Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 08-22-2010, 04:04 PM   #761
rpl
My Ride: 2002 330ci
Originally Posted by spencers View Post
Made in China!
PS- Don't click on his picture and go to the last page of his photobucket.
rpl is offline   Reply With Quote
Old 08-22-2010, 04:56 PM   #762
Imola.ZHP
My Ride: Imola ZHP
Originally Posted by sharky33OCi View Post
Today I
had sex with my e46.
Me too! Been on vacation for a week (without her) and she was all tight again almost like a virgin...
On a more serious note, anyone remove their A-Pillar covers? The fabric on mine have come loose and needs to be re-glued. I tried to remove them when I installed my bluetooth kit (mic) and couldn't figure them out...
-- '03 330i ZHP
-- Marcus
Imola.ZHP is offline   Reply With Quote
Old 08-22-2010, 08:21 PM   #763
spngr311
My Ride: 2001 M5
^I just took my A and C pillars off to flock them (unfortunately the tan didn't match as well as I had hoped, so I'll probably flock them black soon). Take a butter knife to pull the cover piece off the middle of the A-Pillar. It's just snapped into place. Use a T20 torx bit to unscrew the three screws to take the pillar off. The hardest part for me was pulling it off where the A-pillar cover slides into the dash. You have to pull up without pulling the pillar cover too far away from the pillar to get it out.
spngr311 is offline   Reply With Quote
Old 08-23-2010, 02:26 PM   #764
Roxlo
My Ride: e46 325i
-Fixed an oil leak caused by the vanos oil line
-Installed new NGK spark plugs
-Installed new cabin air filter
-Checked out my control arm bushings, need new ones, ordered polyurethane from ECS tuning.
-Ordered zimmerman sport rear rotors and OEM brake pads
-Dumped bottle of techron in to clean the fuel system
Roxlo is offline   Reply With Quote
Old 08-23-2010, 03:54 PM   #765
Imola.ZHP
My Ride: Imola ZHP
THANKS!
I was thinking there were probably screws behind that piece, but wasn't sure if by prying around those covers if the curtain bags would shoot out. I know, highly unlikely, but still. I pulled and pulled on the drivers side for awhile thinking just clips held them in, now I know. Mine wrinkled at the bottom first (a few years back) and the one side looks bad after I pulled and pulled on it for awhile...
-- '03 330i ZHP
-- Marcus
Old 08-23-2010, 04:50 PM   #766
N89
My Ride: 330Ci
Originally Posted by Imola.ZHP View Post
THANKS!
I have a link to a DIY on my home computer, if you want to PM me I'll reply with that link later, I can't remember where it was exactly... I planned on doing this soon too haha. As far as the procedure goes though I think you pry off the middle piece first, then remove two 10mm torx screws, of course disconnecting the battery first because of the air bag.
N89 is offline   Reply With Quote
Old 08-23-2010, 04:53 PM   #767
SalM
My Ride: Shhh
Thought About 2 Toning My Interior
SalMPhotography
SalM is offline   Reply With Quote
Old 08-23-2010, 04:57 PM   #768
N89
My Ride: 330Ci
Oh I'm not sure if I posted in here, but Saturday I replaced the cooling system with the kit from Tischer... wow was that a pain in the ass at times... especially the lower radiator hose
Old 08-23-2010, 10:55 PM   #769
pyrocrickett
My Ride: 2004 330i ZHP
Rewired my DIY AUX-in with an iPod dock connector to 3.5 mm audio plus USB plug (two-in-one!) & routed all of the cabling behind/beneath the center console; now I have a single connector to power & play my iPod/iPhone!
'04 ///ZHP sedan 6MT
pyrocrickett is offline   Reply With Quote
Old 08-23-2010, 11:24 PM   #770
xavi330i
My Ride: 2004 330i smg
I have a big list.
-Checked and cleaned intake tubes. No cracks.
-Cleaned ICV. It was dirty and stuck. Going back to OEm air filter.
-Cleaned throttle body. Shiny
-Cleaned MAF.
-Cleaned my recently replaced DISA. Covered in oil.
-Replaced CCV and all hoses. It was the cause of my oil leak and oil consumption comparable to a rotary. White smoke/lean condition with codes. Fouled the 6 plugs.
-Replaced dipstick tube O-ring.
-Replaced Vanos piston seals and internal (rattle) rings.
-Replaced Vanos gasket.
-Replaced Vanos oil inlet crush washers.
-Replaced VCG and all of it other grommets and rings.
-Replaced sparkies with new BMW 4-prong platinums.
-Replaced fuel filter.
-Changed oil and filter.
Special thanks to assembly lube and torque wrench.
xavi330i is offline   Reply With Quote
Old 08-23-2010, 11:34 PM   #771
spencers
My Ride: 2006 330i
Yeah, I took an unexpected shower when I finally got that one off!
spencers is offline   Reply With Quote
Old 08-24-2010, 05:50 AM   #772
theinfamousdrew
My Ride: 911 Turbo / E70
yesterday....
i washed her and attached some new velcro to the bottom of my floor mats.
theinfamousdrew is offline   Reply With Quote
Old 08-24-2010, 03:37 PM   #773
Bimm3rSpeedstr
My Ride: 323Ci
New pads, rotors, wheels and tires!
Bimm3rSpeedstr is offline   Reply With Quote
Old 08-24-2010, 06:07 PM   #774
Miko_10
My Ride: 330i 5 Spd
bought a new gas cap and did a 200 mile road trip, 33 mpg FTW..
FS(PM me if interested, MID Atlantic Area, 22307 zip)
- 2 M68 fronts w/ winter tires, local pick up preferred,
- OEM Pre face Sedan Clears.
Miko_10 is offline   Reply With Quote
Old 08-24-2010, 06:25 PM   #775
sea6speed
My Ride: 2010 335i Msport 6MT
Bought 2 cans of Armor All wheel protectant, The Absorber, new microfiber mitt and wheel brush.
sea6speed is offline   Reply With Quote
Old 08-24-2010, 07:01 PM   #776
theinfamousdrew
today i hit 123456.....
also when i got home from work the orange oil light came on after i turned it off....let it cool down a bit...checked the oil level...its fine....so i guess its time to replace the oil level sensor
Old 08-24-2010, 07:12 PM   #777
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
Re-glued the peeling part of my A pillar at the bottom, and took my door panel off AGAIN to use winshield silicone on the door clips to keep them from rattling. This coming weekend I think I'm gonna lower the car some more, may end up having to get shorter endlinks for the front, the hotchkis units are as short as they can go which limits my drop. Maybe get some pics of the new drop and CSLs
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 08-24-2010, 07:13 PM   #778
Imola.ZHP
My Ride: Imola ZHP
33 mpg?
My past few tanks have been lucky to get 21...
Thats nearly all city though, with A/C blasting and quite a bit of flogging...
Closing in on 91k, I think its time for a new fuel filter.
-- '03 330i ZHP
-- Marcus
Old 08-24-2010, 07:30 PM   #779
E46erFan01
My Ride: 2003.5 BMW M3
Finally finished claying. Took a couple days but it looks amazing. Also got a couple things buffed out.
2003.5 BMW M3
E46erFan01 is offline   Reply With Quote
Old 08-24-2010, 08:16 PM   #780
pyrocrickett
Put 'er in the air for a pre-roadtrip inspection of suspension, tires, & rear subframe, then checked the oil, wiper fluid, brake fluid, & lug bolts. Tomorrow morning will be a coolant, power steering fluid, & tire pressure check before hitting the 600-mi road home!
Rate This Thread
