Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 09-23-2012, 12:18 AM   #12341
Zell
Zell's Avatar
My Ride: so turbo wow
Good stuff. Probably made your idle buttery smooth Or at least smoother.
Old 09-23-2012, 12:18 AM   #12342
AlexBimma
My Ride: BMW 323i 2000
Had same problem with mine... first time i put it on (thought it was on good)... couple days later car wouldn't start.... boot fell off hahah, its on good now
AlexBimma is offline   Reply With Quote
Old 09-23-2012, 12:22 AM   #12343
BeMyWhip
My Ride: 01 BMW 330ci
lol, boot fell off. Yeah you gotta really make sure you line things up and snug it down.
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 09-23-2012, 12:31 AM   #12344
Fajitas
My Ride: 04 E46
Drivers side window regulator for the 4th time in one year.
Fajitas is offline   Reply With Quote
Old 09-23-2012, 01:00 AM   #12345
deadwood83
My Ride: has an iron lung
Send a message via MSN to deadwood83
It's like BMW wanted me to be a meth-head.
AA Stg2+ 325xiA? Are you stupid? Maybe a little.
I can program cars fo' freeee near Salt Lake City. PM for details.
deadwood83 is offline   Reply With Quote
Old 09-23-2012, 01:34 AM   #12346
BeMyWhip
BTW, forgot this pic...
this is the easiest way to get the lower clamp in. position it with clamp bolt head up in the rear of the boot, and use a swivel extention... easy.
then attach the smaller tube and do the same.
Always Mod!!!
Old 09-23-2012, 02:44 AM   #12347
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
Radiator
Thermostat
Water pump
hoses
coolant temp sensor
Expansion Tank
BMW Coolant
Betsy is officially Mango'd
Schlag96 is offline   Reply With Quote
Old 09-23-2012, 04:19 AM   #12348
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Two questions...
What brand is the regulator you are buying and if you have a sedan, did you replace the red clip that goes onto the window?
Old 09-23-2012, 04:26 AM   #12349
Fajitas
My Ride: 04 E46
Originally Posted by Solidjake View Post
Two questions...
The last one was a Dorman which I replaced today with another Dorman because I bought it locally at an autoparts store that offered a lifetime warranty. I have a sedan and have always replaced the clips along with the hex nut and bolt. I've noticed that if I have the window half way down and shut the door it somehow breaks the clips or causes them to dislodge from the glass which in turn causes the regulator to fail.
Old 09-23-2012, 04:34 AM   #12350
Solidjake
Zero. Leaks.
Solidjake's Avatar
I never heard of that brand. At that rate I'd just buy an oem one and see what happens. Maybe lube up the tracks that the glass goes on.
Old 09-23-2012, 06:20 AM   #12351
///MPR77
My Ride: 02 ///M3 Tri-Ped
Originally Posted by ///MPR77 View Post
4 New Tires for my new to me style 119s
Washed it
Weighed it. 3200 lbs
Oil Change.
Doing the cooling system overhaul right now.
Attachment 470491
and canyons at 1am.
3am...Just finished Cooling system maintenance.
I didn't do the return hose, or the heater inlet...yet.
The expansion tank wasn't fully seated, and after buttoning everything back up, I start the bleed, and my 50/50 starts pouring out the bottom...oh noes...
Jacked it back up, splash shield off, poured just water into the ET...leaking begins...pushed like hell on the top of the ET, and the sucker seated, and water quit flowing.
Proceeded to bleed again, and voila, all is well, I think.
Going to do a quick test drive, check again for leaks, and if all is well, then off to the canyons we go.
Old 09-23-2012, 11:00 AM   #12352
BeMyWhip
looked today at the intake boot and found this nice 2' tear....
Always Mod!!!
Old 09-23-2012, 03:28 PM   #12353
DeL2000
My Ride: BMW 323i
For this weekend work: Replace all the pulleys, water pump pulley and steering pump pulley with aluminum, both pulley mechanical tensioner for AC and alternator, idler pulley. Removed the aux fan and clutch fan, and replaced it with an electric fan. Replaced oem control arms/bushings with meyle HD control arms, ball joints and bushing. Replaced both end links. Replace both belts. And last but not least, oil change with mobil 1.
Next weekend: Cooling system overhaul - looking to replace the radiator, expansion tank, hoses, water pump, thermostat for both the engine and transmission
DeL2000 is offline   Reply With Quote
Old 09-23-2012, 03:33 PM   #12354
ZHPSteve
My Ride: 2004 330i ZHP
Replaced the front headlight lens'....now I've realized I really need to replace the turn signals since they look really messed up and old compared to the new lens. Any suggestions on what to go with? I have a Silver 330i ZHP Sedan, I'm torn between going with the clear or just putting in new ambers. I got the lens' from Khoalty and were very pleased with them, any suggestion on who to purchase the lights from?
ZHPSteve is offline   Reply With Quote
Old 09-23-2012, 04:20 PM   #12355
zwei e46
My Ride: '99 323i & '05 325xi
Swapped out the bosch plugs to NGK on the xi.
Also cleaned up some axle grease from recent cv boot replacements. They cleaned the area ok, but not as good as I would like it.
zwei e46 is offline   Reply With Quote
Old 09-23-2012, 04:41 PM   #12356
Solidjake
Zero. Leaks.
Solidjake's Avatar
^ Good move on the NGK's
Flamesuit on
Old 09-23-2012, 09:25 PM   #12357
WDE46
My Ride: 2004 330Ci OBM
Installed Powerflex RTABs. I think it solved my tramlining issue. The rear end is so much stiffer and I think it's a little louder. Still need and alignment. I had purchased a steering flex coupler (guibo) to install also, but I don't think it was necessary, and I can't get to the bolts easily.
Old 09-23-2012, 09:39 PM   #12358
tehcbass
My Ride: bmw e46 323i
I fixed the rear (right) lights... now they're working
also got my front lights polished. looking like new.
tehcbass is offline   Reply With Quote
Old 09-23-2012, 09:45 PM   #12359
RKiepper
My Ride: 1999 E46 328I x2
Flamesuit on
Both of my 328's came stock with NGK's...
Come at me bro
RKiepper is offline   Reply With Quote
Old 09-23-2012, 09:55 PM   #12360
Marinerd
My Ride: 04 xiT, 09 328i
Replaced my Fuel Tank Breather Valve. Got rid of my p0444 code.
Marinerd is offline   Reply With Quote
Rate This Thread
