Thread Tools Search this Thread Rating: Thread Rating: 32 votes, 4.00 average.
Old 06-04-2012, 08:09 PM   #9861
BMWSilberGrau
BMWSilberGrau's Avatar
My Ride: 2004 330ci
Originally Posted by phoenix31 View Post
Just recently picked up a m3 and so far I've bought oem m3 floor mats, black and white carbon fiber bmw kit, metal m3 license plate, cleaned the hell out of the engine compartment, and tomorrow I have a guy coming over for a quote on a new paint job. I am thinking of adding a turbo, but don't know where to start. I also want to dye the seats.
You should post what you get quoted on for you paint job! I am looking to get one since someone totally messed up my paint . There are little acid marks on the hood!
Anyone have an idea of how much a new paint job should cost?
'04 Silbergrau Metallic 330ci
ZSP / ZPP / ZCW / 6MT / VMR VB3 18" / OEM MTech II / M3 Trunk Lip / Matte Black Kidney Grills / Shadowline Trim / ST Coilovers / AUX
BMWSilberGrau is offline   Reply With Quote
Old 06-04-2012, 08:12 PM   #9862
Ice Cold
My Ride: 2005 330xi
Send a message via AIM to Ice Cold
Considering driving it off a cliff. Got ABS light brake light and DSC light and the car died. Wont start, won't even turn over. This thing has been nothing but headaches for the past couple of months. I replaced the battery a little over a year ago. Any ideas?
Follow Me On Instagram: JamesMarshall_E46
My Progress Thread - How To Set a Signature - Black Sedans FTMFW
-James-
Ice Cold is offline   Reply With Quote
Old 06-04-2012, 08:33 PM   #9863
S85FTW
My Ride: E60 M5 & F30 328XI
Send a message via AIM to S85FTW
An 05 with that many problems? Jeez
S85FTW is offline   Reply With Quote
Old 06-04-2012, 08:57 PM   #9864
Ophidian_PR1M3
My Ride: 2004 BMW 325ci
Originally Posted by Phoeni9x View Post
How'd you do this? Vinyl, paint, plastidip, swapped? Looks good!
I used plastidip. It's got several flaws in it from when I removed the tape and some of the plastidip bonded to the tape next to the chrome.... Probably should've used vinyl but oh well it will work for now
Ophidian_PR1M3 is offline   Reply With Quote
Old 06-04-2012, 09:03 PM   #9865
Ophidian_PR1M3
I keep getting those same lights but my car is running fine aside from the lean code I have and can't find a solution to. Let me know what you find that sets off the lights tho please
Old 06-04-2012, 09:20 PM   #9866
Stiggles
Stiggles's Avatar
My Ride: Was built Fri 13th
Sounds like a simple alternator/voltage regulator problem.
Replace with an OE Bosch 120a after correctly diagnosing this is the problem.
Stiggles is offline   Reply With Quote
Old 06-04-2012, 09:26 PM   #9867
Kleen330
My Ride: 330Ci
well not today but yesterday ...woke up and saw my passenger window was shattered but still holding up because of the tint....at first i was like it must have been the heat i guess.... but i look at it closer and it looks like someone tried to pry the window open...but theres no damage on the seals....whatever still pissed me off.... there goes mod money...
sig
Kleen330 is offline   Reply With Quote
Old 06-04-2012, 09:33 PM   #9868
Crestwood1001
My Ride: 2001 325xi
Started it this morning and had a low coolant level light, shut it off and checked the level, it reads low, I got under the car and saw 0 leaks or wetness of any kind, started it again and no light. I got a key scan a while ago and the cooling system was replaced ~25k ago, im assuming it's normal for it to read correct completely cooled off (10 hours shut down), and that I'm low on coolant but iv never had any cooling issues, not really concerned but will add coolant of you guys think I should!
Crestwood1001 is offline   Reply With Quote
Old 06-04-2012, 09:38 PM   #9869
Hollywood516
Hollywood516's Avatar
My Ride: 02 330i
Originally Posted by Tampa01e46 View Post
So you took your car to a shop to have an INTAKE installed?
Um no.. It was in the shop(FINALTOUCH MOTORSPORTS) for:
New H&R springs
New RTABS
New sway bars links
Transmission fluid change (filter)
4 wheel alignment
New Upper strut mounts
New vanos line
4 New wheels and tires.
New Rotor and pads( Brembo,Hawk)
And fixed oil filter housing gasket leak
Oh yeah, he put my new intake in for me also (Free of charge)
Just was commenting how great it sounds..
She's back to good now....
Hollywood516 is online now   Reply With Quote
Old 06-04-2012, 09:42 PM   #9870
Jperry666
My Ride: 2002 325i 5spd
Im almost finished with my fiberglass box. ALOT more work than anticipated but coming along good. Pic is from test fitting still have a couple layers of glass and bondo and carpet to go. Click image for larger version
Sent from my DROIDX using Bimmer App
Jperry666 is offline   Reply With Quote
Old 06-04-2012, 10:16 PM   #9871
phoenix31
My Ride: 2001 BMW M3 Phen Yel
My girlfriends brother is an amazing painter. I've seen some of his work on classic cars. He does just about anything. I'm currently cleaning out my garage and sealing it up so we can use it as a place to do body work and paint. He is suggesting since the Phoenix yellow is already a sweet color then maybe just putting some ghosting (light pearl metallic) designs in subtle places. Only really noticeable in bright light when you look hard. I'm not a fan of bold black strips or anything large like that. The color to me is almost perfect the way it is. Any suggestions?
phoenix31 is offline   Reply With Quote
Old 06-04-2012, 10:43 PM   #9872
TerraPhantm
My Ride: 2005 M3 Coupe
Could you have possibly turned the heat on recently?
TerraPhantm is online now   Reply With Quote
Old 06-05-2012, 01:58 AM   #9873
Platinum Plus Quality
My Ride: M54B30
Did these things over the weekend..
I installed a brand new Genuine BMW valve cover w/ new Genuine valve cover gasket because my old valve cover was distorted and caused me to change the valve cover gasket six times in a month with four brand new gaskets and three different types of sealant material. Leak kept coming back. so we'll see in a couple weeks...
and I fixed my fuel filter line leak with Genuine BMW fuel hose. The aftermarket hose I used didn't seem to hold up well. Started leaking after I did the job close to two years ago.
Hopefully I get genuine results.
Cooling | Maintenance | Vacuum | Suspension | Costs
"Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs
Old 06-05-2012, 01:58 AM   #9874
My Ride: M54B30
Old 06-05-2012, 05:42 AM   #9875
m320
My Ride: 2002 bmw 320
Replaced front left side headlight ballast, replaced it with aftermarket ballast, and D2S adaptors.
m320 is offline   Reply With Quote
Old 06-05-2012, 07:11 AM   #9876
boostedisbetter
My Ride: 2000 Integra
New H&R springs
New RTABS
New sway bars links
4 wheel alignment
New vanos line
I thought there was more to this story
^M3 EATER^
boostedisbetter is online now   Reply With Quote
Old 06-05-2012, 07:22 AM   #9877
deanthedude1977
My Ride: bmw e46 325i sport
changed the thermostat as the heater in it was throwing a code 123-heater stat--followed info on here so thanks guys..
deanthedude1977 is offline   Reply With Quote
Old 06-05-2012, 07:22 AM   #9878
boostedisbetter
Where did you get your new thermostat, and how much did you pay-if you don't mind.
^M3 EATER^
Old 06-05-2012, 07:26 AM   #9879
deanthedude1977
got the stat at main dealers-didnt want to risk anything else==£79 pounds....replaced the bolts too and got the coolant from bmw aswell
Old 06-05-2012, 08:02 AM   #9880
Crestwood1001
My Ride: 2001 325xi
Yes the past few nights and this morning, light goes off after drivin for a bit, on a side note you know Dalton don't you?
Rate This Thread
