Thread Tools Search this Thread Rating: Thread Rating: 32 votes, 4.00 average.
Old 07-12-2011, 09:57 PM   #3581
tb330
My Ride: 2008 Trailblazer SS
Installed some spacers all around and threw in a new air filter as well. Have to go check the front spacers in the morning as I'm getting a slight shimmy at 65-70
tb330 is offline   Reply With Quote
Old 07-12-2011, 10:27 PM   #3582
aleksankazakov
My Ride: 04 E46 330i sport
Originally Posted by Nervous View Post
I can get even 46. Just reach speed about 70 mph and reset the MPG meter. At some point it will show 40+ mpg
Seriously, if you drive ONLY on highway, on cruise control, 55-65 mph, if ratios of diff and last gear are low enough,with proper tire pressure then it is probably possible to reach 30-33 mpg.
how do you reset the mpg miter?
aleksankazakov is offline   Reply With Quote
Old 07-12-2011, 10:30 PM   #3583
TitaniumCranium
/// Limitless
TitaniumCranium's Avatar
My Ride: 2002 BMW 330Ci
Press the OBC button untill it shows MPG and press and hold the button down for a few seconds and it resets.
/// MODS
/// Auto => 6-Spd Manual Conversion | Apex EC-7 | Koni/Ground Control Coilovers | Vorshlag Camber Plates | Meyle HD LCA | PowerFlex bushings | GruppeM CAI | Shark Injector | 6000k HID's and Fogs | BMW European MTechII | BMW Performance Shifter | ACS Mirrors and Rear Spoiler ///
Old 07-13-2011, 07:50 AM   #3584
S85FTW
My Ride: E60 M5 & F30 328XI
Send a message via AIM to S85FTW
[QUOTE=Black E46 sedan;13371547]You did the stitching? Looks really good!
Thank you sir, yes I did do the stitching. The shift boot took about an hour to do and the ebrake took about an hour and a half. I am betting that the steering wheel is going to take me at least 3 hours to do on Thursday but it will be worth it.
S85FTW is offline   Reply With Quote
Old 07-13-2011, 08:01 AM   #3585
Lusticles
My Ride: 325Ci
I drove it. Nitpicked at all the rock chips while I was in the metro parking lot.
Then thought about when I am getting my M-tech II bumper painted and installed.
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 07-13-2011, 08:03 AM   #3586
Marinerd
My Ride: 09 328i
Originally Posted by Hollywood516 View Post
Bought a new key from stealership.... $175 total..
Only $175? I was thinking it was gonna be along the lines of $250. Is that for a chipped main key? Are the prices different at different dealerships, cause I could've sworn last time I asked someone at the closest dealer to me it was somewhere in the $200 range.
Originally Posted by Black E46 sedan View Post
I kept the 325 rears but swapped the fronts for 330 brakes. Cross drilled and slotted rotors, stoptech pads, and SS lines all around plus the 75mm stud kit from Vorshlag. I like the way the brakes feel now!
How did you fit 330 brakes on a 325? Is it just a direct swap? Caliber and rotors? Mounting screws distance the same on the 330 caliper as a 325? I feel like there's more options for 330 and M3 size rotors than 325.
Marinerd is offline   Reply With Quote
Old 07-13-2011, 01:32 PM   #3587
Hector45
My Ride: 2002 OB 330i
Drove her about 800 miles, west Florida to north Georgia and back.
She ran like a top
Hector45 is offline   Reply With Quote
Old 07-13-2011, 02:06 PM   #3588
Zchild
My Ride: 2000 BMW 3XXi ZSP
Replaced the parking brake assembly, the OEM one is shot after 12 years of useage.
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is online now   Reply With Quote
Old 07-13-2011, 02:13 PM   #3589
gianni 328
My Ride: Topaz E46
Put 100octane. About 40$ at $7.48 a gallon lol but she runs aggressive and more responsive. I wish it wasn't so expensive. I'd run it all the time!
__________________E46
-GIANNI
gianni 328 is offline   Reply With Quote
Old 07-13-2011, 05:01 PM   #3590
tifreak
My Ride: 04 325xi
you should hide that change before some junkie busts your window to get at it
tifreak is offline   Reply With Quote
Old 07-13-2011, 05:54 PM   #3591
Levim9
My Ride: 01' 325i
It's a direct swap for the fronts. All the mounting and hardware is the same. 330 Calipers, 330 caliper carriers, 330 rotors, and 330 pads is all you need. The brake lines may be different sizes. Anthony@bimmerbrakes sent me my order knowing I would be upgrading to 330 fronts so he would know if the 325/330 brakes lines are different.
I've heard you have to change the E-brake assembly and rear trailing arms to 330 parts to fit the rears. Since most of the stopping power comes from the front it wasn't worth the $ in extra parts to change the rear brakes to 330 size. Eventually I plan on swapping in an M3 rear end (whole assembly) including the rear brakes so what I saved here will go into that project.
Levim9 is offline   Reply With Quote
Old 07-13-2011, 05:56 PM   #3592
theinfamousdrew
My Ride: 911 Turbo / E70
Thought about trading up to an M3
here is my ad
http://forum.e46fanatics.com/showthr...5#post13374295
theinfamousdrew is offline   Reply With Quote
Old 07-13-2011, 06:04 PM   #3593
Levim9
My Ride: 01' 325i
Good luck with the sale ^ Maybe you'll be in an M soon
Old 07-13-2011, 06:12 PM   #3594
Ineil
Ineil's Avatar
My Ride: 2001 M3
Easiest and fastest parts replacement I have ever done on my M3, replaced TPS in less then 5 minutes.
And hit 100,000 miles today
M3 sold
New Car
2012 Roush Stage 3 Mustang
Ineil is offline   Reply With Quote
Old 07-13-2011, 06:13 PM   #3595
Wickedly
My Ride: BMW 2003 325i
Took old grill out, Clean the grill placer, left it very neat and clean, install new grills. Took old and barely visible emblem out and install a new one and very cool looking
http://img717.imageshack.us/img717/2...3173438191.jpg
http://img8.imageshack.us/img8/6581/...3173433261.jpg
http://img684.imageshack.us/img684/5...3173444799.jpg
http://img6.imageshack.us/img6/4271/...3181553941.jpg
http://img199.imageshack.us/img199/4...3181608355.jpg
http://img84.imageshack.us/img84/834...3181622719.jpg
Wickedly is offline   Reply With Quote
Old 07-13-2011, 06:42 PM   #3596
elitewolverine
My Ride: 02' M3 Coupe
my dealer quoted me with the same price for my m3 key, 160 if im not mistaken have to check the paper again.
i was surprised because my ford key was $325
elitewolverine is offline   Reply With Quote
Old 07-13-2011, 06:53 PM   #3597
Ridin 30i
My Ride: E46 330i
Golf tee mod. Quite noticable difference in sound and throttle feel at lower rpms. Makes me wanna get exhaust.
Sent from my MB860 using Bimmer App
Ridin 30i is offline   Reply With Quote
Old 07-13-2011, 07:17 PM   #3598
mkdonald
My Ride: 330 Cic
Repaired the worn spot on my side bolster with dye and an air gun. Looks really good.
mkdonald is offline   Reply With Quote
Old 07-13-2011, 07:34 PM   #3599
E46_M3Power
My Ride: 01 M3
Drove it around some, cleaned it out, fixed my xenons. Gonna wash it tomorrow.
E46_M3Power is offline   Reply With Quote
Old 07-13-2011, 08:01 PM   #3600
awol82
My Ride: 03' 325xi
Flashed a Euro2 tune and prayed I wouldn't brick it during the process!
Eric
03' 325Xi
awol82 is offline   Reply With Quote
Rate This Thread
