Rating:
#741 |
My Ride: M3 & 323Ci (sold)
what brand of coil-overs are those?
![]() ![]() OEM CSL WHEELS - OEM CSL BRAKES - OEM AUTOFOLD MIRRORS - CSL TRUNK - CSL DIFFUSER - AA SPORT TUNE - AA PULLEYS - BILSTEIN PSS9s - AUTOSOLUTIONS SSK CF CSL RACE LIP - NAVI HU - BMW PERFORMANCE CF STRUT BAR - BMW GROUP-N MTRMTS - UUC SS BRAKELINES, TRANS MOUNTS, RTABs - 4.10 BMW M-SPORT DIFF |
#742 |
My Ride: 01" 325iT
wash, wax, vac
#743 |
Changed the flywheel - the old one stared giving me some vibration, clutch is new. Put new guibo as well.
Diagnosis - BMW...
#744 |
Detailed interior
#745 |
threw on matte black kidneys on my 325i and cleaned my 330ci
![]() jessica. |
#746 |
My Ride: 2001 BMW 330xi Sport
I listed her on e46fanatics for sale
http://forum.e46fanatics.com/showthread.php?t=786350 |
#747 |
Fixed a flat tire
#748 |
Washed it, then waxed and cleaned the rest of it up. I hate detailing
#749 |
New wheels/tires, drilled rotors and pads, now to detail
#750 |
PS- Don't click on his picture and go to the last page of his photobucket. |
#751 |
Mod
Yesterday I vacuumed the interior thoroughly, used Lexol leather cleaner on EVERY single square inch of leather inside and then I used Lexol leather conditioner. After that I popped out the rear seats and ripped out the crayon smelling lining. I already took all of that out of the trunk 1 month ago. Then I vacuumed under the rear seats as well. I found a quarter, lol.
Follow my cross country drive to Bimmerfest West 2013
http://forum.e46fanatics.com/showthread.php?t=987217 ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
#752 |
Mod
hahahahahahhahahahaahahaha
#753 |
today i might fix my "wondering" floor mats
#754 |
Finally got my Dynavin wired up. Sounds great!
#755 |
resealed convertible roof.
#756 |
My Ride: 01" 325iT
glued pillar trims with 3M Super 77
#757 |
My Ride: have 5 doors and FI
took off the rear bilstein struts and H&R coils - replaced with PSS10 setup - damn wagons are tough...many more panels to remove
took off Fikse Profil10 and installed almost new CHs (used them for about a month last fall before putting away for winter and I have been using the Fikse since spring) rebuilding Nav DVD unit tonight as well (tired of the unit locking up and not being able to read DVD)
![]() /_________\ OO=[][]=OO |
#758 |
Hope to install the front struts tomorrow and replace the spherical bearing in the Vorshlag camber plates (nothing broken or worn...just trying to isolate a noise in the front since installing the camber plates)
I want to install the new style and larger injectors for the TS2+ setup then onto extending the secondary O2 wiring past the cats and cut out holes and weld in the two bungs (new O2 and trans harness installed - no more trans wiring or TCU) I had to have Pat at GP Autogroup (Pro Imports) perform the programming beyond what I could figure out with my GT1 (even having assistance from Seth at Tischer) the only codes coming up now after two readiness cycles completed are P0420, P0430 and P1525 - secondary cats too low, same and then DISA valve reading low DISA is removed with TS - so the tune will take care of that code...extending the wiring will hopefully eliminate the 420 and 430 codes
#759 |
Cooling System Overhaul
Ok. This was yesterday but I didn't get a chance to post.
I replace the leaking thermostat and some other cooling system parts. Rad, Stewart WP, Thermostat, Rad Hoses, Temp Sensor, Coolant Level Sensor, Expansion Tank and Cap, Bleeder Screws and coolant. Today: Take it for a drive. |
#760 |
Today I
had sex with my e46. |
| Rate This Thread | |
