Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 01-08-2012, 04:20 PM   #5981
TexFinn
My Ride: 01 Hellrot 330i
I've been procrastinating on replacing the driver's side rear window regulator but decided to bite the bullet today. Pretty easy job, actually.
Let's see how long the no-name regulator lasts. Now I just need to get my ass doing the passenger front, too. Preferrably before that takes a dump like the driver's rear.
01 Hellrot 330i
08 MB C350 Sport
05 MB C230K Sport
03 Chevy Silverado RCSB 5.3
TexFinn is offline   Reply With Quote
Old 01-08-2012, 04:27 PM   #5982
BigDRick323
My Ride: 2000 323i
I thought I had really screwed it up, took it apart again, tightened the screw holding the glass to the regulator, tested it and Wala! Perfecto window!
Old 01-08-2012, 06:02 PM   #5983
ShaTR
My Ride: 2004 325xi
Originally Posted by Solidjake View Post
I really don't want to run staggered because of the lower profile for the rear. Some of the roads here suck. I might swap with someone for two rears or two fronts and then run 235/40.
Just washed the car, vacuumed the inside, cleaned the trunk out and cleaned up the engine bay a bit.
Staggard doesn't mean less sidewall on the rear. The sidewall number is a percentage of tire width.
For example, for my newly aquired summers wheels and tires, the tires are 225/45/17 front and 245/40/17 rear. The sidewall height difference is 1/8". That's like 1 or 2 seasons worth of tread wear. (nuthin basically)
back on topic
Changed my sparks to NGK iridiums and dropped in a K&N air filter.
ShaTR is offline   Reply With Quote
Old 01-08-2012, 06:04 PM   #5984
moiz21
My Ride: 1999 323i 5-SPD
Went for a cruise with local BMW fanatics. Not just e46's, but had E90's, 1 series, even had a Porsche and cobalt. Was really fun, attached some pics. Went from MD to Philly for some cheesesteaks. Was fun, at points we would hit a ~100 as a pack. Really fun, had a good 20 cars or so. Was a total of 6 hours round trip. Those that wanted, did some pulls against each other. Everyone had 2-way radios, so we could keep in touch. Definitely would recommend that everyone take part in something like this at some point with local fanatics. One of those involved was new//M3fan as well.
Name:	photo 1 (2).jpg
ID:	431615   Click image for larger version
Name:	photo 1 (3).jpg
ID:	431616   Click image for larger version
ID:	431617   Click image for larger version
Name:	photo 2 (2).jpg
Name:	photo 2 (3).jpg
ID:	431619   Click image for larger version
ID:	431620   Click image for larger version
Name:	photo 3 (2).jpg
ID:	431621   Click image for larger version
Name:	photo 3 (4).jpg
ID:	431623   Click image for larger version
Name:	photo 4 (2).jpg
ID:	431624   Click image for larger version
Name:	photo 4 (3).jpg
ID:	431625   Click image for larger version
Name:	photo 5 (2).jpg
ID:	431627   Click image for larger version
Name:	photo 5 (3).jpg
ID:	431628   Click image for larger version
ID:	431629   Click image for larger version
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 01-08-2012, 06:10 PM   #5985
zanth119
My Ride: 2002 330cic
Weather was very nice here, was able to do a quick mini-detail yesterday and today:
"Some people will tell you that slow is good - and it may be, on some days - but I am here to tell you that fast is better. I've always believed this, in spite of the trouble it's caused me. Being shot out of a cannon will always be better than being squeezed out of a tube" - Hunter S. Thompson
zanth119 is offline   Reply With Quote
Old 01-08-2012, 06:12 PM   #5986
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
So can I run 235/40 all around on 18x8 front and 18x8.5 rear?
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 01-08-2012, 06:21 PM   #5987
ShaTR
My Ride: 2004 325xi
probably, but why? run a staggard tire setup, you have the rims for it already...
throw some 255/35 on the rear, 235/40 on the front and call it a day.
Old 01-08-2012, 06:28 PM   #5988
Solidjake
Zero. Leaks.
Solidjake's Avatar
I know but the roads here in NYC aren't the most generous...
Old 01-08-2012, 06:30 PM   #5989
ShaTR
My Ride: 2004 325xi
then why did you buy 18's?
The sidewall on both the sizes i mentioned are almost exactly the same. Its the same amount of sidewall as if you ran 235/40 all around. just a wider tire.
besides, a wider tire will protect the lip from curb rash better too.
Old 01-08-2012, 06:40 PM   #5990
Solidjake
Zero. Leaks.
Solidjake's Avatar
Well I am going to trade for a square setup and run the 235/40's
Old 01-08-2012, 07:36 PM   #5991
ShaTR
My Ride: 2004 325xi
It's your choice. But i still don't understand why. You said because the roads in NYC are bad, but what does that have to do with a square setup vs staggard??
Old 01-08-2012, 07:39 PM   #5992
Solidjake
Zero. Leaks.
Solidjake's Avatar
Well being able to rotate and just having that bit bigger sidewall. If I can't get anyone to trade I'll just do the staggered and deal with it.
Old 01-08-2012, 07:41 PM   #5993
Sanchjer
My Ride: 323i e46 SOLD!
Heres the pics I promised last night. Not the best weather for pics so once the rain clears up I'll take some GOOD pics. Gonna need a new sig...anyone down for the challenge??
ID:	431641   Click image for larger version
ID:	431642   Click image for larger version
ID:	431643   Click image for larger version
ID:	431645   Click image for larger version
Sanchjer is offline   Reply With Quote
Old 01-08-2012, 07:43 PM   #5994
Solidjake
Zero. Leaks.
Solidjake's Avatar
I like the 4th pic with the front of the car angled, but it would look better if you took the pic further back so I could crop it easier.
Old 01-08-2012, 07:50 PM   #5995
TX78666
My Ride: 330i ZHP, N55 135i
Did the e90 reflector retrofit on *one* headlight. I was pretty distracted - football, movies, nice weather, etc. I'll do the other next weekend.
Do you think it made any difference? Here's the old reflector, and one of the new ones.
Because... Grocery Getter.
TX78666 is offline   Reply With Quote
Old 01-08-2012, 07:57 PM   #5996
Sanchjer
I wouldn't be able to get any pics for the next couples days...rains in the forecast here for awhile. Once I get good pics I'll repost em. Thanks
Old 01-08-2012, 07:59 PM   #5997
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
why black???????
/_________\
O==[][]==O
Old 01-08-2012, 08:01 PM   #5998
330i ZHP
330i ZHP's Avatar
wow, did you get the parts off eBay? is there a diy?
should I do this or the fxr stuff
/_________\
O==[][]==O
Old 01-08-2012, 08:05 PM   #5999
Sanchjer
Originally Posted by 330i ZHP View Post
why black???????
The PO painted them black. I'm contemplating to strip the paint and have them silver or leave them as is. Everyone says they look good black...I'm not sure what style BBS they are, I need to see a set of silver ones on a silver sedan to know for sure what I'm going to do.
Old 01-08-2012, 08:18 PM   #6000
TX78666
I got the parts off ebay. There are a couple of DIYs that I worked from. I still had to figure out a little on my own. I may do a DIY when I do the other one. Unfortunately, I already took the new reflector apart, and cut it down, so I can't do any before pictures for that.
Here is the reflector DIY I used:
http://forum.e46fanatics.com/showthread.php?t=845704
An I used this DIY to take the headlights apart. This DIY was not 100% accurate, though. That's what has me thinking that I may try to put my own together.
http://forum.e46fanatics.com/showthread.php?t=609558
I couldn't say if you shoud do this, or the FX-R stuff. This was cheaper. I don't know if it was easier. Don't know if the end result is better, either. For me, it was a cheap way to fix a problem. I wasn't looking for an upgrade. Just a repair.
Rate This Thread
