Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 07-21-2012, 01:15 AM   #10981
zhenkaaaM3
My Ride: Fst'r then your e46
Originally Posted by Ophidian_PR1M3 View Post
DIY around $200. $1000 at a shop
Definently not $1000 at a shop. Id say, no more then $400 at a shop.
zhenkaaaM3 is offline   Reply With Quote
Old 07-21-2012, 01:20 AM   #10982
Ophidian_PR1M3
My Ride: 2004 BMW 325ci
If you can find a shop that will do it for $400, then they have clearly never worked on a BMW starter before. It's a big project
Ophidian_PR1M3 is offline   Reply With Quote
Old 07-21-2012, 10:08 AM   #10983
j@fer87nyc
My Ride: WHITE 02 BMW 330ci
Originally Posted by J1Productions View Post
Do you feel a noticeable difference in power with the 330 compared to the 323i? Or is it pretty similar.
completely different bro the 323 convertible was heavier than a freaking truck and because of that it wasted mad gas i was getting like 17/24 mpg driving normally // this one is as light as a feather and way faster and is great on gas when you drive it normally about 19/30 mpg driving it normally but we all know that it is a whole different story when you punch it
there she is
btw anyone knows whats up with these rims ? are they even bmw rims?
11FB1CF4-1174-4B9C-A3B5-79321D08CCC5_4
11FB1CF4-1174-4B9C-A3B5-79321D08CCC5_5 - Copy
11FB1CF4-1174-4B9C-A3B5-79321D08CCC5_3 - Copy
j@fer87nyc is offline   Reply With Quote
Old 07-21-2012, 11:48 AM   #10984
zhenkaaaM3
Clearly this was one of the sponsered shops on this forum. So i am sure they no wut they were doing
Eugene
Former E36 M3 Owner + E46s
Old 07-21-2012, 01:15 PM   #10985
Crestwood1001
My Ride: 2001 325xi
Cleaning out my glove box today and realized my car does have the slot for the rechargeable flash light anyone know a good place to get one that's not crazy expensive? And does anyway know if the OEM first aid kit would work in an 01 sedan?
Crestwood1001 is offline   Reply With Quote
Old 07-21-2012, 01:18 PM   #10986
RKiepper
My Ride: 1999 E46 328I x2
Ok, so the HCV is normally open at all times.. Didn't know that. Mine isn't getting the signal or power to close, which is why I'm not getting cold air with the AC on.
Anyone know why?
Fault code? HVAC controller?
Searching didn't bring any help..
RKiepper is offline   Reply With Quote
Old 07-21-2012, 01:20 PM   #10987
aeorozco
My Ride: 2000 323i
Send a message via Yahoo to aeorozco
Replaced both upper and lower intake boots today, just found a leak on the ps res and the house under it along with the pressure line car never leaves a drop of oil in my garage and the res is always full so it must not be a big one.....fml it never ends!! Lol
Sent from Droid Charge
2000 323i ........Stock for now
aeorozco is offline   Reply With Quote
Old 07-21-2012, 01:21 PM   #10988
RKiepper
Buy one on eBay, and convert it to LED. This isn't the cheapest route.. But it's the most 'OE' route that will give you a bright enough light.
First aid bins should all be interchangeable.. You just need the brackets if your car does not already have them.
Old 07-21-2012, 02:09 PM   #10989
Crestwood1001
My Ride: 2001 325xi
Thank you sir. Are all the lights the same or did the connectors change over the years?
Question guys, whenever you use the heat in my car the low coolant light comes on and then goes off when you shut off the heat, then comes on the next morning for a few mins.... Wtf? Haha
Old 07-21-2012, 02:18 PM   #10990
vbfronkis
My Ride: 2001 325iT
Originally Posted by E46_330i_Stud View Post
Leverage will still work. Turn the wheel to the left/right depending on what side your working. Boom! Room to fit a wrench with a pipe on it.
Tried it, totally worked. My 1 hour brake job turned into a 3 hour job though. Two of the four bolts were frozen and one of those two had a deformed head. Had to use a file to re-shape it so my socket would fit over it.
But, job's done. Now heading off to the parts store for a new air filter, cabin air filter, spark plugs and some cleaner so I can clean my idle control valve when I pull it tomorrow.
2001 325iT, manual
vbfronkis is offline   Reply With Quote
Old 07-21-2012, 02:18 PM   #10991
RKiepper
NP. The lights are all the same IIRC. I gutted mine and put in a small cordless house phone battery/LED.
Your coolant system either has some air in the system(heater core), or it's just a bit low. Mine did this thanks to a leak in a heater hose. Your engine pushes coolant up into the heater core, which draws out coolant from your expansion tank. Not a big scary fix, but I'd check for wet hoses anyway.
Old 07-21-2012, 02:34 PM   #10992
illestminimike
My Ride: Project Drama
Think I'm gonna take it to autocon today. Anyone else going?
Old 07-21-2012, 02:34 PM   #10993
Crespo5190
My Ride: 2001 325CI
How much is it to get in?
-Tony
Crespo5190 is offline   Reply With Quote
Old 07-21-2012, 02:37 PM   #10994
illestminimike
10 bucks with the flyer. I can give one to you and anyone you bring. Down to caravan it? Lol
Old 07-21-2012, 02:45 PM   #10995
Crespo5190
My Ride: 2001 325CI
Hmmm I'm beginning to get interested. Where is it at?
-Tony
Old 07-21-2012, 02:56 PM   #10996
illestminimike
Santa Anita Racetrack. Gate 1. 15 minutes away from you. Last year was really sick.
Old 07-21-2012, 03:00 PM   #10997
Crespo5190
My Ride: 2001 325CI
Ugh. That means I have to wash my car -___ lol sounds like fun. What time?
-Tony
Old 07-21-2012, 03:45 PM   #10998
BeastModeAaron
My Ride: 323i
Added 2 decal stickers, Brought up my Horses (:
BeastModeAaron is offline   Reply With Quote
Old 07-21-2012, 07:39 PM   #10999
dawnpatrol53
Banned User
My Ride: 2004 330ci
Installed led interior lights from khoalty and was pleasantly surprised by their quality given their price compared to some of the other kits out there. They look great as well. Also ordered stett intake boots to get rid of my vacuum leak forever.
dawnpatrol53 is offline   Reply With Quote
Old 07-21-2012, 07:56 PM   #11000
illestminimike
Autocon was way too hot. I left after 30 minutes. Couldn't stand the heat.
Rate This Thread
