Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 08-26-2011, 02:16 AM   #4241
2005 325i
My Ride: 05 325i
Originally Posted by spencers View Post
The dealer
What did they run you?
I had my car in the dealership for 3 days because I had a knock in the right rear wheel. I finally got it back today and they said the knock was because of a bad shock mount so they changed that for like $200 and changed a valve cover gasket. All in all spent $318, left the dealer ship and noticed my stereo now has an interference problem so it sounds like there's static under acceleration, I still haven't tracked down the problem. But after I left the dealer I went and got gas then left and what do you know the knocking was back, took it home jacked it up then me and my buddy spun the tire and pulled on it thinking it was a wheel bearing. But no luck seemed solid, my buddy then was checking the drive line and what do you know where the axle bolts to the diff all the bolts were finger tight and some were almost completely out. That could have gone horribly wrong if that were to have came apart
2005 325i
-Headers
-Straight piped
-Cold Air Intake
-2 Din Kenwood/ Mmats 12"
-Megan Racing Lowering Springs
2005 325i is offline   Reply With Quote
Old 08-26-2011, 08:14 AM   #4242
JerzyBoy973
My Ride: 01 330ci
Did you have the dealer diag that?? Or did you just tell them to do the shock mounts? I would have it flat bedded back them and get it taken care of minus the cost of your first repair. That's just BS.
JerzyBoy973 is offline   Reply With Quote
Old 08-26-2011, 11:11 AM   #4243
spencers
My Ride: 2006 330i
"From the dealer" is my generic response for stupid questions in this thread.
I probably bought them from Tischer. They're $0.55/each at thebmwpartstore.com.
White ones are part number #51418224768
Gray ones are part number #51418224781
spencers is offline   Reply With Quote
Old 08-26-2011, 03:14 PM   #4244
2005 325i
My Ride: 05 325i
My friends dad works there so I went in there and told them I have a bad knock in the right rear and I can feel it when I accelerate and decel. After they fixed it he said that it was because of the shock mount, didn't make since to me but I figured they would know better than me but I guess not haha.
We tightened the bolt as good as we could get so i'm going to drive it down there today and have them tighten it on spot, or at least try
Alright cool man, I will check them out because all mine are destroyed
2005 325i
-Headers
-Straight piped
-Cold Air Intake
Old 08-26-2011, 04:05 PM   #4245
kowalzekc
My Ride: 99 328i
Clutch job, no not by me either.....
kowalzekc is offline   Reply With Quote
Old 08-26-2011, 04:28 PM   #4246
Beemeeup
My Ride: 2001 330ci
Just replace the lower control arm bushings, urethane, they seem to work well, not a difficult job either. Also, used some of that Permatex upholtstery spray to reattach the fabric on the "A" pillar. Looks much better than it did, time will tell if the adhesive holds though. Oh yeah, one other thing, installed a strut brace that I bought used. Cant wait until I can afford new bilstein shocks and struts, so I can instal them with the H and R springs. I'm on a roll!
Beemeeup is offline   Reply With Quote
Old 08-26-2011, 07:26 PM   #4247
JerzyBoy973
My Ride: 01 330ci
I parked her under some trees...
Old 08-27-2011, 12:03 AM   #4248
brandonwish
My Ride: 02 325i 5MT
Got her a garage today! Keep her warm and toasty during the frigid cleveland winter
|||2002 325i 5MT|||
brandonwish is offline   Reply With Quote
Old 08-27-2011, 11:50 AM   #4249
TheTrickyTruth
My Ride: 2001 325i
Euro-tray!
TheTrickyTruth is offline   Reply With Quote
Old 08-27-2011, 12:46 PM   #4250
Guest021715
Account closed.
Originally Posted by bwallace530 View Post
You going to coat your headers right?
Sent from my PC36100 using Bimmer
I don't think real world benefits are great enough to be worth the hassle.
Old 08-27-2011, 02:58 PM   #4251
spencers
My Ride: 2006 330i
Fixed the rear parcel shelf rattle again
Sharpied the faded red indicator on my center vent
Old 08-27-2011, 03:06 PM   #4252
brandonwish
^ Looks great. My blue one is actually faded
|||2002 325i 5MT|||
Old 08-27-2011, 04:36 PM   #4253
moiz21
My Ride: 1999 323i 5-SPD
How did you deal with the rattle? Need to get to it at some point.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 08-27-2011, 05:14 PM   #4254
spencers
My Ride: 2006 330i
Tennis ball.
Old 08-27-2011, 09:01 PM   #4255
moiz21
Did u take the whole back deck out to put in the tennis balls? Or how did u decide to do it?
MODS
Old 08-27-2011, 09:26 PM   #4256
joel211974
My Ride: 325i
Replaced bumper cover for an M3 style,replaced windshield washer reservoir, wash it, can't wait to paint it !..
joel211974 is offline   Reply With Quote
Old 08-27-2011, 10:48 PM   #4257
///Mine
My Ride: '05 325i
$35 part from the dealer and 30mins later = new aux input
///Mine is offline   Reply With Quote
Old 08-27-2011, 11:07 PM   #4258
zhenkaaaM3
My Ride: Fst'r then your e46
Covered it today.
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 08-28-2011, 01:08 AM   #4259
spencers
My Ride: 2006 330i
Removed HK subs to gain access to the underside of the deck. Stuffed the tennis ball in.
Old 08-28-2011, 10:18 AM   #4260
moiz21
Lol, saw ur original post before u decided to edit. I've searched all up and down on this forum as well as 2 others. There are about 5 or so different ways to do this. I don't have an HK system, so can't do it your way. Installed a sub so the rattle is annoying but not something I have to do right now. What I'll probably end up doing is remove the entire back deck and line it with something. I Always ask anytime I see someone mentioning the rear deck rattle in case there is a new method I haven't read about yet. Thanks for letting me know what you did. I appreciate it.
MODS
Rate This Thread
