Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 12-14-2011, 12:56 AM   #5601
BBBoy323i
My Ride: 01' 325ci
Bought a set of VMR VB3's 18x8.5 all around in gunmetal, bought from supreme power parts, they hooked me up on shipping by giving me a $100 credit, the total was $750 shipped to Hawaii!
BBBoy323i is offline   Reply With Quote
Old 12-14-2011, 02:39 AM   #5602
bmwTuner1
My Ride: Bmw, 330ci
Originally Posted by rossisboss View Post
recently I've been chasing a coolant leak, I replaced everything but the radiator at first, then I had to get a replacement upper hose because it leaked. Now the rad is leaking...
also in the last month or so
-new air filter and duct boots (torn)
-cleaned throttle body and IAC (helped a lot) used CRC throttle body cleaner, that stuff is gooood.
-Stewart WP
-LED interior lights (back pillars waiting to be pulled and fixed, CF re-wrap or something
-Angel Eyes
-pulled center console out to wire up a switch for the angel eye relay
-finding time to re-finish the center console/cup holders as they are scratched.
-Dunlop SP winter sport 3d snow tires
side note: summer tires like Dunlop's Sport Maxx TT's don't grip even dry below 30 'F
and she's in need of a cleaning, again.
thats a lot. Have you pinpointed your coolant leak on the actual radiator? its better to start with the more inexpensive items first.
It turned out my coolant leak was coming from the part where the expansion tank meets the upper hose. So I changed both of them today as well as the coolant sensor, coolant, and oil. Now I just have to track down this oil leak I have. I cleaned my whole bottom end and kept the plastic cover off in hopes it will show me what area its coming down from.
Photobucket
bmwTuner1 is offline   Reply With Quote
Old 12-14-2011, 09:51 AM   #5603
AquaRelliux
My Ride: 330ci 03 M-sport
I installed oem black kidneys yesterday looks awesome on my ir coupe with shadowline
AquaRelliux is offline   Reply With Quote
Old 12-14-2011, 09:52 AM   #5604
moiz21
My Ride: 1999 323i 5-SPD
Thats an amazing price. Wonder what it would have been within the Cont US.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 12-14-2011, 10:56 AM   #5605
aleksankazakov
My Ride: 04 E46 330i sport
Send a message via ICQ to aleksankazakov
Installed new HIDs 8000k
Sent from my MOTWX435KT using Bimmer
aleksankazakov is offline   Reply With Quote
Old 12-14-2011, 11:13 AM   #5606
TR4G-
My Ride: '01 325xi, '90 325iC
purchased an audiocontrol LC2.1 line out converter so I can hook up my dual 12 inch subs in my rear deck
TR4G- is offline   Reply With Quote
Old 12-14-2011, 02:52 PM   #5607
Pedi
My Ride: 330ci
Cooling System failed but did not overheat ! i got lucky ... caught it early
Pedi is offline   Reply With Quote
Old 12-14-2011, 02:52 PM   #5608
Pedi
My Ride: 330ci
$612 later...Ordered a custom cart full of Genuine BMW cooling system. She will be taking a 2 week nap until i can replace her cooling system with brand new shiny parts !
Old 12-14-2011, 03:15 PM   #5609
aleksankazakov
Washed
Old 12-14-2011, 03:29 PM   #5610
Pedi
My Ride: 330ci
Originally Posted by aleksankazakov View Post
Washed
get some new headlight lens !
Old 12-14-2011, 06:46 PM   #5611
zhenkaaaM3
My Ride: Fst'r then your e46
installed projectors much better. Now, had to get screw in corners...
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 12-14-2011, 07:00 PM   #5612
E46runsPCB
My Ride: 2000 BMW 323ci
Washed and waxed, cleaned inside and out. Watched it for a couple hours....
E46runsPCB is offline   Reply With Quote
Old 12-14-2011, 07:03 PM   #5613
rossisboss
My Ride: '03 330i sedan ZHP
yeah it was a lot of stuff, and it's on one of the tubes running across the rad. I've replaced everything else already, most because of wear causing small seeping leaks in cold weather, and some as preventive maintenance. The car being a manual trans made the rad a little cheaper and much easier to change. I'm just waiting on it to cool before cracking it open right now.
I love the fan on this car, 1 screw, 1 push rivet, 2 plugs, pull it out.
upcoming I plan on VANOS seals and rattle kit, possible 02 sensor, and some rear diff work to seal it and stiffen the mounting back up. then maybe I'll have time and money to rebuild my shifter.
115,000 miles and counting, daily driven, clean all around, and underneath.
Is your oil leak coming from up front somewhere? If it is, check into your oil filter housing gasket, the one between the engine and the filter housing, not the o-ring on the cap. mine had a leak there last winter.
back to the garage now to swap the new rad in. should be cold enough now.
rossisboss is offline   Reply With Quote
Old 12-14-2011, 07:17 PM   #5614
IHAZBMR
My Ride: '02 M3 SMG
Took her down for an overall checkup, only problem is this stupid driver's door lock issue, and I evidently need new rotors....oh and got my Vogtland springs in the mail....
'02 Ti Silver M3 SMG SoCal I.E.
Mods: 35% Ceramic tint, CF Wrap Interior, CF roundels, CF Shift Knob, Painted reflectors, Cell Phone holder, Euro mirrors, Dice Mediabridge, Sirius SC-C1
IHAZBMR's '02 M3 SMG
IHAZBMR is offline   Reply With Quote
Old 12-14-2011, 07:42 PM   #5615
spencers
My Ride: 2006 330i
Looks good
spencers is offline   Reply With Quote
Old 12-14-2011, 07:44 PM   #5616
330xIce
My Ride: 2005 330xi
Send a message via AIM to 330xIce
installed my khoalty 7500k h7 halogens, replaced my air filter, and changed my oil
Follow Me On Instagram: JamesMarshall_E46
///My Progress Thread - How To Set a Signature - Black Sedans FTMFW
-James-
330xIce is offline   Reply With Quote
Old 12-14-2011, 08:44 PM   #5617
zhenkaaaM3
bought a bunch of goodies for my e46
Old 12-15-2011, 03:59 AM   #5618
grandcarrera
My Ride: 330xi 2003
Changed my coil today. My car is running so much smoother. To bad tho that I drop a cover cap (number 15) to the side. I hope that it will do nothing to my car.
http://www.realoem.com/bmw/showparts...&fg=15&lang=en
grandcarrera is offline   Reply With Quote
Old 12-15-2011, 04:00 AM   #5619
grandcarrera
My Ride: 330xi 2003
Old 12-15-2011, 05:51 AM   #5620
bmwTuner1
My Ride: Bmw, 330ci
Yeah, the fan is a breeze to get off. I kept reading on the possible sources for oil leaks the other day and came across the OFHG having issues after time. You saying that makes me more certain thats the problem. Ill have a look when I get some time. Thanks for the advice!
Photobucket
Rate This Thread
