Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 10-14-2010, 01:56 PM   #1061
spngr311
My Ride: 2001 M5
At least it didn't cut open a radiator hose like it did to me once.
spngr311 is offline   Reply With Quote
Old 10-14-2010, 02:00 PM   #1062
theinfamousdrew
My Ride: 911 Turbo / E70
You just made me check to make sure there was no puddle under the car...lol
The temp gauge light up for like 30 second before I was able to shut it down....think I'm good? I don't know how fragile these are
theinfamousdrew is offline   Reply With Quote
Old 10-14-2010, 02:03 PM   #1063
theinfamousdrew
Lit up* damn phone
Old 10-14-2010, 02:29 PM   #1064
spngr311
My Ride: 2001 M5
I would definitely look at the hoses. My alternator belt frayed and split down one of the grooves and cut a slash in the hose. Thankfully, I had ordered a cooling system rebuild the week before and planned to change that stuff over the weekend.
Old 10-14-2010, 04:10 PM   #1065
zwei e46
My Ride: '99 323i & '05 325xi
put new clutch hose and slave cylinder in my 323. Bleed it the "proper way", thanks to searching here. Take-offs MUCH smoother. Now I have to psych myself up for the clutch master cylinder... doesn't look fun!
zwei e46 is offline   Reply With Quote
Old 10-15-2010, 05:24 PM   #1066
theinfamousdrew
today...replaced my serpentine belts
new rear brake pads (stoptech)
new air filter (streamline)
Old 10-15-2010, 09:46 PM   #1067
himefrankie
My Ride: 03 330xi
Yesterday, I installed alcantara shift and e-brake boots!
go big or go home.
himefrankie is offline   Reply With Quote
Old 10-16-2010, 02:25 AM   #1068
djack12
My Ride: 2001 330i
Lets see. Yesterday I did the following:
New lower radiator hose
New temp sensor
New cooling fan (along with a complete rewire front he fuse panel (dead 12v to the fan)
New water return hose
New radiator drain plug
New ATF (power steering) and hose clamps on reservoir
New expansion tank
New secondary air pump mounting bolts
This all came when I found out my fan was wired with an aftermarket temp sensor and would not turn on with the AC, and would also cause my fan to only fun at high speeds. Also found a leak in the lower radiator hose fixed with a black tar substance, zip tie and tape. The water return hose was eaten away from ATF that was leaking from the reservoir, and my expansion tank had a hole in it.
2001 330i
Great Service, Great Prices
Ryan Gangemi Motorworks
http://www.ryangmw.com
djack12 is offline   Reply With Quote
Old 10-16-2010, 10:41 AM   #1069
tb330
My Ride: 2006 Acura TL
BMW Performance Intake
tb330 is offline   Reply With Quote
Old 10-16-2010, 11:50 AM   #1070
chris98891
My Ride: '16 X6 50i
Send a message via AIM to chris98891
Oil/filter change
Replace valve cover gasket
replace spark plugs
replace cabin filter
replace intake filter
replace fuel filter
seafoam
-Chris
chris98891 is offline   Reply With Quote
Old 10-16-2010, 09:39 PM   #1071
RGO325CiC
My Ride: '01 325Ci 'Vert
Windshield. OEM glass cost me $635 and a 2-week wait.
'01 325CiC
- Steel Grey Met; Tanin Red leather; Myrtle trim; etc.
RGO325CiC is offline   Reply With Quote
Old 10-17-2010, 06:56 PM   #1072
Manny330
My Ride: 02 330i
Send a message via AIM to Manny330
washed and waxed it
Stock
Manny330 is offline   Reply With Quote
Old 10-17-2010, 07:01 PM   #1073
franz
My Ride: 03 330i
BMW Performance Composite front rotors, Carbotech XP10 pads.
franz is offline   Reply With Quote
Old 10-17-2010, 07:06 PM   #1074
Gheybe
Gheybe's Avatar
My Ride: F80 M3
Akebono brake pads all around.
Coolant top off.
Cleaned interior including all my alcantara parts.
will be washing my car tomorrow.
Gheybe is offline   Reply With Quote
Old 10-17-2010, 07:45 PM   #1075
theinfamousdrew
you jinxed me....i think it did...or cracked the thermostat housing...i have a slight drip coming off of the bottom of the motor
it looks like its coming from the lower rad hose near the thermostat or from the housing it self
Old 10-17-2010, 07:56 PM   #1076
jessief29812
My Ride: 2002 bmw 330xi
filled up gas
jessief29812 is offline   Reply With Quote
Old 10-17-2010, 08:13 PM   #1077
Sansho
My Ride: 2001 325i
Replaced CCV.
Sansho is offline   Reply With Quote
Old 10-17-2010, 08:43 PM   #1078
Marcus-SanDiego
My Ride: 2008 X5
Coolant top off.
Unless it's raining again.
Marcus-SanDiego is offline   Reply With Quote
Old 10-17-2010, 08:48 PM   #1079
tcphoto
My Ride: E92 335 MT Coupe
I have only owned my E46 for ten months and the only problems I have experienced is a dead windshield washer pump and front brakes. Friday, I went out to head to work and the dashboard lights went crazy and it would not start. After reading the posts regarding the subject, I called Autozone and had them hold their last 94R-DLG. It comes with an eight year warranty, three year free replacement for $145. I brought it home, installed it and it fired up on the first attempt. I won't even guess how much my local stealership wants for the same part but I am confident that it would be at least twice what I paid. Just as a prank, perhaps I will call tomorrow and ask.
tcphoto is offline   Reply With Quote
Old 10-17-2010, 08:54 PM   #1080
xFalleNx330Ci
My Ride: '01 330Ci
Decided to post it for sale
Sent from my DROIDX using BimmerApp
Originally Posted by beingdevious View Post
OT is like a bunch of rabid horny monkeys that run around and rape other forums, any new monkeys, and then throw **** at eachother, take pics, and demand nudes.
xFalleNx330Ci is offline   Reply With Quote
Rate This Thread
