Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 11-10-2010, 09:19 AM   #1181
GA-e46
My Ride: 2001 325i
wash, clay bar, wax, polished fron headlamps and fog lights, detailed outside, detailed interior and II maintenance
GA-e46 is offline   Reply With Quote
Old 11-10-2010, 10:13 AM   #1182
45jimmy
My Ride: AW M3
Send a message via AIM to 45jimmy Send a message via MSN to 45jimmy
Since last month I've...
Hardwired a valentine 1
Installed an oem short shifter
Bought rubber floor mats
Installed a sound system
DIY homelink
Replaced headlight lenses
Replaced led corner lights
45jimmy is offline   Reply With Quote
Old 11-12-2010, 06:04 PM   #1183
amunoz27e
My Ride: 325ci
Today, I washed and wax my car, reinstalled my keyhole delete on driver door, installed new CF roundel on hood, and steering wheel, and the air scoops.
ID:	383448   Click image for larger version
ID:	383449   Click image for larger version
ID:	383450   Click image for larger version
Bilstein PSS10 Coilovers | Highline Tuning Catback Exhaust | Double Din Audio | Lots of Carbon Fiber Interior/Engine Bay | 19x8,19x9.5 Wheels | RIP - Reiger Body Kit .
amunoz27e is offline   Reply With Quote
Old 11-12-2010, 08:17 PM   #1184
BeMyWhip
My Ride: 01 BMW 330ci
Got my new all season and bigger 265 35 ZR18 Falken 912's for the rear of my car. Love em...
Name:	265 35ZR18 Falkens Asymetrical tread.jpg
ID:	383463   Click image for larger version
Name:	265 35ZR18 Falkens 912 diff view.jpg
ID:	383464   Click image for larger version
Name:	265 35ZR18 falkens 912.jpg
ID:	383465   Click image for larger version
Name:	Back view 265 35ZR18.jpg
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 11-13-2010, 09:57 AM   #1185
theinfamousdrew
My Ride: 911 Turbo / E70
fixed some rock chips and scratches
also installed a new shift boot for the RSX
theinfamousdrew is offline   Reply With Quote
Old 11-13-2010, 01:02 PM   #1186
jcha7134
My Ride: 2002 325i sedan
bathed her softly..
life is tough..
...and tougher when you're stupid.
Photobucket
jcha7134 is offline   Reply With Quote
Old 11-13-2010, 01:44 PM   #1187
Miko_10
My Ride: 330i 5 Spd
Oil change.
Emissions test - Passed.
FS(PM me if interested, MID Atlantic Area, 22307 zip)
- 2 M68 fronts w/ winter tires, local pick up preferred,
- OEM Pre face Sedan Clears.
Miko_10 is offline   Reply With Quote
Old 11-13-2010, 01:53 PM   #1188
TerraPhantm
My Ride: M3 & ZHP
enabled the triple flash turn signals on my car (like the newer BMWs)
Old 11-14-2010, 02:29 PM   #1189
theinfamousdrew
i want this! lol...mine is too old
Today was paint day....
painted my keyhole delete (it looked like crap), reflectors, and emblem
Old 11-14-2010, 03:15 PM   #1190
zhpfan4life
My Ride: 2004 BMW 330ci ZHP
Just finished an oil change and hit 80000 miles today. =]
Mods:
Eurospec Exhaust, 19"VMR VB3's, Tint, BMW Performance CAI, and more to come...
zhpfan4life is offline   Reply With Quote
Old 11-14-2010, 03:50 PM   #1191
TerraPhantm
My Ride: M3 & ZHP
So's mine - I had to get an LSZ from a 2006 car.
Old 11-14-2010, 06:15 PM   #1192
325iExecutive
My Ride: an immigrant like me
Replaced nonsport seats with sports that I picked from a used parts retailer.
2005 - 325i
2008 - Mazda CX9
325iExecutive is offline   Reply With Quote
Old 11-14-2010, 06:23 PM   #1193
jookdoree
My Ride: 2005 330ci Coupe e46
installed OEM base roof rack system and Yakima FatCat6 snowboard rack
http://forum.e46fanatics.com/showthr...e=2&highlight=
Thanks~!
jookdoree is offline   Reply With Quote
Old 11-14-2010, 06:26 PM   #1194
The_Don
My Ride: 2001, 325Ci
Installed lumbar support in my seats.
Got the parts from premium seats that were left at my house when I sold my sport seats.
The_Don is offline   Reply With Quote
Old 11-14-2010, 06:29 PM   #1195
zhpfan4life
How do you do the turn signal thing? That is sick!
Mods:
Old 11-14-2010, 06:40 PM   #1196
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
friday. played around with the nav/bluetooth/sirius.
car has been parked up and untouched all weekend.
delmarco is offline   Reply With Quote
Old 11-14-2010, 06:52 PM   #1197
Zyaltr
My Ride: 01-325cic,08-750Li
Did this...lots of fun~!
How to clear the convertible's drain holes
I've searched long and hard and I've not found a "how to" for clearing the drain holes at the front of the convertible cover well. So here goes...
Tools required (Image01)...
1. 1/4" ratchet drive
2. 3" extension (1/4")
3. 6" extension (1/4")
4. 10mm socket (1/4")
5. 8mm socket (1/4")
6. 7mm socket (1/4")
7. 3/8" ratchet drive
8. 3" extension (3/8")
9. 6" extension (3/8")
10. 13mm socket (3/8") - deep socket optional
11. 5mm hexagon head socket (Allen head) (3/8")
12. Snipe-nosed pliers
13. Forked upholstery tool
14. 13mm ratchet ring spanner
15. 10mm ring spanner (ratchet optional)
16. Stanley knife
17. A ground toothbrush to retrim the car without scratching the paintwork
18. Some wood to hold the roof and roof compartment
19. Foam to support front of roof
20. Compressed air supply and hose
21. Water hose
22. Towels
Stage 1 - Preparation
1. Fully lower the roof.
2. Remove the rear seat and store it safely. [Tools 1, 2 & 4]
3. Remove the middle side trim panel (part with armrests) - both sides. Thde two bolts are in each armrest and need to be removed. [Tools 1, 2 & 5] Any trim clips should be removed using tool 13 if possible (see Image02 B). Remove any clips from the car and attach to the trim before refitting. Disconnect the tweeter cable (see Image02 C).
4. Disconnect the slide cover return spring (see Image03) - both sides [Tool 12].
5. Remove the small upholstery rivet (see Image04) - both sides [Tool 13].
6. Remove the upper side panel - both sides. Three bolts (see Image02 A) to be removed [Tools 1,2 & 6].
7. Remove the lower side panel -both sides. Slide the trim upwards to remove. Again remove any trim clips from the car and fit them to the trim. [Tool 13]
Stage 2 - Lifting the roof
1. Operate the roof so the rear of the roof and the opening comparment are as high as possible.
2. Chock open the roof and the compartment (see Image05 & Image06)
3. Using Tool 15 disconnect the hard top attachment and move it aside (see Image07 A) - both sides.
4. Using Tools 7, 8 & 11 disconnect the cover lock (see Image 07 B) - both sides. Be careful not to drop the Allen headed bolts. Note any witness marks for refitting.
5. Release the cables from the catches (see Image08) to allow the lock to be moved aside.
6. Loosen the nuts holding the roof onto the bracket (Image09, Image10 & Image11) - both sides. [Tools 7, 9,10 & 14] Note witness marks for refitting.
7. Support the front of the roof using foam or such like.
8. With the aid of an assistant remove the nuts.
9. Manoeuvre the roof so you can see the drain hole (see Image12).
Stage 3 - Clearing the blockage
1. Attempt to clear the blockage using a hose and compressed air.
2. Test with a water hose.
3. Use the towel to soak up any spillages. Micro-fibre towels are ideal.
4. Use the knife to cut through the sound-proofing under the seats as water is bound to collect here.
5. If you need more access, you can remove the roof bracket. You will need a 13mm ratchet ring spanner to do this [Tool 14].
Stage 3a - Removing the roof bracket
1. Behind the bulkhead (Image11) you should be able to see a 13mm nut. Loosen this nut. Do not remove it yet (or you may never see it again!) [14]
2. Remove the nuts shown in Image13 and Image14. [Tool 7 & 10]
3. Remove the nut attached to the stud next to the drain hole in Image15. You will need to use Tool 14 to do this.
4. Remove the loosened nut behind the bulkhead. You will be able to use the play in the bracket to get your fingers in the gap to retrieve the nut. [Tool 14]
5. You will have much more access to the drain hole and should be able to clear any blockages.
Zyaltr is offline   Reply With Quote
Old 11-14-2010, 07:17 PM   #1198
TerraPhantm
My Ride: M3 & ZHP
You need to get an LCM that's 09/2005 or newer (it should be uncoded if you don't want to have a tamper dot) and then enable the triple flash signals through coding
Old 11-14-2010, 07:25 PM   #1199
5speed5er
My Ride: TreTreFive
Changed oil and washed
5speed5er is offline   Reply With Quote
Old 11-14-2010, 07:37 PM   #1200
slammin_330
My Ride: is no ZHP.
Washed it. I hate cleaning wheels.
1974 Jensen Healey
1988 524Tds/5
1994 550iT/6 (Gristle Hammer)
1995 318Ti Clubsport
2001 Discovery 2, M54B30 swapping
2003 330i/5
slammin_330 is offline   Reply With Quote
Rate This Thread
