Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 05-05-2012, 10:03 PM   #9021
ryannel2003
My Ride: '04 Cadillac Deville
Little E46 has been behaving lately. Drove around to put some miles on the car to see if SES light would come back on and it hasn't. I did notice that during tonights hard rain I need to reseal the little beestinger antenna again. It has a slight leak causing the 3rd brake light cover to have some water. No biggie... I'll take care of it tomorrow.
Gotta admit, I was a diehard Cadillac guy before this car and if everything continues to go well with this BMW I don't think I would ever buy anything else. Great car it is.
ryannel2003 is offline   Reply With Quote
Old 05-05-2012, 10:21 PM   #9022
Sanchjer
My Ride: 323i e46 SOLD!
Dropped in a new cabin air filter. I kept sneezing and coughing while in my car and really couldn't figure out why, the other day my friend started to do the same when we went to the store. That was when I realized I needed a new filter. There was so much pollen stuck in that old thing. Drove around for a good while with the new filter and not a single sneeze or sniffle.
Sent from my PG86100 using Bimmer App
Sanchjer is offline   Reply With Quote
Old 05-05-2012, 10:53 PM   #9023
///MPR77
My Ride: 02 ///M3 Tri-Ped
Originally Posted by TiAg46 View Post
Pulled off the front bumper, and it's on the Driver's side, all the way up front by the brake ducts. Just pull it out, disconnect the cable, connect new sensor, put it back into place.
But yeah, didn't solve it for me. Still reading -40......
Sometimes when it gets hot enough, it reads +50 degrees though. And other times, it can be spot on with the temp.
Freakin' bi-polar sensor, I swear.
You had to pull the bumper cover off?
Why?
Are you sure the long pins seated in the connector properly?
Sent haphazardly from my HTC
Old 05-06-2012, 11:23 AM   #9024
HighPod
My Ride: '00 white 323ci
Did my vanos seals yesterday at 175,000 miles. Very happy I did it. I couldn't believe how bad the old seals were.
Sent from my DROIDX using Bimmer App
HighPod is offline   Reply With Quote
Old 05-06-2012, 01:36 PM   #9025
FM3T10
My Ride: E46
Great for you man! How noticeably different is the car?
FM3T10 is offline   Reply With Quote
Old 05-06-2012, 01:40 PM   #9026
PH03NIX46
My Ride: 2003 M3
Why?
I can't think of any other way to disconnect that sensor.
It's placed inside of a hole by the brake ducts, and then it clips into another piece, and a little bit of it pokes outside of the bottom of the car, to get an accurate temp. reading.
And I tried to push it in as hard as I could, the sensors appear to be nearly identical...
Eibach | Sportline | OEM Euro Headers | TTFS
PH03NIX46 is offline   Reply With Quote
Old 05-06-2012, 02:20 PM   #9027
zhenkaaaM3
My Ride: Fst'r then your e46
Cleaned it, in and out. tomorrow its going to be all dusty, i hate black
zhenkaaaM3 is offline   Reply With Quote
Old 05-06-2012, 02:36 PM   #9028
E46Moonlight
My Ride: 2000 323i
Looks so much better with the tow cover
E46Moonlight is offline   Reply With Quote
Old 05-06-2012, 03:43 PM   #9029
BmwSonora26
My Ride: Bmw325ci
Painted the diffuser over the license plate black
BmwSonora26 is offline   Reply With Quote
Old 05-06-2012, 04:31 PM   #9030
serdar255
My Ride: '01 325ci / '90 325i
You made it worse
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 05-06-2012, 06:26 PM   #9031
BmwSonora26
My Ride: Bmw325ci
Originally Posted by serdar255 View Post
You made it worse
For some reason i like it ima let it go for alil while. Its plasti dip so it can come right off.
Old 05-06-2012, 08:12 PM   #9032
jmanfredonia
jmanfredonia's Avatar
My Ride: 325i
cleaned and waxed my car, changed wiper blade inserts...
E46 325i with 70,200 miles for sale: http://forum.e46fanatics.com/showthread.php?t=993988
jmanfredonia is offline   Reply With Quote
Old 05-06-2012, 08:16 PM   #9033
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Cleaned her up a bit and went to a family wedding
Old 05-06-2012, 08:27 PM   #9034
TurnersInOz
My Ride: 2004 325i
Spent an hour or so on my hands and knees removing the paint splatter from both sides. Grrrrrrrrrrrrrrrrrrrrrrrr.
Ordered VANOS kit, VCG etc. from Pelican.
Will do the inside later today.
TurnersInOz is offline   Reply With Quote
Old 05-06-2012, 08:55 PM   #9035
lejeunebimmer
My Ride: 02' M3 SMG, 02' 330i
Stripped about 80lbs of weight, while still maintaining a full interior...
330i - AA Tuned, Headers, UUC Stage I LW FW, e36 M3 Clutch, UUC SS Clutch line, BMW Performance Intake, Evo Sport Pulleys, BMW Performance Cross-Drilled Rotors, Hawk HPS, BW SS Brake Lines, BW Solid Guide Bushings, BMW Performance CF Strut Brace, H&R Sways, H&R Sport Springs, Bilstein Sport Shocks, Powerflex Bushings, LED Tails, Clear Sides/Turns, Black Grill, Mtech 2, CF Splitters
M3 - Not enough room to list
lejeunebimmer is offline   Reply With Quote
Old 05-06-2012, 08:59 PM   #9036
j_block
My Ride: 2003 325i
what did you take out or off?
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 05-06-2012, 09:05 PM   #9037
lejeunebimmer
Sound deadening under rear seat, behind the seat back, in the trunk, behind the door panels of the back seat, trunk lining (all of it), tool kit' jack, wheel chock, oddments tray on the left side of the trunk, full-size spare tire and wheel, wiring for a sub the p.o. Put in.
So I have a stripped trunk, but I do have a full interior.
Should bring my total weight down to about 3170. I'll confirm it in the next couple of days.
Old 05-06-2012, 09:09 PM   #9038
j_block
My Ride: 2003 325i
So I have a stripped trunk, but I do have a full interior!
So would you have more exhaust drone if you took out all the sound deadening?
Old 05-06-2012, 09:10 PM   #9039
tock172
My Ride: '12 135i DCT
Ordered my parts and fluids for my next oil service from BavAuto. They had a special going on where you get a free filter when you purchased liqui moly oil so I went for it. I also purchased a set of these:
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 05-06-2012, 09:16 PM   #9040
Solidjake
Zero. Leaks.
Solidjake's Avatar
Yes you will. I took out all of my green soun deadening as well. Sounds great though with oem exhaust
Rate This Thread
