weren't working. I don't have the clearance of a lift or more powerful tools to get it out, so I asked a shop nearby if they would be able to extract it. They sounded unconcerned about the job.
Gave them two new bolts to put back in. Hoping it won't cost much.
Really PO'd about it because it's such a stupid issue.
Old 09-03-2013, 07:37 PM   #22182
David McMahon
My Ride: '99 E38 740iL
Put me front and rear bumper trims back on today, waiting on clips to do the sides. Not entirely happy with them, so will get a proper paint and clear coat soon(ish) they look better than before at least.
David McMahon is offline   Reply With Quote
Old 09-03-2013, 08:11 PM   #22183
skylane5sp
My Ride: 2002 330i 5sp
Originally Posted by dHOFFs View Post
Got a 20% tint all around and washed it!
Don't you just love those wheels? Takes me longer to clean the wheels than the rest of the car... What kind of "tool" do you use on them. I found a champagne flute brush at a local hardware store that works pretty well.
skylane5sp is offline   Reply With Quote
Old 09-03-2013, 08:20 PM   #22184
ANREC330
My Ride: C6 Vette & M3
* What did you do to/for your E46 today? *
Got some pictures taken.
ID:	524892Click image for larger version
ID:	524893Click image for larger version
ANREC330 is offline   Reply With Quote
Old 09-03-2013, 08:21 PM   #22185
boatshoe
My Ride: 330xi
^that last one's phr$h
boatshoe is offline   Reply With Quote
Old 09-03-2013, 08:40 PM   #22186
sjacoby112
My Ride: 2002 325ci
+1 agreed
2002 325ci | 5MT | SGM/AGM | Varrstoen | RoyalStance | Form Flow & Fitment | Flipzco
sjacoby112 is offline   Reply With Quote
Old 09-03-2013, 09:54 PM   #22187
001
My Ride: 01 330ci
Nice pics ^^
I got some PM parts
001 is offline   Reply With Quote
Old 09-03-2013, 10:00 PM   #22188
Guest021715
Account closed.
Originally Posted by 001 View Post
Nice pics ^^
I got some PM parts
Where did you order from?
Old 09-03-2013, 10:10 PM   #22189
001
My Ride: 01 330ci
I just threw them into the same box, but i bought from:
BMA(fuel pump, thermostat, zimmerman rotors, expansion tank)
Pelican (waterpump, belts, intake boots, fuel filter, air filters)
Amazon (o2 sensors, brake pads) and Discounttiredirect.
Old 09-03-2013, 10:45 PM   #22190
trentcdrums
My Ride: BMW 323i Sedan
Happened to me with my lug bolt. Thank god for flatheads and Hammers. Always could be worse man!
Old 09-03-2013, 10:58 PM   #22191
brandonwish
My Ride: 02 325i 5MT
Spark plugs
|||2002 325i 5MT|||
brandonwish is offline   Reply With Quote
Old 09-03-2013, 11:02 PM   #22192
Zell
Zell's Avatar
Shop was able to get them out just fine. They were able to get a lot more leverage than I could and smashed a smaller extractor socket onto it...which is what I was struggling to do given my clearance. Came right on out!
Those front caliper carrier bolts are very soft, and can really deform easily - plus they're torqued at almost the same spec as our wheel bolts. Now that I see how easily they can round, I only use a 6-point socket and a massive breaker bar to remove them
Old 09-03-2013, 11:49 PM   #22193
CK325
My Ride: 323Ci, 325xi
half the parts came in for maintenance which is gonna include replacing the oil separator valve and hoses, spark plugs, oil&fuel filters, throttle body gasket, and some other minor things.
Planning to bleed my brakes and install the stainless steel brake lines at the same time as well...or I might just wait until I get new calipers/rotors. We'll see. Gonna be a busy weekend!
CK325 is offline   Reply With Quote
Old 09-03-2013, 11:50 PM   #22194
CK325
Old 09-04-2013, 07:36 AM   #22195
frongm
My Ride: 2002 330Ci
lots of cutting grinding and drilling in order to get the oem exhaust off.. engine and tranny mounts, tranny fluid, new to me magnaflow exhaust going on today if I can find some time.
frongm is offline   Reply With Quote
Old 09-04-2013, 11:39 AM   #22196
qthegenius
My Ride: E36 M3, E46 323i
Replaced the Camshaft Position Sensor, Intake side. Car runs better already!
qthegenius is offline   Reply With Quote
Old 09-04-2013, 12:05 PM   #22197
Ft1219
My Ride: BMW?
Supersprint rear muffler section, 2nd res delete. Sounds amazing!
Hellrot/ 3.64 LSD/ MTech II/ Schrick Cams/ Bimmerbrakes Headers/ Highline Tuning Exhaust/ Active Autowerke Software/ TMS Pulleys/ BMW SSK/ Powerflex bushings/ DNA Rear Adjustable Control Arms/ BBS LM Wheels/ Apex Studs/ Bilstein pss9 coils/ UUC Mounts/ Sparco Seats/ Macht Schnell Brackets/ Project kics Lug Nuts/ Pirelli P Zero
Ft1219 is offline   Reply With Quote
Old 09-04-2013, 03:06 PM   #22198
SLVRgrau
My Ride: 330 Ci '05 ZHP
Installed new cross drilled rotors, new brake pads, lower control arms, bushings and upper strut mounts...She is riding lovely now!
SLVRgrau is offline   Reply With Quote
Old 09-04-2013, 04:24 PM   #22199
BigDov
My Ride: 2002 330i
Ordered front control arms, bushings and hardware to replace the worn units, and a couple of other small parts that aren't worth mentioning
BigDov is offline   Reply With Quote
Old 09-04-2013, 10:02 PM   #22200
E46_Freak32194
My Ride: 2000 BMW 323i
Painted side moldings
today i painted my door moldings the same color as the car. To me it makes the car look much cleaner in a sense.
here's a before and after
ID:	525100   Click image for larger version
E46_Freak32194 is offline   Reply With Quote
Rate This Thread
