Rating:
#12321 |
Grand Superpatriot
I took mine apart completely and cleaned them. it's not enough to just wipe them as you see it. (you'll see what i mean when you look closely)
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#12322 |
Waka Waka Waka
Got control arm bushings replaced, power steering fixed, and oil change.
-Spencer
#12323 | |
My Ride: 2003 325xi Touring
new MAF. $270 GONE... it was worth it though.
![]() Shes not your average grocery getter. This 2.5L of fury doesnt mess around. Quote:
#12324 | |
100% star stuff
![]() Bilstein/Eibach B12 Pro-Plus Suspension System | DICE Mediabridge | Valentine One |
#12325 | |
#12326 |
Besides, even if they did start yellowing, I'd take the $180 I saved over OEM and buy some polish
#12327 |
Waka Waka Waka
My sides don't fit at all and they're yellowing.
-Spencer
#12328 |
Installed a Shark injector, Intake, and Strut Tower Brace today on my 330xi.....#POPPIN!!!
#12329 |
Ordered some smoke film from ebay, going to attempt to overlay the clear on my R/C/R tails, do the front corners and try the side markers, I'm thinking they probably have too many angles though, maybe a heat gun can work some magic though, basically shrink wrap them...
Thinking its time to loose the roof rack for awhile...
![]() -- '03 330i ZHP -- Marcus |
#12330 | |
Sent from my SPH-D700 using Bimmer App |
#12331 |
Ordered Meyle HD control arms
#12332 |
Modded ///Member
Love mine! Car drives so much better.
#12333 |
My Ride: 2000 BMW 3XXi ZSP
After replacing my Control arms/bushing yesterday, I took Sally-Sue in for an alignment and lastly I restored the Shark Injector to my newly flashed M52TUB28 head.
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA NCC Member Recognition Chairman NCC High Performance Driving School Registrar NCC Auto-X BOD Liaison DIY Senior Committee Coordinator 2006 E90 325Xi & 2000 E46 3XXi " Vision without resources is just hallucination" |
#12334 |
Put in a new mass air flow sensor, cleaned my k&n air filter, and gave it a bath.
Sent from my SPH-L710 using Bimmer App |
#12335 |
Pads and rotors. Wagner crossdrilled.
New clamps on PS reservoir. Socket repair for tail lights and turn signals. |
#12336 |
Mod
Sorry to do this to you man but an OEM maf is $144 shipped on bmaautoparts.com
Follow my cross country drive to Bimmerfest West 2013
http://forum.e46fanatics.com/showthread.php?t=987217 ![]() Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide |
#12337 |
Grand Superpatriot
^ +1. Today I replaced my dip-stick o-rings. old ones weren't that bad to be honest but they are squared off a little (as opposed to round like the new ones) only like 50 cents for both. no biggy!
oil filter o-rings come next week... some of my stockpile..
#12338 |
Today I gave her a wax and detail, replaced camshaft sensor then went on a drive to show her off.
#12339 |
My car was making a noise from the right rear wheel. After some testing I notices the ebrake didn't work for that wheel. Took off the caliper and rotor then saw this. A fat chunk of the brake shoe ripped off and was spinning around in there.
![]() -2003 M3 Vert -1967 Mini Cooper |
#12340 |
I bought the complete kit from ECS Tuning... Drilled and slotted rotors... Hawk ceramic pads... Stainless brake lines... ATE Super Blue.. Painted the calipers black. I got the fronts done today. It took a while to get the rotor screws out... Then the rotors off. Best way to get the screws out that I found is to bang on them with a hammer and a tool to hit the top of the screw head without mangling the screw itself. Then I had to soak the rotor with WD-40 and let it sit... Then banged them with a 10 pound rubber mallet... They finally came off.
We'll see if I do the rears tomorrow. Having Jack Daniel's right now...
NWS and Advertising Removed.
| Rate This Thread | |
