Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 10-03-2010, 07:02 PM   #1001
Shawn187
My Ride: e46 M3
Removed my MAF looked at it cleaned it. Installed MAF. Started Car and listened to it DIE! Unplugged MAF. Found a new part---> Hydrocarbon detector. Looked it up to see what it does and put it back.
Shawn187 is offline   Reply With Quote
Old 10-03-2010, 09:10 PM   #1002
The Thomas J
My Ride: 2002 325Cic
Tinted the windows.
The Thomas J is offline   Reply With Quote
Old 10-03-2010, 09:23 PM   #1003
zhpfan4life
My Ride: 2004 BMW 330ci ZHP
Did a coolant system bleed and luckily I don't have any leaks, it was a good day. I also filled up the tires to the normal psi
WOO!
Mods:
Eurospec Exhaust, 19"VMR VB3's, Tint, BMW Performance CAI, and more to come...
zhpfan4life is offline   Reply With Quote
Old 10-04-2010, 12:56 AM   #1004
Washburn
My Ride: 2005 AW 330Ci ZHP
Gave it a 2-day rest (drove the Tbird to work), and changed the front floor mats to all weather mats.
2005 Alpine White 330Ci with ZHP
Washburn is offline   Reply With Quote
Old 10-04-2010, 08:58 AM   #1005
xavi330i
My Ride: 2004 330i smg
This past Saturday: Replaced my fuel filter and replaced both exhaust flanges/gaskets that mate headers to TSE3. Had a terrible exhaust leak. The fuel that emptied out the old fuel filter was cruddy black! Look as if it was very rich 2-cycle mix with deposits. The following night had a huge pounding headache from fuel vapor inhalation.
xavi330i is offline   Reply With Quote
Old 10-04-2010, 09:09 AM   #1006
Zodo
My Ride: 2000 328i
Over the last couple of weeks:
FCABS
Air conditioning compressor
Fuel pump, fuel level sensor & fuel filter
Changed trans fluid & filter
Changed rear end fluid
Had sub frame inspection (passed)
AE's
Waiting on my smoked led brake lights
Zodo is offline   Reply With Quote
Old 10-04-2010, 03:12 PM   #1007
djack12
My Ride: 2001 330i
Just got finished installing a full set of Tokico HP struts and shocks....
2001 330i
Great Service, Great Prices
Ryan Gangemi Motorworks
http://www.ryangmw.com
djack12 is offline   Reply With Quote
Old 10-05-2010, 10:35 AM   #1008
lab rat
My Ride: '02 330iT
installed the M3 trunk lip spoiler
Old 10-05-2010, 12:44 PM   #1009
himefrankie
My Ride: 03 330xi
didn't do it today.. but over the past weekend completed the steptronic paddle-shift retrofit and installed an alcantara wrapped smg wheel.
go big or go home.
himefrankie is offline   Reply With Quote
Old 10-05-2010, 02:53 PM   #1010
TiAgXi
My Ride: e46xi, e46m
Got CABs pressed into their respective lollipops. Yesterday I removed CA's and CABs. Tonight everything goes back on.
TiAgXi is offline   Reply With Quote
Old 10-05-2010, 03:27 PM   #1011
arkadur
My Ride: E46 323CI
a new clutch, with all oil seals
uuc trans mounts, all new bushing, and teflon bushing for selector rod.
the shifter fell better then new one
arkadur is offline   Reply With Quote
Old 10-05-2010, 03:54 PM   #1012
Spynxxx
My Ride: '01 330Cic
Just finishing up the ICV and wouldn't you know it I dropped the very last torx head bolt and had to listen to the pa-chin-ko like music as it bounced it's way down to rest in the belly pan
Last edited by Spynxxx; 10-05-2010 at 03:58 PM. Reason: Filter found Japanese slot machine name offensive when spelled properly
Spynxxx is offline   Reply With Quote
Old 10-05-2010, 04:50 PM   #1013
DrBmw4
My Ride: 02 330ci
I purchased my new rear shocks & Meyle mounts and washed her!
DrBmw4 is offline   Reply With Quote
Old 10-05-2010, 05:01 PM   #1014
throttlehead
My Ride: 330i Imola ZHP 6MT
i emailed..then called the "specialist" working on my car since the deer strike 3 months ago, for the tenth inquiry! oh it might be done today ! yea ZHP now to get the inspection before time is up !
2003 BMW 330i ZHP
Imola Red Saloon
6MT
throttlehead is offline   Reply With Quote
Old 10-05-2010, 07:31 PM   #1015
iminshambles
My Ride: 323ci
Put on 4 new tires and ordered parts to replace the cowl and the rear vent window trim/belt molding that have dry rotted.
The plastic and rubber that BMW uses is terrible.
iminshambles is offline   Reply With Quote
Old 10-05-2010, 10:24 PM   #1016
tifreak
My Ride: sdfgsdf
got it registered
tifreak is offline   Reply With Quote
Old 10-07-2010, 04:38 PM   #1017
zwei e46
My Ride: '99 323i & '05 325xi
Recently ...
replaced FCAB (Meyle HD)
complete cooling system overhaul
Removed drivers window regulator and tightened everything up. Added zip-tie as well (preventative)
Today ...
Replaced my swaybar endlinks ... WOW, what a difference for $40.00!
"Re-seated" the above mentioned window (read this link)
http://www.bimmerfest.com/forums/sho...d.php?t=421824
zwei e46 is offline   Reply With Quote
Old 10-07-2010, 04:49 PM   #1018
darksideracer69
My Ride: 01 325ci
New expansion tank n rad my expansion tank busted on the highway yesterday
IMAG02051
Old 10-07-2010, 07:43 PM   #1019
yaboc
My Ride: 02 325iA
replaced worn roundels with b/w ones.actually trunk piece is still good
yaboc is offline   Reply With Quote
Old 10-07-2010, 08:23 PM   #1020
SparklingZHP
My Ride: 05 330ci ZHP
Washed it, after almost a month of on and off rain. Cleaned a bit of the garage for her to hibernate from winter in 2 weeks
SparklingZHP is offline   Reply With Quote
Rate This Thread
