Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 02-02-2012, 04:13 PM   #6581
Sanchjer
My Ride: 323i e46 SOLD!
Originally Posted by Majdob View Post
Nice I wanna see those LM's when you're done
I don't have LMs. I have BBS style 197s.
Sent from my PG86100 using Bimmer App
Sanchjer is offline   Reply With Quote
Old 02-02-2012, 04:14 PM   #6582
Majdob
My Ride: Slow TiAG
Little edit at work until I take a new one
ohh yah guy is a idiot for painting those black, can't wait to see how they turn out
Vruuuuum.
Majdob is offline   Reply With Quote
Old 02-02-2012, 04:15 PM   #6583
Sanchjer
Originally Posted by serdar255 View Post
What supplies?
I was trying to post a pic but it didn't work. Here they are.
Old 02-02-2012, 05:22 PM   #6584
serdar255
My Ride: '01 325ci / '90 325i
do you have tires still mounted or no
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 02-02-2012, 05:28 PM   #6585
Sanchjer
I do. Why? I'm going to use index cards and tape to protect the tires. That's also why I got the paint on style and not the spray style.
Old 02-02-2012, 05:29 PM   #6586
Sanchjer
Yeah me either.
Old 02-02-2012, 07:35 PM   #6587
serdar255
Just curious im doing this to my style 44
Old 02-02-2012, 08:33 PM   #6588
Hooverbeamer
My Ride: '00 323i
Did my vcg and spark plugs
Hooverbeamer is offline   Reply With Quote
Old 02-02-2012, 08:33 PM   #6589
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Clean engine
Old 02-02-2012, 08:36 PM   #6590
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Replaced key fob screws and silicone lubed my key gasket! Picked up my elephant trunk for trunk harness rebuilding!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 02-02-2012, 09:38 PM   #6591
trj
My Ride: 325Ci
All my lighting mods are almost done.
Interior LEDs done a couple of days ago. Need to add a resistor to make sure they work all the time.
OEM AL bixenon projectors with 6000K bulbs retrofit in my halogen housing completed today. Have to mount the ballasts properly, for now its just zip tied.
Have to fix the 3 LED issue with my angel eyes so I can put them in the headlights.
Old 02-02-2012, 11:15 PM   #6592
The_Don
My Ride: 2001, 325Ci
I just finished a series of needed maintenance projects:
Oil change
Re-lubed brake caliper bushing pins
Bled the brakes and abs/dsc unit
Installed 10mm spacers to help my wheels clear coilovers
Adjust front endlinks
Adjust the redline transmission fluid blend for better shift engagement
- UUC Stg. 1 LTW Flywheel - UUC SSK + DSSR - UUC TM +TME - UUC Rear Adjustable Control Arms - UUC Swaybarbarians - AST Sportline II -
- RE Underdrive Pullys - RE FCABs - BMW Performance Control Arms - Shark Injector - EMP High Flow Water Pump - TMS Adjustable Endlinks - K&N CAI -
- M3 Motor Mounts -
For Sale
The_Don is offline   Reply With Quote
Old 02-02-2012, 11:22 PM   #6593
Guest021715
Account closed.
Are your LEDs turning off?
I'm still running the 6SMD in the footwells, and single 194 bulb in the dome without any problems
Old 02-02-2012, 11:25 PM   #6594
nike001
My Ride: Fergo
Originally Posted by samson View Post
not worried about my plate :o
LED plate lights
Where did you get these? I currently have LED's in mine now.. but they're too blue.
2015 M235i 6MT
nike001 is offline   Reply With Quote
Old 02-02-2012, 11:57 PM   #6595
Sanchjer
I got mine from khoalty and they look just like his. Easy to install and no need for resistors.
Old 02-02-2012, 11:59 PM   #6596
trj
My Ride: 325Ci
You got the same LEDs as mine apart from the dome one, didn't you? I guess I am going to get the bigger(360 degree) dome light LED.
Yah they are still turning off. They work sometimes and sometimes they don't. Usually it doesn't work after I run the car for some time (may be heat is causing some issues).
I installed 9 LED ones in the footwells and single ones on the dome and C pillars. The switched ones work great, only the automatics are not working so great. By autos I mean the ones that should be triggered by remote or door opening; the dome, C pillars and the footwells. Also as the result my angel eyes are not getting triggered with the remote.
I got a 100 ohm 10 Watt resistor I plan to put in parallel with the footwell light, but its too big to be soldered in.
Everything will have to wait, because there is a forecast of up to 2 feet of snow by saturday
Old 02-03-2012, 12:05 AM   #6597
Guest021715
Account closed.
Yeah, I ordered the dome light from LEDAutomotive and the 9SMD footwell lights from Ebay are on the way.
Dunno, I haven't driven the car, its just a garage queen for winter but all the LEDs work so far.
How'd you find the installation for the rear 194 LEDs? Mine was a pain.. had to take the plastic lenses off, and switch around about 4 bulbs until the button ones worked.
Old 02-03-2012, 12:11 AM   #6598
trj
My Ride: 325Ci
Yeah the C pillar ones were very difficult. Had to pry the lenses off to get the LEDs in, my fingers are still sore because of that.
For the LEDs not working, just switch them around also bending the pins to the outer side of the LEDs to make a proper contact with the round holder worked for me.
Old 02-03-2012, 11:32 AM   #6599
E46BAV90
My Ride: 330ci & 325xi
Just watching my car sit in the garage as the snow comes down.... all 2 feet of it
2002 330ci & 1987 325i vert
SIG PIC
Clutch Slave Cylinder Replacement DIY
E46BAV90 is offline   Reply With Quote
Old 02-03-2012, 01:36 PM   #6600
Sanchjer
Just replaced my FCABs, all I have to say is for anyone second guessing doing there's, just do it. The response of the car has improved so much. All the thuds are gone when I go over bumps as well. Think I'm going to do the steering coupler next, along with the stability arms. About to start on stripping my wheels.
Rate This Thread
