Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 05-19-2011, 12:56 PM   #2781
Stickbuilder
My Ride: Touring, and others
2 new pre cat oxygen sensors, and cleaned the AMM sensor. 68,000 miles but 11 years old, with many heat cycles.
[/SIGPIC]I'm fluent in 3 languages:
English
Sarcasm
Profanity
Stickbuilder is offline   Reply With Quote
Old 05-19-2011, 01:18 PM   #2782
benzedid
My Ride: 2001 BMW E46 318i
checked all fluids
benzedid is offline   Reply With Quote
Old 05-19-2011, 02:07 PM   #2783
323I00
My Ride: E46 323I
Broke the fakin clips on the door moldings and had to drive to the stealership and purchase 8 of them , 4 for now and 4 more for the fut..
I did pay garage price , 1.45 each as compared to 5 dollars and some thing each...
323I00 is offline   Reply With Quote
Old 05-19-2011, 02:20 PM   #2784
JZambrano7
My Ride: 2003 325xi
Finally got to installing my new wheels style 119, i know it needs a drop but thatll come with time. I've been taking things step by step. The wheels make a huge difference tho and for now i'm very satisfied.
-JZ7-
JZambrano7 is offline   Reply With Quote
Old 05-19-2011, 02:54 PM   #2785
spencers
My Ride: 2006 330i
^ Definitely! Love those Style 119's
spencers is offline   Reply With Quote
Old 05-19-2011, 05:46 PM   #2786
JZambrano7
My Ride: 2003 325xi
thanks bro, yeah i can't help but smile when i look at my car.
Just washed her btw
Uploaded with ImageShack.us
-JZ7-
Old 05-19-2011, 09:01 PM   #2787
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Finally did the electric fan swap
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 05-20-2011, 12:14 AM   #2788
sellsellsell2000
My Ride: E46 seden
Send a message via AIM to sellsellsell2000
5/19/2011
Replaced AC belt and (Serpentine Belt for UUC Pulley).
AC Belt - Part no. 11-28-1-437-450-M21 (Pelican Parts)
UUC Pulley Belt - Part no. K060630 (Kragen) ~ Brand: MastePro
13/16" X 63 5/8" OC
20mm X 1616mm OC
or Ask for 6PK1600 number.
BMW /// 323i
OEM M-Tech II front & rear bumper /// Cluster Ring /// Grimace Fog Lights /// CCFL angel eye
330i Diff /// REMUS Exhaust /// Heat Shield Cold Air Intake
sellsellsell2000 is offline   Reply With Quote
Old 05-20-2011, 02:14 AM   #2789
titan320ci
My Ride: 2001 320ci auto
I thought i'd try to change the front standard springs to sport ones for a subtle front drop, looks better, but i think eibachs or racelands will eventually have to be put on!
TITAN SILVER 2001 E46 320CI
XENONS,
REAR LEDs
RED SPORT LEATHER
PEWTER DI NOC TRIM
ALPINA B3 FRONT AND REAR SPOILERS
ALPINA GOLD STRIPES
ALPINA 18" Classics
55mm front and 30mm drop
custom s/s exhaust
titan320ci is offline   Reply With Quote
Old 05-20-2011, 05:31 AM   #2790
mujjuman
My Ride: not an E46
Seafoamed the hell out of it.
Discovered another coolant leak.
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 05-20-2011, 06:00 AM   #2791
Guest021715
Account closed.
I need to do this before my next oil change. My guess is you poured some seafoam in the brake booster line. I've seen a DIY that said this hose had a "one time use" strap on it, any thoughts?
Old 05-20-2011, 08:32 AM   #2792
bwallace530
My Ride: 325
Be careful after awhile the sea foam will eat away at the lines you are using to suck up the sea foam. Happened to me I would sea foam every other month and it does a really good job just it is really rough on the intake tubes. Mine finally crumbled in my hand when I put it back. It was an older Acura that had alot of miles.
bwallace530 is offline   Reply With Quote
Old 05-20-2011, 11:34 AM   #2793
Solidjake
Zero. Leaks.
Solidjake's Avatar
Old 05-20-2011, 11:05 PM   #2794
tifreak
My Ride: sdfgsdf
pick up a regular hose clamp, you can probably get them pretty cheap at any auto parts store
tifreak is offline   Reply With Quote
Old 05-20-2011, 11:07 PM   #2795
Andy2108
My Ride: SpecE46 & E46 M3
still battling it out with the shop that messed up.
Got rear ended. Gave it to shop for ESTIMATE. Was going to take the check and get it done differently (cheaper).... they just decided to fix the car with bondo. Not what I wanted.
De gustibus non est disputandum.
Old 05-21-2011, 01:05 AM   #2796
TerraPhantm
My Ride: M3 & ZHP
Removed stock headers. Ran into an issue removing section 1, but I should be able to take care of that tomorrow. Euro headers and euro section 1 should be installed tomorrow if all goes well. Already got the DME flashed to European specs. Hopefully will be ready for Eurofest on Sunday. Also got new pre and post cat O2s since I figured itd be a lot easier to do that while the headers are being installed.
Euro vs US headers.
Old 05-21-2011, 01:45 AM   #2797
Nervous
My Ride: 01 330CI 6MT ZSP EU3
Where did you get them from, Terra? How much? Keep us posted about results, in "flashed DME" topic too.
Nervous is offline   Reply With Quote
Old 05-21-2011, 01:49 AM   #2798
new//M3fan
My Ride: 77' 924 87' E30
Euro vs US headers.
nice, I see the M3 has proper headers were as non-m's just have manifolds.
Today, I beat the crap out of my car sensibly.
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 05-21-2011, 02:49 AM   #2799
TerraPhantm
My Ride: M3 & ZHP
Got them from a guy on M3forum (I think he's here too actually) for ~$1100 shipped. (I got the headers and cats for that price... euro cats aren't in that picture). These headers are actually the RHD variant, which is why the one pipe has a bit of a flat-spot. The RHD steering gets in the way of the LHD euro headers. RHD headers fit fine in LHD cars though, and there's no major power difference (according to BMW anyway).
I do kinda wish I was able to get the CSL headers since they're lighter, but it's not really a big deal. The shape is identical between CSL and non-CSL headers - the CSL ones are just made thinner so that they weigh less. Power output should be the same.
I'll definitely keep you guys posted about how they work. I do think the Euro DME will behave a little more appropriately with the euro headers and brand new O2s. While the euro flash has been great so far, it does occasionally do weird things. Since my engine should be identical to a eurospec motor now, it should function properly. I think the issue were more apparent on the M3 since the US and Euro exhausts differ more radically for the M3 than the non-Ms
Yea, the euro headers are actually designed pretty well on the M3. There are aftermarket headers with higher peak power numbers, but many of them sacrifice mid-range performance to do that.
Old 05-21-2011, 09:14 AM   #2800
PRDesignsTony
My Ride: 02 330ci
Did a lot lol, replaced power steering pump, new steering fluid, replaced CCV pipe and a few other pipes and hoses, rubber hoses showed some wear so I decided to replaced them since I already had the intake manifold off, new manifold gaskets, new pressure regulator, cleaned the throttle body, the fuel injectors, fuel lines, accelerator pump. She drives like a DREAM! also degreased my engine so it looks way cleaner than in the pics.
crappy pics but its something.
PRDesignsTony is offline   Reply With Quote
Rate This Thread
