Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 09-08-2012, 11:46 AM   #11961
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Originally Posted by trj View Post
After re- doing VCG 3 times last week, I ordered a new one yesterday. It was victor reinz that i replaced around 5 months ago. It suddenly developed a leak at the front, after removing and installing 3 tomes last week, i was able to stop the leak for a week. Now its leaking again in the back side.
I ordered elinger this time. If this leaks as well then I will just get a new VC.
So I finished a little bit ago, and as someone wrote here recently, the OE seems more rubbery than the reinz. We'll see!
I checked mine thoroughly for cracks and didn't see any. Also heard that reinz had changed suppliers of rubber...and mine coming out did see stiffer than I'd have expected after a relatively short time...under a year.
Might be many of us have suffered from this bad batch of rubber.
Anyway, I remember my first time and it was nerve wracking, as it was the most significant diy I'd done at that point...iirc. This time a relative breeze. Won't say I enjoy it...but without break time...figure maybe 1.5 hours or so. Waiting for rtv to harden a bit before starting it...just coz!
Fingers crossed!
See me in June!
dmax on Facebook
Mangofy your E46!
Old 09-08-2012, 11:55 AM   #11962
Crestwood1001
My Ride: 2001 325xi
I used OEM the second time and it felt like much better rubber, the non OEM one I used the first time was rock hard after a month
Crestwood1001 is offline   Reply With Quote
Old 09-08-2012, 02:29 PM   #11963
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Drove her in the rain to pick up a scanner
Old 09-08-2012, 02:42 PM   #11964
trj
My Ride: 325Ci
Fingers crossed!
Just came back re-tigthening the bolt where I was leaking again.
Have to keep it from leaking at least till the new elring gasket arrives.
1.5 hours it is for me too. May be even faster as I have done 3 times already in last week. I guess I can remove the VC and all the screws blindfolded now.
I have broken the studs for VC before because of over torquing, so be careful. And those pesky little suckers are not cheap at the dealership. Even online, the cap nut is $5 and the stud is $1. Dealers: cap nut $9, and the stud $4.
Last time I did the VCG, I started the car after full 24 hours. Wanted to make sure it doesnt leak because of RTV not reaching the cure time. And then I get a leak from the opposite side.
Old 09-08-2012, 02:50 PM   #11965
tamb
My Ride: 323i se
trying too get it too run bye 2000rpm lol
tamb is offline   Reply With Quote
Old 09-08-2012, 04:30 PM   #11966
Fajitas
My Ride: 04 E46
ATF reservoir and return hose, Heater control valve, Mtech II front bumper, rear brake pads, replaced hazard light and door lock combo switch, cabin air filter.
Fajitas is offline   Reply With Quote
Old 09-08-2012, 05:37 PM   #11967
zwei e46
My Ride: '99 323i & '05 325xi
Replaced the fsu on the 323 today. I watched Solidjakes vid and checked-out a few other DIY threads. Job was MUCH easier than I anticipated. The only thing I changed up was removing the plastic air duct. Read where someone did that and it helped alot with visibility. My original fsu was screwed in.
Thanks go to this forum and Solidjake for once again making me not afraid to tackle things with our cars and saving us money!
zwei e46 is offline   Reply With Quote
Old 09-08-2012, 06:01 PM   #11968
Solidjake
Zero. Leaks.
Solidjake's Avatar
Nice man! How's the airflow now?
Old 09-08-2012, 06:19 PM   #11969
zwei e46
Strong and steady! Thanks again.
Old 09-08-2012, 06:25 PM   #11970
deadwood83
My Ride: has an iron lung
Send a message via MSN to deadwood83
Removed the entire center console
Installed kill switch for meth and separate switch for V1
Ran the wires for the ash tray concealed display
Began stripping the center console in preparation for a refinish
Ran AEM meth controller, boost line, and wires to the trunk
AA Stg2+ 325xiA? Are you stupid? Maybe a little.
I can program cars fo' freeee near Salt Lake City. PM for details.
deadwood83 is offline   Reply With Quote
Old 09-08-2012, 06:42 PM   #11971
dmax
dmax's Avatar
We'll see...I used oe, ultra black, and didn't follow the directions quite right! Oops. G-d damn it!
It says apply rtv, tighten down immediately, then wait an hour to tighten it down another 1/4 turn. Well, I just went down in stages all around and we'll see.
I'd read about the screws many times...since I know the torque is nothing, I basically just stopped at the stop and went tight. All unbroken...but I still have a spare screw from years ago just in case! Thanks for the warning though! This time I also ignored the instructions to just do the half moons at the corners and did the entire half moon.
I'll confess if it leaks again!
See me in June!
dmax on Facebook
Mangofy your E46!
Old 09-08-2012, 06:56 PM   #11972
///MPR77
My Ride: 02 ///M3 Tri-Ped
Fingers crossed!
My Reinz VCG is leak free so far. When you pointed out a few months ago that my tightening pattern was incorrect, I pulled it off again, then reseated, and tightened it from the center studs to the outer ones, and everything has been good. (Torqued to 6ft/lbs)
Thanks BTW
I did notice the Reinz gasket has some extraneous "flappage"(not flush with the VC) just parallel to the SAP, but it certainly hasn't leaked yet.
Today:
I pulled out one of my EE projectors, baked it at 200F so that I could remove the clear cover to wipe what I thought was some condensation residue, but when I pulled it apart, and went to wipe it; it was this ultra fine grey dust, which wiped right off.
Old 09-08-2012, 07:06 PM   #11973
tock172
My Ride: '12 135i Dinan S2
Back when I did my VCG almost 15,000 miles ago, I used a genuine BMW gasket and ultra black RTV (IIRC). I didn't wait long at all before starting the car afterwords and since then, I have not had a single issue.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 09-08-2012, 07:17 PM   #11974
My Ride: Lexus
I think i need to give it a wash and brush (I brush my interior carpeting instead of vacuuming it) saves electricity, lets me exercise, and saves money... I think I'll do that now.
Old 09-08-2012, 07:18 PM   #11975
My Ride: Lexus
And +1 on Genuine BMW valve cover gaskets. it's what I use along with a brand new Genuine valve cover
Old 09-08-2012, 07:42 PM   #11976
dude14
My Ride: '04 330CI ZHP
Replaced the fuel pump and it took less than an hour. Cleaned the MAF with CRC MAF cleaner. Then gave it very thorough bath. Looks good and runs better!
dude14 is offline   Reply With Quote
Old 09-08-2012, 08:17 PM   #11977
ImSoFreaknWhite
My Ride: '06 M3 SMG VERT
Send a message via ICQ to ImSoFreaknWhite Send a message via AIM to ImSoFreaknWhite Send a message via Yahoo to ImSoFreaknWhite
drive up to LA to pick up a VIS CSL trunk for my vert
Jordan
My Build Thread
l Status Gruppe One-Piece Lip l Anodized CCW Classics w/ Polished Lips l Black Grills/Gills & Emblems l Carbon Fiber Roundels
Status Rear Section l K&N 57 Series CA Intake l OEM JB Hardtop l TM Drilled/Slotted Rotors l D2 Coilovers w/Camber Plates l VIS CSL VERT Trunk
ImSoFreaknWhite is offline   Reply With Quote
Old 09-08-2012, 08:49 PM   #11978
zhenkaaaM3
My Ride: Fst'r then your e46
put on some new wheels =]
zhenkaaaM3 is offline   Reply With Quote
Old 09-08-2012, 09:00 PM   #11979
///MPR77
Pics?
Old 09-08-2012, 09:10 PM   #11980
VIKTR
My Ride: 2002 330ci
Bought matte grilles on eBay
They came in the mail today
I tampered with them to make them fit
Just messaged the seller expressing my desire to return his rubbish
Not sure if I want to purchase a new pair of oem, trust one of the sponsored vendors,
... or glue the originals back into place
VIKTR is offline   Reply With Quote
Rate This Thread
