DAILY E46 MOD/REPAIR UPDATES - What have you done? - Page 1153 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 10-19-2013, 08:36 AM   #23041
pauly99
My Ride: 2002 325i
Degreased engine. I believe I may have an oil filter housing gasket leak.Sprayed the MAF sensor while I had a few things apart.
pauly99 is offline   Reply With Quote
Old 10-19-2013, 02:06 PM   #23042
MattVa
My Ride: 325ci 330ci
Lighting Upgrades
Upgraded Lighting Today
LED Tail Lights
HID Projectors w/Angel Eyes
Next Upgrade Fog Lamps
02 BMW 325Ci 5spd x2
01 Bmw 330Ci 5spd
99 Camaro Z28 1LE
95 Mustang Cobra Dart 363 18psi Vortech
99 Corvette FRC
01 Superformance Cobra
Ultima Can-Am 355 G50/50 Yellow
Ultima Can-Am 350 G50/50 Orange
MattVa is offline   Reply With Quote
Old 10-19-2013, 02:15 PM   #23043
Ft1219
My Ride: BMW?
New VMRs
Hellrot/ 3.64 LSD/ MTech II/ Schrick Cams/ Bimmerbrakes Headers/ Highline Tuning Exhaust/ Active Autowerke Software/ TMS Pulleys/ BMW SSK/ Powerflex bushings/ DNA Rear Adjustable Control Arms/ BBS LM Wheels/ Apex Studs/ Bilstein pss9 coils/ UUC Mounts/ Sparco Seats/ Macht Schnell Brackets/ Project kics Lug Nuts/ Pirelli P Zero
Ft1219 is offline   Reply With Quote
Old 10-19-2013, 03:08 PM   #23044
engineear
My Ride: 2001325i
Took a peek under the engine bay. Not a single hint of oil and any other fluids. No leaks
So, I order some hoses, pulleys, tensioners, water pump, coolant, power steering bottle etc....and proceed to upgrade the cooling system per Mango and others. I found the hose that had split with age and replaced it fairly easily. The others, well, read on. While I was under the car wiping up the previous coolant spray, I noticed what appeared to be an oil leak. Oily all underneath back to the tranny pan. This was very frustrating as I had recently done all the gaskets and thought it was tight and complete. What it turns out to be was the power steering hoses. Hold that thought.
Taking off the coolant hoses are, for the most part, very simple. But trying to put back on can be awfully time consuming. Glad my big brother was here to help. You may want to "grease" the fitting before the attempt is made to slide the hose on. The other issue, which I haven't seen anyone comment on, was taking the ET off. What a pain in the patoot THAT was! With all hoses removed it just sits in a fitting with no clamps holding it in. It's set in place with o-rings and suction. You must wrestle with this tank to get it out and my bro and I tag-teamed this sucker and won as it finally succumbed to our grunts and yelling at it...no police were called by the neighbors. Also, putting that top hose from the thermostat to the ET was a royal pain to put on...sprayed some silicone on the edges and as I pushed the radiator he pulled the hose on...PITA!
Flushed the system with distilled water then filled with the "cool blue" beverage, bleed and watch for a few days and all is normal again..."for another 100,000 miles"!
So, I have to go to the dealer for PS hoses and I replaced the ET also as there was an ever so small chip out of the small orifice that the thermostat hose fits over...better safe than sorry someone keeps saying around here.
The top PS hose that fits in the top of the radiator has a "push/pull" type metal fitting that was a bit of a skank to remove but we prevailed. There is a bottom hose that is kept in place with clamps, top and bottom that had to be razor cut to remove. The PS bottle was replaced and the fluid looked like brown, burnt oil that when leaked and slung over the bottom of the car appeared to look like oil. It is red once again.
After wiping off the bottom of the car AGAIN, all looks as clean as Jakes. And staying that way I might add.
engineear is offline   Reply With Quote
Old 10-19-2013, 05:28 PM   #23045
tks
My Ride: slower than yours
* What did you do to/for your E46 today? *
oil pan gasket and oil level sensor
pretty sure i just automatically rejuvinated 10 horsepower back into my car!
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 10-19-2013, 06:08 PM   #23046
olivierE46M3
My Ride: E46 M3 2003
Shower time!!!Click image for larger version
olivierE46M3 is offline   Reply With Quote
Old 10-19-2013, 11:26 PM   #23047
trj
My Ride: 325Ci
Front wheel bearings done.
Most difficult part was to get the dust boot behind the bearing. Was frozen with rust, had to sacrifice a screw driver on it.
Old 10-20-2013, 01:00 AM   #23048
Guest021715
Account closed.
Curious, what warranted your front wheel bearings to be changed?
I have a front end squeal and vibration, but I'm not sure its the rotors (OE, all factory original)
Old 10-20-2013, 02:40 AM   #23049
Nick_M3
My Ride: 2005 325ci
Changed the thermostat on my 05 325ci. Been stuck open and now with the cooler weather car wasn't warming up. Much easier than I anticipated took 30 minutes start to finish. Happy car. Bring it old man winter. Also gave him a good wash. Over the next week I will be changing the air filter& cabin air filter, oil, airbag light reset, lcm swap, passenger headlight leak, replacing control arm bushings. Click image for larger version
Nick_M3 is offline   Reply With Quote
Old 10-20-2013, 07:58 AM   #23050
BlazingWildBill
My Ride: Ferg 328Ci
Re: * What did you do to/for your E46 today? *
I replaced my Camshaft Positioning Sensor (intake near oil filter housing) and it made a WORLD of a difference. I didn't really notice it being laggy or not-so-peppy, but once I replaced it I feel like I'm in a new car. Accelerates much quicker with a lot more throttle responsiveness.
Sent from my SAMSUNG-SGH-I337 using BimmerApp mobile app
Post Count:666Sig thanks to Big Rick
BlazingWildBill is offline   Reply With Quote
Old 10-20-2013, 08:27 AM   #23051
THECLEANERBEAMER
My Ride: 2002 325i
Originally Posted by Ft1219 View Post
New VMRs
Those aren't VMR's?
Instagram:thecleanerbeamer
THECLEANERBEAMER is offline   Reply With Quote
Old 10-20-2013, 10:32 AM   #23052
trj
My Ride: 325Ci
I had a little play on the wheel and also some grinding noise at slow speeds.
Changing the bearings reduced the noise greatly but still have some rotational noise. May be my rotors are warped. Have to replace the brakes soon, I will change the rotors once the pads get too low.
Old 10-20-2013, 12:01 PM   #23053
Ft1219
My Ride: BMW?
Originally Posted by THECLEANERBEAMER View Post
Those aren't VMR's?
I bought them new locally, he said VMR, I asked again and they are XXR. My fault for not doing the proper research before posting!
Old 10-20-2013, 12:11 PM   #23054
Knight
My Ride: '05 330Ci | '01 325i
Oil change, fuel system cleaner and washed my wheels.
Knight is offline   Reply With Quote
Old 10-20-2013, 12:15 PM   #23055
olivierE46M3
What did you use for fuel system cleaner?
Sent from my GT-P7510 using BimmerApp mobile app
Old 10-20-2013, 12:50 PM   #23056
Ft1219
My Ride: BMW?
Made my own diff bushing press tool. Works flawlessly. Cost $11 at hardware store. Use really deep washers as a receiver to remove the bushing, and the flat washers to press them in.
Old 10-20-2013, 12:52 PM   #23057
Ft1219
My Ride: BMW?
Here it is
Old 10-20-2013, 12:55 PM   #23058
Guest021715
Account closed.
Installed a 35w 6000k HID kit, complete with relay wiring harness. Even insulated the +12v coming from the jumper connection.
Surprisingly sharp cut-off and very similar light dissipation compared to old Nokya 2500k's... although much, much brighter
On November's menu:
I have a spare non-sport prefacelift bumper with some paint damage, from when that pesky street sign ran out in front of me. I don't expect to sell it, and I can't bare to throw it away. So I decided to have fun with it and practice my vinyl wrapping skills.
A preview of what's to come:
Old 10-20-2013, 12:56 PM   #23059
stevenluczynski
My Ride: Is Steel Blue
stevenluczynski is offline   Reply With Quote
Old 10-20-2013, 01:23 PM   #23060
bostonsthename
My Ride: 2003 Jet Black 330xi
Expansion Tank Cap by G.A.S.
So Saturday I decided to replace my Idler Pulley and change my oil which I've been putting off for about two weeks now. I changed the oil with the BMW Synthetic 5w-30 instead of my usual Mobil 1 0w-40. Replaced the Idler Pulley and all was fine. I had also replaced the alternator belt about a month ago with a new one from NAPA.
Last night I was driving on the highway doing about 65 and all of a sudden my alternator light came on, I lost power steering, and then the temperature went up to the red and I coasted off the highway and into a parking lot because it just happened to work out for me, probably traveled a distance of about 1/2 mile. Belt had snapped but it was cold and rainy so I didn't bother checking last night.
This morning I go and the belt snapped, and my hydraulic tensioner roller had cracked. I also noticed that coolant had sprayed a little and the cap on the tank was leaking. I had just bought the G.A.S. Expansion tank cap so that a catastrophic explosion of coolant doesn't occur if the tank cracks. So luckily I still have the original tank cap and put that on and now no leaking and everything is running fine.
I'm wondering, is this a sign that the tank needs to be replaced or do you think the cap is just faulty and the cold and sudden hot just shocked the roller and cracked it? or did they just happen to go at the same time?
bostonsthename is offline   Reply With Quote
Rate This Thread
