Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 07-08-2014, 04:56 PM   #28381
Geoff.B
My Ride: 2004 BMW 330i MSport
Got some touch up paint fixed the couple spots put some clear coat aswell and voila beener is back to show room condition
The best place to spend lots of time is in my BMW :)
Geoff.Brechmann
Geoff.B is offline   Reply With Quote
Old 07-08-2014, 06:01 PM   #28382
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
^ Same with the touch up paint. Bs'd a bit with my friend and snapped a pic of the car
DSC_0452
by Solidjake, on Flickr
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 07-08-2014, 06:32 PM   #28383
autoAER
My Ride: 03 325xi,08 335i
that lip and mtech II though! very nice!
Leila-E46 325xi Alpine White-Sheila-E90 335i Monaco Blue-Xavier-E53 X5 Black Sapphire Metallic
autoAER is offline   Reply With Quote
Old 07-08-2014, 06:54 PM   #28384
Solidjake
Zero. Leaks.
Solidjake's Avatar
Thanks man, would still look a lot better if the shop I took it to to get painted did a better job...
Old 07-08-2014, 07:49 PM   #28385
Swater330i
My Ride: 2003 BMW 330i 5MT
Clear side markers installed!
Originally Posted by phenom323ci View Post
I am going to install M3 fender grill on my 323ci.
Originally Posted by futureSubie View Post
IMO, the euro clear corners looks too aftermarket/ricey.
Originally Posted by Davconelectric View Post
This 323 would most likely handle and drive better than a stock e46 m3.
Swater330i is offline   Reply With Quote
Old 07-08-2014, 08:25 PM   #28386
BlE46
My Ride: E46 330i ZSP
Front plate delete strip from ECS today...
(before & after)
ID:	564700   Click image for larger version
ID:	564701   Click image for larger version
Bl - 2001 330i 5spd ZSP/169k - Orient Blue/Black
PIF (paid in full) - 1989 325i 5spd/273k - Alpine White/Black
BlE46 is offline   Reply With Quote
Old 07-08-2014, 08:28 PM   #28387
Swater330i
(before & after)
should post a full car pic of the delete too. Good job!
Old 07-08-2014, 08:44 PM   #28388
BlE46
Best one I could get right now... Looks off since the molding around is much older than the delete strip... might just take off all the molding and just plastidip it in black to refresh it...
Old 07-08-2014, 08:51 PM   #28389
Dbills
My Ride: 99' 328i
Um..does your car have a tow lock on it?
Dbills is offline   Reply With Quote
Old 07-08-2014, 08:53 PM   #28390
ChuckyVee
My Ride: 2000 323i, '99 328is
Originally Posted by lszlszx View Post
Fixed the scratch and dent in my quarter panel
VERY impressive....looks great!
First Bimmer..."Miss December"...2000 323i, purchased Dec. 2013 w/82K on the clock. PM thus far...pads/rotors, belts/pulleys, complete CS overhaul, FCABs, plugs, autotranny/differential service, fuel pump, filter, and relay. Full front end refresh with LCAs and bushings, struts and mounts, inner/outer tie rods, sway bar endlinks and bushings.
ChuckyVee is offline   Reply With Quote
Old 07-08-2014, 09:26 PM   #28391
BlE46
Yup, it's in the tool case attached to the trunk.
Old 07-08-2014, 10:05 PM   #28392
yjsaabman
My Ride: '03 325i Touring
Remind me not to move there...
yjsaabman is offline   Reply With Quote
Old 07-08-2014, 10:09 PM   #28393
BlE46
Old 07-08-2014, 10:14 PM   #28394
Gunsnbacon
My Ride: 2001 330ci
Lol, I installed a killswitch in mine just in case. I heard a quick DME flash can actually reset the requirement for a key allowing the car to be hotwired. I think there were some issues with the e90 with this because you could code a blank key with the OBD.
There's nothing to steal in my car... other than pirated music cd's
-List of Modifications-
2001 Alpinweiss 330ci ZSP
Gunsnbacon is offline   Reply With Quote
Old 07-08-2014, 10:29 PM   #28395
Swater330i
Old 07-08-2014, 10:34 PM   #28396
BlE46
Lol, I installed a killswitch in mine just in case. I heard a quick DME flash can actually reset the requirement for a key allowing the car to behotwired. I think there were some issues with the e90 with this because you code code a blank key with the OBD.
LOL! Oh, the rim boot? That's just my paranoia actually, my block is pretty safe, 5 different police offices patrol it plus meter maids, lol... I have a steering wheel lock too.
Old 07-08-2014, 11:10 PM   #28397
Mad_Scientist
My Ride: '04 325Ci
Fuel pump and filter, drain/fill transmission x2 .. Started removing rubber from under rear seat. Replacing with dynamat tomorrow
Mad_Scientist is offline   Reply With Quote
Old 07-09-2014, 12:05 AM   #28398
vo-danh
My Ride: 325I
Today, I will driver my car
vo-danh is offline   Reply With Quote
Old 07-09-2014, 02:38 AM   #28399
huTsu
My Ride: E46 325Ci SMG
Trunk interrior color change.
BMW E46 325Ci SMG M-sport II 2002
Ex: BMW E82 123Da M-sport 2008
huTsu is offline   Reply With Quote
Old 07-09-2014, 02:44 AM   #28400
benbrown457
Change oil, new rear tyre, new side repeaters!
benbrown457 is offline   Reply With Quote
Rate This Thread
