Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 08-28-2011, 11:01 AM   #4261
Top_Bunk
My Ride: Ram-Air Nylon
^ There is a 1/4" wide hole in the center of the metal, right behind where the HK sub would mount. I ended up just pushing a bolt through that to put pressure on the rear deck, and then I put a lock washer on it. No rattling for the last 6 months or so, with a sub in the trunk.
Top_Bunk is offline   Reply With Quote
Old 08-28-2011, 11:05 AM   #4262
Top_Bunk
Originally Posted by spencers View Post
"From the dealer" is my generic response for stupid questions in this thread.
I probably bought them from Tischer. They're $0.55/each at thebmwpartstore.com.
White ones are part number #51418224768
Gray ones are part number #51418224781
Come on, man... ^this is the answer I was after. Maybe I should have asked differently? Thanks anyhow, I need to order these.
Old 08-28-2011, 11:07 AM   #4263
moiz21
My Ride: 1999 323i 5-SPD
I've read about the bolt method too. I bought a bolt and looked at the set up but didnt quite understand how it was done. The place I read it from didn't include any pics of the finished job, so wasnt quite sure how to set it up. Still have the bolt in my trunk too. Also read that because the bolt is against the deck, over time wouldnt it punch through since the deck isn't something extremely solid?
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 08-28-2011, 12:08 PM   #4264
Gheybe
Gheybe's Avatar
My Ride: F80 M3
Replaced my headlight bulbs, decided to keep the car and finish what I started.
Gheybe is offline   Reply With Quote
Old 08-28-2011, 12:38 PM   #4265
Top_Bunk
Yeah, I ended up putting a large washer on the end that was touching the rear deck, just to space out the pressure. No problems with warping yet. Time will tell.
Old 08-28-2011, 12:40 PM   #4266
moiz21
This seems like one of the quickest and easiest solutions. Do you think when you have free time, you could take some pics of the set up and send them to me? Would really appreciate it.
MODS
Old 08-28-2011, 12:48 PM   #4267
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I have to go check the car and make sure it's fine.
Picking up the BMW suspension kit tomorrow.
Old 08-28-2011, 12:58 PM   #4268
spencers
My Ride: 2006 330i
Yes
Lol, saw ur original post before u decided to edit. I've searched all up and down on this forum as well as 2 others. There are about 5 or so different ways to do this. I don't have an HK system, so can't do it your way. Installed a sub so the rattle is annoying but not something I have to do right now. What I'll probably end up doing is remove the entire back deck and line it with something. I Always ask anytime I see someone mentioning the rear deck rattle in case there is a new method I haven't read about yet. Thanks for letting me know what you did. I appreciate it.
Perhaps try the link below. I still need to do it. The rattle I fixed yesterday was caused by the subs. The deck still squeaks under certain circumstances. http://www.e46fanatics.com/forum/sho...d.php?t=837216
spencers is offline   Reply With Quote
Old 08-28-2011, 08:09 PM   #4269
bwallace530
My Ride: 325
Found these with oil on them not sure if its from the ofh or a new leak. And I could not tell if it was power steering or oil.
Sent from my PC36100 using Bimmer
ID:	414671   Click image for larger version
bwallace530 is offline   Reply With Quote
Old 08-28-2011, 10:57 PM   #4270
polychrome
My Ride: 2002 325i
I have almost the same problem. At first I thought it was the oil pan gasket. Now I'm thinking it's the oil filter housing gasket. Gotta take a better look at it sometime this week.
polychrome is offline   Reply With Quote
Old 08-28-2011, 11:01 PM   #4271
bwallace530
My Ride: 325
My OFHG is leaking I know that for a fact. Just been to lazy to replace it so much work for a 7 dollar gasket lol. I had the VCG oil return line replaced It was leaking but I still smell some oil burning and My oil levels are not droping so It still must be the OFHG. IDK its pissing me off tho.
Old 08-28-2011, 11:09 PM   #4272
polychrome
My Ride: 2002 325i
I know what you mean man. If it weren't for the fact that I don't have the gasket, I would have done it while I was doing my clutch fan delete mod today.
Old 08-28-2011, 11:11 PM   #4273
Sanchjer
My Ride: 323i e46 SOLD!
Washed her and cleaned out the inside.
Sanchjer is offline   Reply With Quote
Old 08-29-2011, 02:37 PM   #4274
Zchild
My Ride: 2000 BMW 3XXi ZSP
Finally got around to changing my fuel level sending unit on the driver's side as well as replacing the stupid plastic clip on my passenger side rear window regulator. Just a good day for DIY stuff all-n-all...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Back-Up Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 08-29-2011, 03:49 PM   #4275
zhenkaaaM3
My Ride: Fst'r then your e46
Washed and waxed, interior fully cleaned.
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 08-29-2011, 06:42 PM   #4276
moiz21
Productive DIY day today. Total cost: $9.96
Did the alternative to the OEM alarm found here: http://forum.e46fanatics.com/showthread.php?t=761104
Bought 2 86db buzzers, but not as loud as I wanted, so may go back in and replace it with a 102db buzzer later on. For now I'm quite happy to have an alarm that cost less than $10 total.
And did the clutch switch delay mod found here: http://forum.e46fanatics.com/showthread.php?t=398047
This one cost me nothing since I had a spare wire crimp from when I did my AE's a while ago.
MODS
Old 08-29-2011, 06:43 PM   #4277
moiz21
MODS
Old 08-29-2011, 08:15 PM   #4278
Solidjake
Zero. Leaks.
Solidjake's Avatar
Well not BMW related, but first thing I did today was change the expansion tank on my Mercedes and put in new coolant. Then I took out some old nasty fogs lights and taped off the wiring.
AND BMW related... I picked up the BMW performance suspension kit this morning and about four hours ago I replaced the expansion tank on my car and put in new BMW coolant. But in the process I f'd up my bleeder screw so I just ordered a brass one.
Old 08-29-2011, 08:55 PM   #4279
serdar255
My Ride: '01 325ci / '90 325i
Washed her good.
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 08-29-2011, 08:58 PM   #4280
tb330
My Ride: 2006 Acura TL
Changed the spark plugs...I was expecting them too look absolutely horrible, but they weren't bad at all. Also ordered a Euro-tray and should have an Mtech 2 bumper later this week
tb330 is offline   Reply With Quote
Rate This Thread
