Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 11-27-2010, 03:57 PM   #1261
deadflyer
My Ride: '02 330i
Just thought of something, I need to get my mechanic a Christmas present, he did all that for $127 and the inspection/emissions check alone costs about $50.
deadflyer is offline   Reply With Quote
Old 11-27-2010, 07:04 PM   #1262
rossisboss
My Ride: '03 330i sedan ZHP
pulling my coolant expansion tank back out to see what's causing the smaller bottom fitting to leak coolant..... this blows. I'm kinda glad I bought 2 extra gallons of coolant now though.
rossisboss is offline   Reply With Quote
Old 11-27-2010, 09:46 PM   #1263
NerdCore
My Ride: 02 325i
Purchased 200 white LED's. I will do the entire interior in white LED.
NerdCore is offline   Reply With Quote
Old 11-27-2010, 09:47 PM   #1264
HyeWarrior
My Ride: '03 325i --> '13 GTI
Do a DIY!!!
Wow
So Amaze
Much Torque Steer
Such FWDoge
HyeWarrior is offline   Reply With Quote
Old 11-27-2010, 11:21 PM   #1265
spencers
My Ride: 2006 330i
Installed a new lock actuator.
Shattered the window in the process. FML.
spencers is offline   Reply With Quote
Old 11-28-2010, 12:50 AM   #1266
rossisboss
fixed one coolant leak, now it appears I have another issue, took the car for a drive and got no heat, then shortly before returning home temps started climbing, shut her down and coasted into the drive. car still had coolant in it, no drips on the ground... thermostat? also hoping the moisture on my oil cap is just moisture evaporating after the recent temp drop. 60 F to 20 F
Old 11-28-2010, 11:08 AM   #1267
NerdCore
My Ride: 02 325i
Sounds like there is air in your system, bleed the coolant system.
Old 11-28-2010, 12:58 PM   #1268
EmFiftyFour
My Ride: 03' 330xi auto
It crossed my mind, but thats about it..
EmFiftyFour is offline   Reply With Quote
Old 11-28-2010, 02:36 PM   #1269
rossisboss
lol, actually I figured that out last night, the cold and nagging coolant leak had me frustrated and I half skipped that part... whoops.
working with cold coolant when it's 20 F outside pretty much sucks. even when it was in a garage, I had no heater.
Old 11-28-2010, 05:14 PM   #1270
zwei e46
My Ride: '99 323i & '05 325xi
Did my first ever DIY oil change. Used Mobil 0W-40.
Also changed out my bad oil level sensor. Ahh, no more 20 sec. yellow light.
I love this forum
zwei e46 is offline   Reply With Quote
Old 11-28-2010, 08:00 PM   #1271
BMWalker
My Ride: 2001 BMW 330i
alot search my posts but mostly just a very through visual inspection
BMWalker is offline   Reply With Quote
Old 11-28-2010, 08:08 PM   #1272
darksideracer69
My Ride: 01 325ci
new drilled slotted rotors and pbr pads
IMAG02051
Old 11-28-2010, 08:10 PM   #1273
Andy2108
My Ride: SpecE46 & E46 M3
I looked at it once...
Goodluck on the gauge cluster, radio, and hvac
De gustibus non est disputandum.
Old 11-28-2010, 08:41 PM   #1274
mjdx88
My Ride: 2001 330ci
Originally Posted by HyeWarrior View Post
Do a DIY!!!
+1
I love this forum
Keep it up, its the best place to start
I finally got around to changing my gear oil, at 116 almost 117K =/ it needed it. For the last time adjusted my ebrake, I just kept missing the sweet spot on the drivers side. =( I ran out of time to do the diff oil...thats for next weekend.
mjdx88 is offline   Reply With Quote
Old 11-28-2010, 11:55 PM   #1275
amunoz27e
My Ride: 325ci
I did some minor paint touch-ups, installed my ACS roof spoiler, removed some rust by wire brushing my rotors then painting them, adjusted my coilovers by dropping it some more, finally installed CF wheel caps.
Bilstein PSS10 Coilovers | Highline Tuning Catback Exhaust | Double Din Audio | Lots of Carbon Fiber Interior/Engine Bay | 19x8,19x9.5 Wheels | RIP - Reiger Body Kit .
amunoz27e is offline   Reply With Quote
Old 11-29-2010, 01:05 AM   #1276
gonzo08452
My Ride: 323 and 325 5spd
wash, wax, and gas
gonzo08452 is offline   Reply With Quote
Old 11-29-2010, 01:32 AM   #1277
reddemon
My Ride: 2004 325i
Changed my FCABs last weekend, installed the ECS $89 ones, they feel great. Got the ECS level 1 cooling system refresh, still have to work on that. Also bought a buffer, sand paper, rubbing compound and plastix to fix the headlights, haven't done that either. Ordered mobil1 0w40 and filter, should be in the mail soon.
r e d d e m o n
reddemon is offline   Reply With Quote
Old 11-30-2010, 04:21 PM   #1278
theinfamousdrew
My Ride: 911 Turbo / E70
Just got done with my valve cover gasket....no more smell of oil at red lights! (I hope)
theinfamousdrew is offline   Reply With Quote
Old 11-30-2010, 05:08 PM   #1279
jyerabutar
My Ride: 01" 325iT
Summary for this past month
Installed
- 2 Recaro SDR seats
- Hamann Pedal Set (anodized in black)
- Radenergie engine cover
- Radenergie Strut bar
- Weiss led licence plate lights
- Washed car
http://forum.e46fanatics.com/picture.php?albumid=2578&pictureid=24900
jyerabutar is offline   Reply With Quote
Old 11-30-2010, 05:46 PM   #1280
spencers
My Ride: 2006 330i
Had a new door window installed
Rate This Thread
