Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 09-15-2011, 01:17 AM   #4501
soloracer24
My Ride: 330Ci
Originally Posted by e30mike View Post
got some e38 style 5's.... for $20
Bargain!!
soloracer24 is offline   Reply With Quote
Old 09-16-2011, 12:16 AM   #4502
polychrome
My Ride: 2002 325i
Replaced my Meyle oil level sensor with a Hella brand.
polychrome is offline   Reply With Quote
Old 09-16-2011, 12:21 AM   #4503
Sanchjer
My Ride: 323i e46 SOLD!
Cleaned all the tar off the front wheels. Never knew all the different uses for WD-40 lmao. Also washed all my micro-fiber towels. Tomorrow I'll be removing all the wheels and cleaning the inside of them and painting the rotors and calipers.
Sanchjer is offline   Reply With Quote
Old 09-16-2011, 01:05 AM   #4504
///M3 Wizard
My Ride: 2002 M3
That should be interesting.
///M3 Wizard is offline   Reply With Quote
Old 09-16-2011, 01:14 AM   #4505
Sanchjer
When I say rotor I don't actually mean the surface, I mean the hub portion. Just to clarify.
Old 09-16-2011, 01:20 AM   #4506
Guest021715
Account closed.
You can be really sloppy with the hub portion, any excess will get burned off when you brake. What color did you choose?
Old 09-16-2011, 01:24 AM   #4507
Sanchjer
Just going to keep it simple and go with black. For the calipers I'll be painting them silver, I switched over to ceramic pads so I think they'll be fine when it comes to the brake dust.
Old 09-16-2011, 12:52 PM   #4508
330indy
My Ride: Z4M-R, 330i
rear passenger window regulator replaced
Stewart water pump
crankcase vent/oil separator upgrade
BMW...........................CCA
330indy is offline   Reply With Quote
Old 09-16-2011, 01:07 PM   #4509
himefrankie
My Ride: 03 330xi
I ordered a bunch of suspension parts over the last few days.
My car will be very happy.
My wallet is very sad.
go big or go home.
himefrankie is offline   Reply With Quote
Old 09-16-2011, 01:44 PM   #4510
himefrankie
My Ride: 03 330xi
go big or go home.
Old 09-16-2011, 02:58 PM   #4511
BigMoneyWaster
My Ride: Bmw e46 330d Saloon
Picked it up from the repair garage
got the drivers side wing repaired and slapped on a new m sport bumper, and bonnet resprayed. new Carbon badges are on the way
BigMoneyWaster is offline   Reply With Quote
Old 09-16-2011, 08:13 PM   #4512
Art Bimmer
My Ride: 2004 E46 Coupe
Replaced coolant system (Thanks Jason) hydraulic belt tensioner assembly, front crank seal. Just hit 83,500K miles. Started seeing wet spots on the garage floor. Figured I do it now or wait until she blows up on the 95 somewhere. Didn't flush power steering, I can still hear a slight growl, maybe next weekend. Big ups to Kpeng's maintenance guide and to the brothers at getbmwparts.com.
Art Bimmer is offline   Reply With Quote
Old 09-16-2011, 08:46 PM   #4513
spngr311
My Ride: 2001 M5
Washed it and put an M-Sport Steering Wheel in. So much nicer - and it's good to have leather that doesn't have a tear in the top!
spngr311 is offline   Reply With Quote
Old 09-17-2011, 12:31 AM   #4514
///M3 Wizard
My Ride: 2002 M3
Finished installing Aux input jack and iPod mount using http://forum.e46fanatics.com/showthread.php?t=422239.
The sound is perfect!
Old 09-17-2011, 12:31 AM   #4515
///M3 Wizard
My Ride: 2002 M3
Not sure why or how but somehow ended up with a duplicate post like ^. Edit was to delete the pics. meh.
Old 09-17-2011, 11:36 AM   #4516
Mattbuyshouses
My Ride: 2006 330i
Replaced the DISA valve, took about 10 minutes to swap out. Fixed the rough idle issue I was having. Running smooth as silk again! Thanks to the guys over at BMWpartssource.com! Big shout out. Great price, fast shipping. The car and I are both happy again.
Mattbuyshouses
Mattbuyshouses is offline   Reply With Quote
Old 09-17-2011, 01:00 PM   #4517
Guest021715
Account closed.
Your username makes sense. That floating headphone jack has one hell of an erection.
Old 09-17-2011, 08:26 PM   #4518
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
FINALLY washed her after a month or so :X
Vacuumed up the inside, added about 5psi to all tires and some other small things.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 09-17-2011, 08:37 PM   #4519
MrAdam
My Ride: S.L.O.W.
Did the exact same thing! Feels so good now.
Oh and redded out my tails
ID:	417376Click image for larger version
~Adam
NEED BODY SHOP ADVICE?
135i REPAIR THREAD
911 REPAIR THREAD
MrAdam is offline   Reply With Quote
Old 09-17-2011, 08:47 PM   #4520
brk
My Ride: 2003 330I
Cleaned the MAF and ICV.
brk is offline   Reply With Quote
Rate This Thread
