Rating:
#461 |
buzz kill.
#462 |
My Ride: 2002 320i Sedan
Gave my E46 to my new mechanic for a week for the following:
1) engine swap (used 325 engine with 80,000KMs) to replace my 320i engine (cracked head, cross-threaded spark plugs, etc). 2) BSW subwoofer / amp install 3) possible head unit install (Alpine if I do that) Plus a thorough end-to-end inspection. |
#463 |
Last night oil change , put in new eurotray(long with slider) and new zhp knob.
#464 |
My Ride: gobbles oil like a B
bled clutch line today
#465 |
installed Bimmian gauge rings, yeah I know, not much of a mod but need to kill time until the supercharger gets here
#466 |
I just blacked out my grills and emblems all around. New headlights with AEs are on order with cleared reflectors for the bumpers. Next is the window trim and Rims/rubber will follow to replace the 17s as soon as the tread is worn on my current tires.
#467 |
Ha. Tell me about it. To make matters worse, I haven't heard back from the seller yet.
#468 |
welll not today, but wed night my right corner light flew right off when i was doing like 90mph . wtf lol (broken clip) but i ordered new ones. so ill be okay
![]() Instagram : JrVincent7 |
#469 |
Driver side window switch will be delivered and installed later today. Maybe a car wash if I get home early enough from work.
#470 |
Installed oem alarm, just needs activation($100)
#471 |
Is the radio interface cable included? I had interference issues with the trunk cable. The radio interface is as easy to install as the trunk (unless you just run the cable on top of the back seat)
#472 |
Stayed up til 2AM installing a UUC TSE3 exhaust and M-Tech II rear bumper on my 325i. Eargasm every time I start her up now.
#473 |
Tried to get a alignment done on my 325ci to find out only dealerships can do it for the most part Fail on my part.
#474 |
Stealth Bulbs
Made my clear corners look great with Stealth Bulbs.
#475 |
My Ride: have 5 doors and FI
I finished my car day by picking the wagon up from Re:vision (I had left it there Friday since I could leave it safely inside) and installed the Benfer CF strut bar, the CF airbox, the CF rear diffuser...all these had been installed on the sedan...but since I had previously installed the BMW Performance CF airbox, perf CF strut bar and perf MTech II CF diffuser on that car.
I also removed the old stereo setup in the wagon and went to a more simple setup with just a JL Audio amp and sub added to the factory nav (and MB quart speakers throughout). Damn it was too hot to work out there - even with the AC pumping in the garage.
![]() /_________\ OO=[][]=OO |
#476 |
Changed the oil and put a new coolant level sensor in the 330ci today.
#477 |
My Ride: 330d Sport Touring
Cleaned door panels and all leather as well as giving her a clean. Took her to a viewing - hoping to have sold her by tonight.
![]() Sig is a BlownE30M3 production! EDGE PROTECTOR DIY http://forum.e46fanatics.com/showthr...&highlight=diy "The protection of views purely on religious grounds cannot be justified. It is not only an irrational idea, but it is also divisive, capricious and arbitrary" - Lord Justice Laws, UK 29/04/2010 |
#478 |
Last night:
-Washed -Polished -Detailed the inside Soon to come: -Angel eyes -Matte black kidneys Last edited by Roxlo; 08-18-2010 at 06:44 PM. |
#479 |
i replaced my seat sensor mate for the air bag system in the passenger sport seat - maybe i'll post a DIY for it because of i didnt find a good guide for me, let me know if someone need it,
i changed my trans oil to the RP 75W90. - much better - but there is still work to do.. and - i replaced my control arms to Meyle , - recommended |
#480 |
This weekend I put in my new thermostat so drained and flushed the entire system. Filled up with new coolant and broke my radiator drain plug.
Put in a new fuel filter. Sanded down those little strips below the front wing/fender just above the side skirts. The bit of the back panel that runs along to the front (coupe). It was all rusty so I sanded it back, primed and painted. Will hit it with 2000 grit tomorrow and lacquer. Realised my driver door and boot seals are all f'ed up. |
| Rate This Thread | |
