Thread Tools Search this Thread Rating: Thread Rating: 32 votes, 4.00 average.
Old 09-14-2012, 01:09 PM   #12141
M3Newb
My Ride: E46 M3
Originally Posted by RKiepper View Post
The eBay versions claim to be made from the newer material.. But I don't think anyone actually has evidence to support that.
Beisan systems are owned by the guys who identified the cause of the problem, and found a way to fix it first. So I went with them.
I looked at the eBay versions for a while, and got beat out on eBay again for Beisan products that owners never installed before selling their car.
Actual Beisan products showing up on eBay doesn't happen very often.
I'd go with the Beisan route, $65 for some seals sounds like a lot, but you'll spend that much in gaskets if you have to do it again due to using a potentally inferior product from eBay.
Would the loss in hp and torque that they mention really be that noticeable? Seems unlikely
The guy i bought it off of just had the BMW inspection II done. I googled it and cant believe everything that it covers. Hopefully im good to go for a while.
M3Newb is offline   Reply With Quote
Old 09-14-2012, 02:06 PM   #12142
moiz21
My Ride: 1999 323i 5-SPD
In some instances the difference is very noticeable, in others not so much. It depends on the degredation of your current seals. Also, these seals are not something that BMW officially acknowledges. So that is not covered under Inspection II.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 09-14-2012, 02:15 PM   #12143
M3Newb
My Ride: E46 M3
Hmm, might be something I need to check out then, ive got 117,000 miles
Old 09-14-2012, 02:18 PM   #12144
RKiepper
My Ride: 1999 E46 328I x2
^this is true..
I believe there's going to be more of a placebo effect then actual gains. But there should be an increase in engine performance and smoothness nonetheless.
BMW may acknowledge the problem one day, so keep your receipt handy when they do.
If a dealer were going to do vanos work under warranty, I'd get the seals and rattle kit(ZHP ONLY?) and try to get them to install them for me, or get access to the part before hand so you could do it.
RKiepper is offline   Reply With Quote
Old 09-14-2012, 02:22 PM   #12145
JZambrano7
My Ride: 2003 325xi
Cracked coolant tank. Replacing it now
-JZ7-
JZambrano7 is offline   Reply With Quote
Old 09-14-2012, 06:58 PM   #12146
randman1
My Ride: 03 330ci
Black corners
randman1 is offline   Reply With Quote
Old 09-14-2012, 07:28 PM   #12147
babinski46
My Ride: 1999 BMW 328I
Today was fluid day! Oil, MTF, Diff fluid. Probably should start a retroactive rebuild thread, just too much stuff to list right now.
babinski46 is offline   Reply With Quote
Old 09-14-2012, 08:50 PM   #12148
PH03NIX46
My Ride: Phoenix Yellow ///M
A nice wash and vacuum.
PH03NIX46 is online now   Reply With Quote
Old 09-14-2012, 09:55 PM   #12149
JasonSmithed
My Ride: 00 323i
Dun dun it all
Sent from my SCH-I510 using Bimmer App
JasonSmithed is offline   Reply With Quote
Old 09-14-2012, 09:55 PM   #12150
JasonSmithed
My Ride: 00 323i
Originally Posted by randman1 View Post
Black corners
Sexy
Old 09-14-2012, 11:19 PM   #12151
Skchamaa11
My Ride: 2001 BMW 330ci
washed and waxed
Whether you win by a inch or a mile winning is winning
Skchamaa11 is offline   Reply With Quote
Old 09-15-2012, 12:02 AM   #12152
E46tknv
My Ride: Fst'r then your e46
Washed
E46tknv is offline   Reply With Quote
Old 09-15-2012, 12:19 AM   #12153
trj
My Ride: 325Ci
Angel eyes on again. Great warranty honor from umnitza.
Made the ramps from the home depot 2x10s.
Finally dont have to use the stupid widow maker jack to get the floor jack under the car.
trj is online now   Reply With Quote
Old 09-15-2012, 12:21 AM   #12154
NightRaider93
Waka Waka Waka
My Ride: 04 325i
Pretty sure my power steering went out..and something is squealing in the engine somewhere.
-Spencer
NightRaider93 is online now   Reply With Quote
Old 09-15-2012, 01:13 AM   #12155
///MPR77
My Ride: 323i ZSP/ZPP
Do you have any lights on the cluster? "Red Battery light"
Originally Posted by ///MPR77 View Post
Some say his notoriety is so profound, that he was able to drop the e46 in his name, and just like "The Highlander" there can only be one....all we know is he is called "Mango"
Old 09-15-2012, 01:22 AM   #12156
nightrunner20
My Ride: will eat your dust
Send a message via AIM to nightrunner20
looked at it in disgust and thought about how it should have been an m3.
nightrunner20 is offline   Reply With Quote
Old 09-15-2012, 01:50 AM   #12157
RKiepper
Hit an owl.. I have feathers, bird ****, and blood all over my hood. Yay...
Old 09-15-2012, 06:37 AM   #12158
deanthedude1977
My Ride: bmw e46 325i sport
just finished doing my rocker cover gasket(valve cover gasket)---easy enough job was a nightmare trying to get the cover off though used a paint scraper and gently prised up...
I done it as oil was leaking into plugs and a little at back of engine..
deanthedude1977 is offline   Reply With Quote
Old 09-15-2012, 09:53 AM   #12159
Mr.Makeveli
My Ride: 2001 325i(sedan)
Washed & waxed
Mr.Makeveli is offline   Reply With Quote
Old 09-15-2012, 10:55 AM   #12160
shata
My Ride: 00 328i , 06 330i
if you want to risk doing all the work twice to save $7... go for it!
I agree, Its not worth 7$ to have to do the job twice plus the cost of the real deal.
I Have 162k on mine and finally am doing mine for this winter, The Vanos problem is noticeable in cold on my car. Going to be so happy when thats finally fixed.
/// 2000 BMW 328I ///
shata is offline   Reply With Quote
Rate This Thread
