Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 04-30-2012, 10:20 PM   #8881
COBYATCH
My Ride: 03 325i
Originally Posted by illestminimike View Post
Pm MrAdam if your in LA. He was film that matches perfectly. I was going to get LED tails but now I don't care. It looks good enough for me.
will keep that in mind. thanks!
COBYATCH is offline   Reply With Quote
Old 05-01-2012, 01:51 AM   #8882
Roby G
My Ride: 2005 325 Ci
Still tweakin the ride height and dampening with the K-Sport coil overs ! now at even ride height 32cm fronts / 32cm rears rim to center wheel. Reduced tire pressure to 36lbs and dialed down dampers to 18 clicks.
Uneven road surface ride quality with K-Sports, 235/40/18 Yok-S on light 19lb wheels gettin better, less body/frame bump transfer. During acceleration, stops, and thru corners the tires stick like glue with very little frame or body roll from the coils. SRF 504 coilover, SRR 532 spring on control arm.
need a break from tire jacking !
Went and washed the desert grime off her !
Burnin Arizona Heat Wave !
Roby G is offline   Reply With Quote
Old 05-01-2012, 07:47 AM   #8883
moiz21
My Ride: 1999 323i 5-SPD
Originally Posted by Blueandwhite85 View Post
I'd beg to differ. 323's are cruisers, not performers.
I'll disagree in the sense that they are not performers in a straight line. But are just as spry and good at handling in the twisties. And I definitely proved that this past weekend with some friends. Due to my suspensions upgrades, it handles and performed just as well as some of my friends' E9x's. Was an awesome weekend .
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 05-01-2012, 09:23 AM   #8884
///MPR77
My Ride: 02 ///M3 Tri-Ped
Agreed.
I could care less about straight line speed. In the bends;It all comes down to the driver, until the uphill straights.....
Sent haphazardly from my HTC
Old 05-01-2012, 09:23 AM   #8885
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
She's all wet today and I'm staying home.
Old 05-01-2012, 10:26 AM   #8886
daki_bmw
My Ride: 330Ci
- Complete rear brakes (rotors, pads, parking brake shoes, little springs kit for parking brake)
- Valve cover gasket
P.S: Oil level sensor will wait for the next oil change
daki_bmw is offline   Reply With Quote
Old 05-01-2012, 10:27 AM   #8887
Solidjake
Zero. Leaks.
Solidjake's Avatar
What brand is the oil sensor?
Old 05-01-2012, 11:15 AM   #8888
boostedisbetter
boostedisbetter's Avatar
My Ride: NiNe tHoUsAnD!!!
Might as well do your Vanos seals while your at it
** Political sig removed **
boostedisbetter is offline   Reply With Quote
Old 05-01-2012, 11:16 AM   #8889
YayIgotaFaceLift
My Ride: 2004 325ci
Got the New Clutch on, The new transmission on and shes running. So I think that's a big thing.
-Technician at Performance Tech Pro's
-"Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
-Girls are like parking spots. The good ones are taken and the free ones are handy capped!!!!!!!!
YayIgotaFaceLift is offline   Reply With Quote
Old 05-01-2012, 11:17 AM   #8890
Turntables83
My Ride: 2005 330i ZHP
Front CABs from OEM to powerflex.
Turntables83 is offline   Reply With Quote
Old 05-01-2012, 11:18 AM   #8891
boostedisbetter
Originally Posted by ///MPR77 View Post
Agreed.
Actually .... If you COULD care less, that means you COULD care less, I believe what you meant to say is you "COULDN'T care less"
/grammar police
Old 05-01-2012, 11:23 AM   #8892
boostedisbetter
Originally Posted by COBYATCH View Post
painted my tails red again and put back on the clears. still gotta sand them smooth. not really feeling the clears anymore though. might get a set of lightly smoked ones.
can't say I like this mod, maybe when you get done sanding? Vinyl is always the way to go for ALL red tails. Post pics when done sanding. Good idea on ditching those clears...
Old 05-01-2012, 12:02 PM   #8893
daki_bmw
My Ride: 330Ci
Jake, oil level sensor is cheap (24 = $32) ATP rebranded some chinese/turkish junk (probably)...with ATP being one large German shop for German car parts (OEM and not so OEM): https://www.atp-autoteile.de/Default.aspx
I've had small VCG leak for a few months now, and I really needed to fix this ASAP, since I have to make a few trips in the next few weeks (around 1000 kms total) so I didn't want to drive it with a leaking VCG. Waiting for VANOS seals to get from Beisan systems to Europe (or from any shop/seller for that matter) takes 2-3 weeks, so I just had to skip it this time.
Oh, and you shoud say "while you're at it", not "while your at it" because "mine isn't at it."
/grammar police
/grammar police
x2
English is my second language, but I've always felt that the experession should have said: "I couldn't care less..."
Old 05-01-2012, 12:06 PM   #8894
havnfun328
My Ride: '99 328i, '03 M5
New Driveshaft!
A lot of annoying noise and vibration are gone now, really made a difference!
Used a reman from Driveshaft Specialists in Texas ($358 + $60 core). Seemed very good quality and is running very smooth.
Also replaced belts and pulleys a few weeks ago.
Next up: Oil Pan Gasket
2003 E39 M5 Lemans Blue: Truly an amazing car
1999 E46 328i Bone stock 5-speed: Beater and Track Car
250K!!!!!!!!!!!!!!!!!!!
havnfun328 is offline   Reply With Quote
Old 05-01-2012, 12:06 PM   #8895
Solidjake
Zero. Leaks.
Solidjake's Avatar
Return it and get a HELLA sensor. That crap that you bought will fail on you and leak oil.
Old 05-01-2012, 12:07 PM   #8896
330xIce
My Ride: 2005 330xi
Send a message via AIM to 330xIce
[/img]
Smoked gets old quick.. trust me
Follow Me On Instagram: JamesMarshall_E46
///My Progress Thread - How To Set a Signature - Black Sedans FTMFW
-James-
330xIce is offline   Reply With Quote
Old 05-01-2012, 12:07 PM   #8897
YayIgotaFaceLift
My Ride: 2004 325ci
Do ew raelly ned to be abl to speel thes dayz?
Old 05-01-2012, 12:08 PM   #8898
330xIce
My Ride: 2005 330xi
know u dnt
-James-
Old 05-01-2012, 12:31 PM   #8899
jgold47
My Ride: 2004 X5 3.0
/grammar police
x2
I would still wait and do the VCG at the same time as the vanos. unless your spewing oil, I wouldnt bother. Do the VCG, vanos and an oil change all at the same time and call it a day.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 05-01-2012, 01:32 PM   #8900
moiz21
Picked up a new electric fan from my mechanic today for $180. Other one crapped out and runs all the time, after I turn the car off.
MODS
Rate This Thread
