Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 09-23-2012, 11:47 PM   #12361
serdar255
My Ride: '01 325ci / '90 325i
Originally Posted by BeMyWhip View Post
My new intake tubes are in. the old ones surprisingly were bad. Also removed and cleaned the DISA, ICV, and throtle bore. Very simple except that the head of the nut to loosen my lower boot clamp were facing down; this made it a pain in the PITA to remove... just cut it out the way. Also, install the clamp facing up the next time around.
Did you clean your throttle body, my car is throwing an eml light every few drives and i think its either that or the TPS, if so did you remove it to clean it.
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 09-24-2012, 12:13 AM   #12362
Bemwe_03i
My Ride: 2003.5 E46 M3 smg IR
led signals, clear bumper reflectors, spliters..
Bemwe_03i is offline   Reply With Quote
Old 09-24-2012, 01:11 AM   #12363
tock172
My Ride: '12 135i DCT
Wash, polish, wax, wheel cleaning.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 09-24-2012, 04:12 AM   #12364
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Originally Posted by RKiepper View Post
Both of my 328's came stock with NGK's...
Come at me bro
Come at you for what, you have the right spark plugs in there
Bemwe, your M3 looks super clean. I would have went with the smoked corners though
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 09-24-2012, 08:30 AM   #12365
moiz21
My Ride: 1999 323i 5-SPD
I had that issue on my previous 323. I read that cleaning the throttle body might clear it up. Thankfully after I cleaned it out, the eml light didn't come back. I didn't remove the throttle body though. I just used some brake cleaner and paper towels. Cleaned it out as much as I could without removing it. So much dirty crap came out though, so it must have been that.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
Old 09-24-2012, 10:45 AM   #12366
My Ride: Lexus
Always always always ALWAYS remove the throttle body to clean it. If you're to the point where you can reach the front, it's just 5 screws and it pops right off. The back tends to get fouled up much more than the front. Just did this for a neighbor yesterday as a courtesy cause he had asked me to replace his intake boots.
Old 09-24-2012, 10:49 AM   #12367
moiz21
Worked just fine the way I did it. And never got the eml light again until I traded it in. Oh well.
MODS
Old 09-24-2012, 11:02 AM   #12368
ryannel2003
My Ride: '04 Cadillac Deville
Clean the throttle body and ICV and you'll be fine. I did this months ago on my car because it was going into limp mode and it's been fine ever seen. Probably a good time to replace the throttle body gasket and check to see if your CCV is in good shape too.
ryannel2003 is offline   Reply With Quote
Old 09-24-2012, 11:17 AM   #12369
GSherbs
My Ride: 2002 330 xi
Finally got around to doing my final stage resistor - for some reason, I just never enjoy working on the inside of the car so I had been putting it off until now that I need heat.
Then followed up with wash, polish & wax - which is when I discovered my first small bit of rust beginning to form on the drivers side rear door frame .
GSherbs is offline   Reply With Quote
Old 09-24-2012, 11:41 AM   #12370
Imola.ZHP
My Ride: Imola ZHP
Just blew nearly $1250 (it will be more than that when shipping is added) on clutch parts plus rear-main seal...
OUCH!
-- '03 330i ZHP
-- Marcus
Imola.ZHP is offline   Reply With Quote
Old 09-24-2012, 11:48 AM   #12371
GSherbs
Don't feel bad. Spent $2000 on my clutch, slave cylinder, RMS. I wish now that I had attempted to DIY but I just didn't feel at the time that I could do it safely.
$1250 does seem like a lot for parts - aftermarket?
Old 09-24-2012, 12:00 PM   #12372
sjacoby112
My Ride: 2002 325ci
wheel spacers next???
2002 325ci | 5MT | SGM/AGM | Varrstoen | RoyalStance | Form Flow & Fitment | Flipzco
sjacoby112 is offline   Reply With Quote
Old 09-24-2012, 12:26 PM   #12373
GSherbs
Possibly, but don't go overboard - 5mm ideally, no more than 10mm
Old 09-24-2012, 12:42 PM   #12374
My Ride: Lexus
Of course it'll work "fine." I didn't remove and clean the throttle body due to any light, but just because it's the proper way to do it.
Old 09-24-2012, 01:13 PM   #12375
Imola.ZHP
My Ride: Imola ZHP
OEM, bmwmercedesparts.com is where I buy all of my parts (unless I forgot something and have to pay full price at the local stealership). Some people have had issues with them, but for the most part I have not. A couple of orders back never got filled and when I called to ask what the hold up was they were very apologetic and it was early enough in the day that they sent it overnight (saturday deliver) to my door... It was nothing time-sensitive, but wow, I was impressed...
From my research, "lightened" flywheels seem to only make the new clutch wear out quicker. My car is a daily driver so OEM will hopefully give me another 115,000 miles. I looked for Luk or Sachs online but its difficult to find the correct clutch kit for 6-speeds for some reason and when I would find them, they were over bmwmercedesparts.com's $325.XX price...
I have replaced two other clutches, and am fairly mechanically inclined, so I'll be doing the labor myself...
-- '03 330i ZHP
-- Marcus
Old 09-24-2012, 02:04 PM   #12376
My Ride: Lexus
BMWmercedesparts doesn't sell OEM parts.
Old 09-24-2012, 02:53 PM   #12377
trj
My Ride: 325Ci
Took some pictures on the way to Mt.Evans.
It was on Saturday though
Old 09-24-2012, 04:06 PM   #12378
My Ride: Lexus
^ the back of your car is missing in pic #3
Old 09-24-2012, 04:09 PM   #12379
trj
My Ride: 325Ci
Yup, trying to hide my plates. lol.
Well, I was trying to get a good angle on the trees and the back of the car went missing.
Old 09-24-2012, 04:13 PM   #12380
moiz21
I still don't understand the point of hiding your plates when taking pictures. You drive around with them in plain sight all day long. What can someone do with a picture of your plates? (not being argumentative either, I genuinely dont see the point)
MODS
Rate This Thread
