Thread Tools Search this Thread Rating: Thread Rating: 1996 votes, 4.91 average.
Old 09-30-2012, 02:06 AM   #12541
Beamer Creamer
My Ride: 2005 bmw m3
Thanks for no reply. I guess i just like speed more than pinstripes and tan leather
Beamer Creamer is offline   Reply With Quote
Old 09-30-2012, 02:36 AM   #12542
Marinerd
My Ride: 04 xiT, 09 328i
Traded her in for an e90
Marinerd is offline   Reply With Quote
Old 09-30-2012, 03:38 AM   #12543
ShootyzGruve
My Ride: 2003 325i
Originally Posted by ImolaSix View Post
In the process of replacing my control arms. Driver's side is done, but I'm stuck on the passenger side.
I can't for the life of me loosen the inner ball joint nut
Any ideas?
Some things to try:
1. Allen wrench in top of ball joint to hold while turning nut.
2. Jack up CA from underneath to try and get BJ taper to set into subframe.
3. I had this problem with my CA arm and none of these worked. I ended up tearing the boot off the BJ, cleaning the grease off and getting this nifty little pipe wrench thing on the BJ. The wrench was such that when you soon the head the jaw opens/closes, so essentially it tightens itself when turning against it with a wrench in the BJ nut. This is what worked for me.
Whatever you do don't cut the CA off and try to get the BJ out through the top. It's tapered and won't come out.
Sorry if this isnt understandable, but its late and I'm using bimmerapp. Good luck, you'll get it done!
ShootyzGruve is offline   Reply With Quote
Old 09-30-2012, 04:01 AM   #12544
Beamer Creamer
Ya those wrenches kick ass. Channel lock brand i have are good. Parrot jaws. Haha im just trying to intrude into converse. But another tip is heating anything threaded then use candle wax as a flux . It will suck it into treads. I didnt believe till i used on a brake line in caliper i couldnt get with oils. Also if normal jacking underneath doesnt work put jack pinpoint pressure on the dead center of bj bottom and will help put more direct pressure on the ball to stop it turning
Old 09-30-2012, 04:25 AM   #12545
TurnersInOz
My Ride: 2004 325i
Any ideas?
I had to come at it from underneath, it wasn't a lot of fun.
I was able to fish a long wrench in from the front, above the arm. Took a while, but eventually the nut came off
Also had to hold the stud with a hex on install. After the install was done the hex had wedged itself on the exhaust and I had to cut it in half to get it out.
Good luck!
Yesterday/today:
OFHG, VANOS, VCG, spark plugs.
TurnersInOz is offline   Reply With Quote
Old 09-30-2012, 06:24 AM   #12546
love hoes
My Ride: e46 318i
Put my angel eyes in yesterday and today instaled hids looks awesome with rhe white light from the hids over the yellow bulbs
love hoes is offline   Reply With Quote
Old 09-30-2012, 06:53 AM   #12547
agdiver
My Ride: bmw e46
Installed a home made paddle shift on an OEM 318i M43 steering wheel.. Love it !!!!
Sent from my SCH-i509 using Bimmer App
agdiver is offline   Reply With Quote
Old 09-30-2012, 07:01 AM   #12548
agdiver
My Ride: bmw e46
Old 09-30-2012, 01:09 PM   #12549
serdar255
My Ride: '01 325ci / '90 325i
pics, now!
For coding, custom shift knobs, and vinyl stickers: PM me
serdar255 is offline   Reply With Quote
Old 09-30-2012, 01:39 PM   #12550
cak323i
My Ride: ///M3 & 330i ZHP
after working on my friend's ///M all day yesterday....I managed to complete my BMW Performance strut bar mod today... I'm still sore from going in and out of his car all day yesterday...glad I got this done right...:thumbsup
I used liquid electrical tape to cover the exposed metal after bending it so that it wouldn't slip out.
The battery terminal mod in itself was not difficult to do but I decided to do mine this way so that I could keep the original hood switch position without having to cut and splice the wiring.
2004 TiAg ///M - 171,000 miles.......................2003 Imola ZHP - 180,254 miles
cak323i is offline   Reply With Quote
Old 09-30-2012, 02:47 PM   #12551
illestminimike
My Ride: Project Drama
What is going on here?
Old 09-30-2012, 03:07 PM   #12552
325CiMaN
My Ride: 01 BMW 325ci 3.0L
Did you wire them in to the steptronic some how?
325CiMaN is offline   Reply With Quote
Old 09-30-2012, 03:16 PM   #12553
Foxtrot_Uniform
My Ride: 325Xi
Brakes, rotors, Hawk ceramic pads and stainless steel brake lines. Bled the system with ATE Super Blue...
Foxtrot_Uniform is offline   Reply With Quote
Old 09-30-2012, 05:33 PM   #12554
ryannel2003
My Ride: '04 Cadillac Deville
Bosch +4 spark plugs (yes not the best, but much better than what was in the car), new valve cover gasket, and a fuel filter (which was stamped with a date of 9/09/99). It's amazing how people can neglect the simplest of things to replace.
ryannel2003 is offline   Reply With Quote
Old 09-30-2012, 05:39 PM   #12555
deliroast
My Ride: '02 M3 vert
Know the feeling lol. When I did ask the maintenance on the touring the fuel filter was marked 2000. To keep this on topic, redid the trim in the m. Still need to do one last part. And full detail yesterday, just in time for rain
deliroast is offline   Reply With Quote
Old 09-30-2012, 05:46 PM   #12556
WDE46
My Ride: '13 128i, '04 330Ci
Finally got around to putting my steering coupler in. 2004 with 65K miles had a little bit of play in the wheel (about 10 degrees). The coupler eliminated that. My car actually drives like a BMW should now. No tramlining at all anymore. Felt rock solid at 100+ mph. The only problem now is my steering wheel is off by about 10 degrees. I had to let the column turn that much to get a spline that would fit in the coupler. I couldn't get it in there straight. I'll have to do a front end toe adjustment now, but I don't mind the wheel being off because the car handles so ****in well now.
I should note that the old coupler had no visible play while it was on the car. Once I took it off you could feel it move a little with some hand twisting. Didn't feel like much so I thought the coupler wouldn't fix my problem. It's amazing what that small amount of play was doing to my handling on the highways.
Old 09-30-2012, 06:56 PM   #12557
agdiver
My Ride: bmw e46
Yes i did
Now i have paddle shift on my OEM steering wheel
Old 09-30-2012, 06:59 PM   #12558
agdiver
My Ride: bmw e46
I'm paddling my self with my OEM steering...
Old 09-30-2012, 07:14 PM   #12559
ryannel2003
My car drives so much better now. I had a small hesitation when pressing the gas pedal which is almost completely gone. Spark plugs made a huge difference in power... feels like I gained about 15-20HP. I'm still tracking a rattling noise in the front though. Damn cars always need attention lol.
Old 09-30-2012, 08:59 PM   #12560
My Ride: Lexus
Refreshed my manual transmission fluid (D4 ATF w/ 30k miles) with new D4 ATF. Damn the drain and fill plugs were super hard to get off.
Rate This Thread
