Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 09-09-2012, 03:56 PM   #12001
325inthe510
My Ride: 152ci of madness
Originally Posted by HyeWarrior View Post
Curbed one of my wheels
Pics
325inthe510 is offline   Reply With Quote
Old 09-09-2012, 03:58 PM   #12002
vbfronkis
My Ride: 2001 325iT
Speaking of my interior trim... Here is the passenger side front door. It used to be wood grain. I started with the driver's door and it was okay (may do it over) but on my second one (this one) it came out pretty good. No air bubbles and nice and tight around the edges. Took my time.
I'll wait to do the hardest pieces at the end when I've had more experience with the simpler ones.
2001 325iT, manual
vbfronkis is offline   Reply With Quote
Old 09-09-2012, 04:48 PM   #12003
HyeWarrior
My Ride: '03 325i --> '13 GTI
Originally Posted by 325inthe510 View Post
Pics
Damn LA roads. Was going down a narrow residential street on a windy hill, cars parked on both sides. Car was coming down the other way WAY faster than they should have been going, so I tried getting out of the way by getting in someone's driveway. I didn't notice that the entrance to their driveway was so damn high. First time I've ever curbed a wheel, **** sucks
Oh well, time for a new set, FS thread coming soon
Wow
So Amaze
Much Torque Steer
Such FWDoge
HyeWarrior is offline   Reply With Quote
Old 09-09-2012, 05:50 PM   #12004
kaldE46
My Ride: 2001 325i
Replaced fuel pump, washed and waxed the car.
kaldE46 is offline   Reply With Quote
Old 09-09-2012, 08:07 PM   #12005
tock172
My Ride: '12 135i Dinan S2
Today, for the 3rd time, I removed and reinstalled my rear brake pads in an effort to stop a persistent, loud, high pitched squeal during low speed braking. Went for a test drive and it's already back.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 09-09-2012, 08:28 PM   #12006
ImolaSix
My Ride: '02 330Ci M-sport
What brand of pads are you using?
ImolaSix is offline   Reply With Quote
Old 09-09-2012, 08:33 PM   #12007
briangl92
My Ride: VQ37VHR
Better question is what brand of anti-squeal are you using? I had an issue where mine squealed while hot at low speeds. I switched from brake paste to brake lubricant with ceramic. It's secondary function is a noise suppressant. I painted that stuff on the back of the pads and problem solved.
briangl92 is offline   Reply With Quote
Old 09-09-2012, 08:54 PM   #12008
ImolaSix
I didn't apply any anti-squeal to my Pagids and they have never made any noise hot or cold. I guess the shims that came with the pads are doing their job very well.
Old 09-09-2012, 08:56 PM   #12009
briangl92
My Ride: VQ37VHR
I was running Pagids They'd only do it when they were excessively hot though.
I'm running Jurids with that ceramic brake lube now and they're quiet.
Old 09-09-2012, 10:24 PM   #12010
zhenkaaaM3
My Ride: Fst'r then your e46
Bought a few goodies.
zhenkaaaM3 is offline   Reply With Quote
Old 09-09-2012, 10:35 PM   #12011
E46Moonlight
My Ride: 2000 323i
Oh do tell us!
E46Moonlight is offline   Reply With Quote
Old 09-09-2012, 10:38 PM   #12012
SATX_E46
My Ride: 2003 325i
Right rear door window regualtor
SATX_E46 is offline   Reply With Quote
Old 09-09-2012, 11:30 PM   #12013
ImolaSix
I guess my pads weren't getting as hot due to the larger brakes on the 330.
Old 09-09-2012, 11:33 PM   #12014
briangl92
My Ride: VQ37VHR
I was fading my setup. I have a mountain road as a commute. I've upgraded to 330 spec front and haven't had a problem with the size/brand/slotted setup. My 325 setup is consequently for sale
Old 09-09-2012, 11:53 PM   #12015
tuscan1205
My Ride: 325CI
bought this.
maybe this will help fix my passenger headlights auto leveling issues.
'02 Orient Blue 325Ci
tuscan1205 is offline   Reply With Quote
Old 09-10-2012, 12:14 AM   #12016
tock172
In July, I replaced my old pads with Textar pads and Zimmermann rotors. The Textar pads experienced a consistent high speed squeal, and Mango said he ran into the same issue and couldn't solve it either until he want swapped his Textar pads out for Ate. I was originally going to replace my Textar pads with Jurid, but then I chose Ate instead. So here I am. Both brands worked fine in terms of braking and produced the normal amount of dust, but the noise sucks.
My textar pads were installed with little to no anti-squeal. When I put on the Ate pads, I originally used a small amount of the CRC red paste. In 2 of the 3 times I removed and reinstalled since then, I applied varying amounts of the red paste in different areas. No help. Today, I reinstalled the driver's side rear pads with no form of anti-squeal, and I installed the passenger side with small amounts of Permatex Brake caliper lube which, according the packaging, can be used as anti-squeal. The squealing is definitely reduced, but still present. I haven't been able to pinpoint which rear wheel it's coming from now.
And of course I also discovered my driver's side rear style 68 wheel is ****ing bent. Thank you massive pothole. ****. Is the city of San Diego going to pay for that? Give me a break.
Old 09-10-2012, 12:14 AM   #12017
Imola.ZHP
My Ride: Imola ZHP
Originally Posted by tuscan1205 View Post
bought this.
^ is that the piece that attaches to the passenger side lower control arm? I broke mine when I installed my cup kit. What did it cost you?
Airbag light came on, lord, if its not one thing with this car, its another...
-- '03 330i ZHP
-- Marcus
Imola.ZHP is offline   Reply With Quote
Old 09-10-2012, 12:35 AM   #12018
NightRaider93
My Ride: 2007 Z4 Coupe
Ah the joys of owning a BMW.
-Spencer
NightRaider93 is offline   Reply With Quote
Old 09-10-2012, 01:41 AM   #12019
KrasivataSabine
My Ride: 323Ci
Originally Posted by E46Moonlight View Post
Oh do tell us!
I'm out of the country so I'm just missing my E46 for now... gathering dust in my garage
#BattleBimmer #323RS
KrasivataSabine is offline   Reply With Quote
Old 09-10-2012, 08:31 AM   #12020
Hornung418
My Ride: '04 MB ZHP
That's the headlight motor.
Sent from my DROIDX using Bimmer App
Hornung418 is offline   Reply With Quote
Rate This Thread
