Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 10-15-2011, 09:48 AM   #4901
Hollywood516
My Ride: 02 330i
Oil change and thermostat.. Car temp gauge reads a little bit left of 12 o'clock.. Wonder if that's ok?
Hollywood516 is offline   Reply With Quote
Old 10-15-2011, 12:06 PM   #4902
daki_bmw
My Ride: 330Ci
Originally Posted by Hermes View Post
There are actually holes into the trunk under it so the "grid" really does something, it's not just for looks. It's basically to equalize pressure when you open and close windows
FYI- this is where some of the rattle you hear comes from, see the rub marks on my paint?
I didn't know it had some other function beside aesthetics. And yes, I remember I've read about that part making some rattle and guess what - I have rattle frome the exact same area. Probably that grill...
Search how to unlock OBC, go to test 7.0 and get "live data" readout for coolant temp. If it's under 85-ish when fully warmed up, no, you are not OK.
daki_bmw is offline   Reply With Quote
Old 10-15-2011, 12:11 PM   #4903
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Drove it yay
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 10-15-2011, 12:26 PM   #4904
alpine325coupe
My Ride: 2004 M3 SG/IR
I cut 1.5" off my sway bar endlinks and welded them together. No way I'm spending 100+ on adjustable endlinks
2004 Silver Grey / Imola Red - 146k Daily Driver
ENGINE: Scoop, Filter, Elbow, Pulleys, Tune, fan delete+SAP delete
EXHAUST: Headers, Rasp sec. 1, res. x-pipe, TopSpeed muffler
SUSPENSION: BC, subframe reinforcement
WHEELS/TIRES: Hamann PG1, 19x9.5 +25, 19x10.5 +25
DRIVETRAIN: 4.10 gear ratio
LIGHTING: Orion V2, 3000k fogs
INTERIOR: Recaro SPG reps, Cobywheel, CF trim, Dynavin clone, Stealthboxes
alpine325coupe is offline   Reply With Quote
Old 10-15-2011, 01:03 PM   #4905
darksideracer69
My Ride: 01 325ci
Seriously? Lol wtf? Why didn't you just get the impala links for like 40$
Sent from my SGH-T959V using Bimmer
IMAG02051
Old 10-15-2011, 01:17 PM   #4906
alpine325coupe
I figured I couldn't go wrong. I've been driving w/o endlinks for like 3 months. My buddy works at an awning shop so he welded them for me. Free > $40. I'm gonna install them sometime this week to see how they work out
Old 10-15-2011, 02:17 PM   #4907
yetieater
My Ride: '03 330i
New steering coupler and fuel filter
bulletproof one piece at a time
full listing of BMW Performance parts for the E46
yetieater is offline   Reply With Quote
Old 10-15-2011, 03:16 PM   #4908
bwallace530
My Ride: 325
Got my new pads on but I can't get the caliper bracket nuts off, there stuck on so tight. So I am probably going to have to pay someone to put the rotors on.
Does anyone have any advice??
Sent from my PC36100 using Bimmer
bwallace530 is offline   Reply With Quote
Old 10-15-2011, 03:30 PM   #4909
shata
My Ride: 00 328i , 06 330i
Giving it TLC cause cooling system is leaking, Its gotta hold out one more week for going to shop it will get complete overhaul from Radiator to sensors. Also Had to replace the left front turn signal bulb today.
/// 2000 BMW 328I ///
shata is offline   Reply With Quote
Old 10-15-2011, 03:31 PM   #4910
shata
See if home depot is selling Air or electric impact gun... That will solve your problem =)
Old 10-15-2011, 03:57 PM   #4911
bwallace530
My Ride: 325
I know they have one I have seen on tv its only around 80 bucks I think.
I might go check it out.
Old 10-15-2011, 04:05 PM   #4912
edsmax
My Ride: 01 330i
Send a message via AIM to edsmax
New drive belts, new cabin filter, and fresh Redline MTL in the tranny!
Mods: OEM clears all around, ZHP ///M weighted shift knob, GruppeM CAI, UUC Clutch Stop, B&M SSK, red line fluids, golf tee
edsmax is offline   Reply With Quote
Old 10-15-2011, 04:13 PM   #4913
shata
These things are beast to maintain I think I spend roughly 2-4k year in maintenance/repairs lol.
Old 10-15-2011, 04:48 PM   #4914
zhenkaaaM3
My Ride: Fst'r then your e46
Fcuk impact guns. Best way is to go to a hardware store. Get a pipe about 1 1/2 feet long to go over your rachet. That will give you enough leverage to get it off. Kick it down if you have to.
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 10-15-2011, 05:34 PM   #4915
bwallace530
My Ride: 325
I just went to home depot and got a 18v ryobi impact gun
Old 10-15-2011, 05:40 PM   #4916
Sanchjer
My Ride: 323i e46 SOLD!
Are you against air tools, easier and faster DIYs?? Haha.
I let her sit in the driveway all day, but my Bluetooth OBD scanner did come in. Tomorrow I'll be installing my new lower intake boot and brass bleeding screw for my upper coolant hose.
Sent from my PG86100 using Bimmer
Sanchjer is offline   Reply With Quote
Old 10-15-2011, 06:17 PM   #4917
TekNoire7
My Ride: 328i
oil change, refilled coolant, and my god I detailed my car myself with Mr. Clean magic eraser, almost everything looks brand new. I have a beige interior so this made a world of difference. you have to be careful though you don't use it too much because it uses bleach and it can "white out" interior parts of your car if overused! But it looks fantastic it removed scratches and everything I thought I was stuck with in my e46. Now its looking clean for the ladies
TekNoire7 is offline   Reply With Quote
Old 10-15-2011, 06:20 PM   #4918
shata
No ****, having impact gun is so nice.....Ohh the oil bolt is really tight? really ok Here comes the impact - bam done.
Im all about working smart not hard lol
Old 10-15-2011, 06:22 PM   #4919
moiz21
My Ride: 1999 323i 5-SPD
Did the VCG, VANOS seals, idler pulley and DISA valve.
Downside is the exhaust solenoid ended up failing coincidentally
Now gotta cough up ~$100 for a new one.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 10-15-2011, 06:22 PM   #4920
shata
Oh ladies love the e46... Ive had several compliments. Keep it clean and good looking its great car. Makes good impression even though they are pretty old now. I think the E46 is timeless design personally.
Rate This Thread
