Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 02-19-2012, 05:43 AM   #6921
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
the eng/trans/SC is all installed in the wagon...need to mount the exhaust to the headers and plug in the O2s and I will be done under the car
up top, I need the DME from ESS, fill the oil, fill the coolent for the engine and the SC cooler, I am waiting for a new valve cover...I cracked this one (minor and you cant see it, but I am freaking nuts about everything being 100%), I need a new high pitch horn (stopped working while at the painters - tested and known dead - I wonder how a horn just stops working???)
I will need to get an alignment since I had the suspension and steering parts off the car
I will say this again - taking the engine out the bottom and re-installing it that way has been a dream compared to wrestling it out the top
oh well, done for now - I am beat
/_________\
O==[][]==O
Old 02-19-2012, 05:45 AM   #6922
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Found out that my rattling/thud noises from the back are both my trays in the trunk. I put in new clips for them but they still make the noise, I might just not put them back in at all.
Also, cleared my airbag light yesterday and it did stay off.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 02-19-2012, 07:29 AM   #6923
CAFFN
My Ride: 2002 316ti Compact
Washed it and put in new headlight-bulbs.
Next on the list: New license plate lights, fix the not-working rear-wiper, might put in some clear blinker-lights. Oh, and need to clear the airbag-light. Enough to do
BMW 316ti Compact
CAFFN is offline   Reply With Quote
Old 02-19-2012, 11:16 AM   #6924
777eThOd*
My Ride: spins too much
Decided to take the plates off the front.
2007 BMW 335i FBO 6MT - Current
2013 Nissan Nismo 370Z - Current
2004 Non-M Facelift Coupe - SOLD
2006 BMW M3 - SOLD
777eThOd* is offline   Reply With Quote
Old 02-19-2012, 11:50 AM   #6925
shata
My Ride: 00 328i , 06 330i
Put it in the shop for 2k worth of work. Sigh
/// 2000 BMW 328I ///
shata is offline   Reply With Quote
Old 02-19-2012, 12:11 PM   #6926
Solidjake
Zero. Leaks.
Solidjake's Avatar
What work?
Old 02-19-2012, 12:26 PM   #6927
shata
Cooling system and lower control arm bushing/alignment.
Old 02-19-2012, 12:32 PM   #6928
JuicyE46
My Ride: 12 E82
Put my m3 bumper on!
Sent from my MB611 using Bimmer App
JuicyE46 is offline   Reply With Quote
Old 02-19-2012, 01:06 PM   #6929
yrksccr6
My Ride: 2000 328Ci ZPP
New OEM rear struts (one was leaking fluid) and thermostat (temp gauge stayed on cold)
yrksccr6 is offline   Reply With Quote
Old 02-19-2012, 01:07 PM   #6930
alpine325coupe
My Ride: 2004 M3 SG/IR
Replaced driver's side FCA and FCAB after hearing a noise the past few days. Noise is still present, not sure what it is
2004 Silver Grey / Imola Red - 146k Daily Driver
ENGINE: Scoop, Filter, Elbow, Pulleys, Tune, fan delete+SAP delete
EXHAUST: Headers, Rasp sec. 1, res. x-pipe, TopSpeed muffler
SUSPENSION: BC, subframe reinforcement
WHEELS/TIRES: Hamann PG1, 19x9.5 +25, 19x10.5 +25
DRIVETRAIN: 4.10 gear ratio
LIGHTING: Orion V2, 3000k fogs
INTERIOR: Recaro SPG reps, Cobywheel, CF trim, Dynavin clone, Stealthboxes
alpine325coupe is offline   Reply With Quote
Old 02-19-2012, 01:30 PM   #6931
Sanchjer
My Ride: 323i e46 SOLD!
. Dude you can easily buy all the parts for under 1k and do all the work yourself.
Sanchjer is offline   Reply With Quote
Old 02-19-2012, 01:31 PM   #6932
Sanchjer
Did you get the delete strip or just took the plates off? Kinda hard to see in your pic.
Old 02-19-2012, 01:33 PM   #6933
NightRaider93
My Ride: 2007 Z4 Coupe
My cooling system was $400...
-Spencer
NightRaider93 is offline   Reply With Quote
Old 02-19-2012, 02:08 PM   #6934
shata
Cant do it myself, It wont be 2k its lil over estimate but It will be roughly close.
Old 02-19-2012, 02:09 PM   #6935
Jmhockey1920
My Ride: 2002 325i
Fixing to change oil and oil filter
Jmhockey1920 is offline   Reply With Quote
Old 02-19-2012, 03:28 PM   #6936
Majdob
My Ride: Slow TiAG
You really gotta drop that thing
Vruuuuum.
Majdob is offline   Reply With Quote
Old 02-19-2012, 03:31 PM   #6937
777eThOd*
Just the plates, I filled the holes with the paint so holes hard to see.
2006 BMW M3 - SOLD
Old 02-19-2012, 03:47 PM   #6938
JuicyE46
My Ride: 12 E82
yea im working on that.
Old 02-19-2012, 05:23 PM   #6939
///MPR77
My Ride: 02 ///M3 Tri-Ped
Check your motor mounts. They are right above your FCA's
Sent from my HTC Sensation 4G using Bimmer App
Old 02-19-2012, 08:04 PM   #6940
ml325ci
My Ride: 325ci
Gave my 325Ci a bath and detailing. Orbital polishing, nano sealer, butter wax.....parked her in the garage since it rained all day. Next weekend, belts, pully, tensioner, OFHG and coolant flush......then a nice long drive!
ml325ci is offline   Reply With Quote
Rate This Thread
