Rating:
#12561 |
#12562 |
No more E46 guy
My car drives so much better now. I had a small hesitation when pressing the gas pedal which is almost completely gone. Spark plugs made a huge difference in power... feels like I gained about 15-20HP. I'm still tracking a rattling noise in the front though. Damn cars always need attention lol.
#12563 |
Refreshed my manual transmission fluid (D4 ATF w/ 30k miles) with new D4 ATF. Damn the drain and fill plugs were super hard to get off.
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#12564 |
washed and waxed my 323
good for the week
![]() Long Nights and Sandy Beaches |
#12565 |
cleaned my wheels with mr. clean magic eraser.
#12566 |
Mod
My valve cover gasket is leaking, I hear some rattle sound when I drive off... -______-
and... my coolant temps are still 98-102
#12567 |
That strut bar is the nicest ive seen yet. Fuel filters actually do there job better when they are slightly dirty. They are starting to make new filters now that mimic partially clogged by having smaller holes. If performance is good its prob ok but yep 1999 and 2000 prob means overdue. What kind of angel eyes are best? I want good adjustable support clips and black wires, also do they rattle around atall and look cheap?
#12568 |
New Meyle HD control arms are in! The steering is crisp!
![]() My original ZHP control arms were shot after 103k miles. It's true, they do last longer than the regular E46 control arms, but not forever.
#12569 |
video of rattle?
![]() Want a handmade shift knob or custom vinyl stickers? PM me I'm sixteen and like cars with three pedals. My ever small company... http://stgfabricationandmolds.bigcartel.com/ www.facebook.com/StgFabricationAndMolds |
#12570 |
Wondering why u changed ca's? Is that the only way to change ball joint or ?
#12571 |
Yup, the outer ball joints were toast. The Meyles have replaceable ball joints so next time they go I don't have to get new arms.
#12572 |
Cool. I just wired in a rockford 800a2 and 12" boston g5 in truck of course. Had a bitch of time to find keyed power anywhere near truck. Had to tap into passenger vanity light circuit in back of fuse panel under dash. I did everything else so it was reversible back to stock but felt real bad about tapping in so found a circuit that didnt matter but i was wondering if anyone knows of better place to get from? I couldnt find in service manual
#12573 |
Mod
#12574 |
I own a tool called a chassis ear. You can clip to up to 6 different points with gator clips and put on ear muffs and flip through each channel until you narrow down where noise is coming from. Works good anywhere under car too. Just make sure wires are ziptied away from moving parts and arent rubbing on car paint
#12575 |
Check it out...
Sent from my SCH-i509 using Bimmer App |
#12576 |
Another busy weekend for me, tackled it nevertheless, a overhaul cooling system:
Replaced with new: Radiator Upper and lower hoses Thermostat Water pump Mounting bracket Expansion tank Coolant sensor Level sensor Bled as stated in Bentley manual, test drove it and no issues. Gauge stayed at 12 o'clock position, Check fluid again, no air bubbles and running great. The only thing is the new Behr radiator had a different drain plug, compare to the oem radiator. |
#12577 |
My Ride: '03 325i --> '13 GTI
Replaced my passenger side HK speaker... Finally have normal sound again
Also fixed an issue with my headlights. The passenger side would always be a lot dimmer than the drive side... Apparently the D2S bulb fell out of the socket! The locking ring is worthless. It's only a matter of time until it pops out again |
#12578 |
#12579 |
Weagle Weagle
So my steering is pretty tight, but I still tramline a little. I have replaced control arms and bushings (front and rear) and steering guibo. Could the remaining tramling problem be caused by bad ball joins on the steering rack tierods? Is it worth replacing those as well? The steering feels tight, but I still get yanked around on the highway a little.
#12580 |
Dont just replace incase. Lift car, look and feel inner and outer tierods. U prob have? Checked tire runout on balancer maybe?
| Rate This Thread | |
